Go Back   ADVrider > Riding > Regional Forums > Pacific Northwet - Where it's green. And wet.
Old 03-24-2014, 09:24 AM   #4036
Harsany
Harsany's Avatar
Oddometer: 48
Originally Posted by ttime4four View Post
I'm still learning how to use this new 62st, but here's a link that should work for you...
http://adventures.garmin.com/en-US/b.../#.Uy_HjNymDFk
Just download the "Adventure" and I think you can transfer it to your GPS.
That's a cool feature that Garmin has - thanks for sharing!
My old Streetpilot started working again after I got home. Hopefully it was just a fluke that it couldn't get satellite reception.
07 525 EXC
05 CRF 50
Harsany is offline   Reply With Quote
Old 03-24-2014, 09:39 AM   #4037
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,539
Originally Posted by Harsany View Post
That's a cool feature that Garmin has...
I don't know anything about Basecamp, but on that link, I found something interesting:
Send Your Story to Friends and Family
You can email your adventure, share it on Facebook® and Twitter®, or post it in your favorite forums. When you publish, you're also sharing your adventure with a community of fellow explorers who can see where you went and what you experienced along the way.
Explore
Discover New Adventures
Your adventures live in the cloud, so you can experience them online, on your GPS device, on your phone or in BaseCamp. You can also find inspiration for your next journey by searching BaseCamp for other adventures.
I don't know, but this looks like you are showing your tracks to the world. That is fine if that is your intention- not so fine if it isn't.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 03-24-2014, 09:41 AM   #4038
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,750
TTime, what program were you using to generate the above map of your route? Did you just do a screen capture of it or something?
FWIW - Been trying to memorize the trail names a bit. Looking at your route, I'm guessing:
Rogers Camp
Crooked Bridge
Military
Sidewinder
Julies
Elmers
Cedar Tree
Gummy WOrm
Black Water
University Firepower
Kthumb
Elliot Creek
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 03-24-2014, 12:05 PM   #4039
jjdun7
jjdun7's Avatar
Oddometer: 461
Only if you Publish. If you don't hit Publish, it stays on your computer.
_________________________________________________
http://advrider.com/forums/showthread.php?t=871546
http://jjdun7.smugmug.com/
"Get out and explore"
jjdun7 is offline   Reply With Quote
Old 03-24-2014, 12:13 PM   #4040
MortimerSickle
Semi-Adventurer
Oddometer: 12,539
Good to know, thanks.
Maybe I'll give it a try.
G.H.W.S. 1878-1962
Old 03-24-2014, 01:43 PM   #4041
ttime4four
ttime4four's Avatar
Oddometer: 272
Rogers Camp
Crooked Bridge
Military
Sidewinder
Julies
Elmers
Cedar Tree
Gummy WOrm
Black Water
Kthumb
Elliot Creek
I'm using Garmin Basecamp to show the track and just did a simple screen shot to include in my post above.
To answer MortimerSickle's question - still experimenting / learning about the publishing function. I guess if the route get's too crowded you can blame me. I'll try the limited sharing function next time.
I wanted to simply convert my track into a route, but the program was doing a bunch of auto routing to Hwy 6 and I couldn't figure out how to just create a route that matched the track.
'14 KTM 690 Enduro R
'14 BMW R nine T
ttime4four is online now   Reply With Quote
Old 03-24-2014, 04:24 PM   #4042
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,750
That's the same program I use, but my maps dont' look anything like that. May be time to upgrade units. Is that the built in map or did you add that?
Old 03-24-2014, 09:27 PM   #4043
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,241
If you change your map set to one that doesn't support autorouting (or turn off the map completely) then it will create a point-to-point route.
Luke is offline   Reply With Quote
Old 03-24-2014, 09:37 PM   #4044
ttime4four
ttime4four's Avatar
Oddometer: 272
The unit I'm using is the 62st which comes with the 100k Topo. When I connect to Basecamp, the Topo map is displayed.
'14 BMW R nine T
Old 03-24-2014, 09:47 PM   #4045
ttime4four
ttime4four's Avatar
Oddometer: 272
Ok Luke -- I turned off the 100K Topo and the "Global Map" remains -- and this is what I get. Is this what you were expecting in a point-to-point route? I was hoping for a route that exactly followed the track.
I exported the track into a GPX file -- here --> https://dl.dropboxusercontent.com/u/...SF%20Route.GPX
Does this work for anyone?
'14 BMW R nine T
Old 03-24-2014, 10:10 PM   #4046
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,241
Yes, that looks right. It won't follow the track unless you put as many route points down as there are track points, which defeats the purpose of making a route.
I haven't found a great solution for using a GPS in the woods. Saving up a bunch of tracks and then making routes from them is often good enough.
The State forest managers did just post a GPX file with tracks of all the different trails in the Browns/Jordan Creek/Diamond Mill areas.
http://www.oregon.gov/odf/tillamooks...ohvtrails.aspx
Download the Class III file and rename the extension .gpx instead of .gpx.bin
Old 03-24-2014, 11:22 PM   #4047
lucknau
Greenhorn
lucknau's Avatar
Oddometer: 211
Ok
Yep. That's a keeper.
Spotwalla location ID: LUC
lucknau is offline   Reply With Quote
Old 03-25-2014, 07:44 AM   #4048
matloik OP
kludge
matloik's Avatar
Oddometer: 1,253
At the risk of pushing this discussion too much off topic: I'm far from a GPS guru, but I don't see the need to create a 'route' from a 'track'. I just keep a bunch of tracks from previous rides in an area on my unit, which tracks I can just as easily see on there when I'm out in the area again. I don't need the navigation-by-route feature of the GPS when riding in the woods. Eh?
2011 KTM 250 XC-F / DRZ-ADV / 2013 WR250R (wife's)
matloik is offline   Reply With Quote
Old 03-25-2014, 07:55 AM   #4049
MortimerSickle
Semi-Adventurer
Oddometer: 12,539
Originally Posted by matloik View Post
...I'm far from a GPS guru, but I don't see the need to create a 'route' from a 'track'.
You think that you are no guru, I don't even know the difference.
G.H.W.S. 1878-1962
Old 03-25-2014, 08:42 AM   #4050
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,750
COOL!
Will check that out. Thanks Luke!
Times are GMT -7.   It's 11:18 AM.
