Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 03-25-2014, 08:52 AM   #4051
RandomGuy
RandomGuy's Avatar
Oddometer: 19
Originally Posted by MortimerSickle View Post
You think that you are no guru, I don't even know the difference.
@Mortimer: Every unit / software package is a little different, but basically a track is an outline of where you went and a route is where you can be guided to. - You make a track, but you follow a route. (Although some units can navigate tracks in reverse direction.)
@TTime: Yes! Works perfectly...almost gave up when I discovered garmin makes you install their software to download the "adventure". The gpx file link imported into Locus on my phone perfectly. Thanks!
(If you click on the link in Windows it will try to open as a webpage...just right-click and select "save link as" and save the .gpx file.)
Either write something worth reading or do something worth writing. --Benjamin Franklin
RandomGuy is offline   Reply With Quote
Old 03-25-2014, 10:33 AM   #4052
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,376
Thanks, RG.
Got it: the track is what you figured out for yourself, and the route is where the gps wants you to believe it will take you.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 03-25-2014, 11:14 AM   #4053
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,191
Originally Posted by matloik View Post
At the risk of pushing this discussion too much off topic: I'm far from a GPS guru, but I don't see the need to create a 'route' from a 'track'. I just keep a bunch of tracks from previous rides in an area on my unit, which tracks I can just as easily see on there when I'm out in the area again. I don't need the navigation-by-route feature of the GPS when riding in the woods. Eh?
Navigating by route is much more efficient, if you have a good route. The GPS will display the distance to next turn and the turn direction, which I can follow while riding. I can't (safely) follow a track on the map screen without stopping a lot.
It's really hard to make a good route with a bad map, so in the woods I end up stopping a lot when following a route anyway. There the main benefit of a route is keeping it separate from all the tracks in the gps menus and mapsource.
Luke is offline   Reply With Quote
Old 03-27-2014, 10:56 AM   #4054
Mr Dual Sport
Roamer
Mr Dual Sport's Avatar
Oddometer: 1,727
Looks like highway 6 is closed due to a landslide at MP 31. Little wet over there?
You're never lost till you run out of gas....
Mr Dual Sport is offline   Reply With Quote
Old 03-27-2014, 11:08 AM   #4055
MortimerSickle
Semi-Adventurer
Oddometer: 12,376
Originally Posted by Mr Dual Sport View Post
Looks like highway 6 is closed due to a landslide...
It's good at that.
A large landslide in Tillamook County blocked 600 feet of Highway 6 on April 4, 1991, with 500,000 cubic yards of rock and soil partly damming the Wilson River. This highway has been closed annually by mudslides or rock-falls, and the 1991 episode took nearly two months for debris removal at a cost exceeding $2 million. The slide occurred when soils on the steep slope became saturated from nine inches of winter rain in two days. Cracks appeared along the upper planar slide and permitted infiltration of runoff to saturate soils. The soil liquefied immediately before movement. When the event took place, the slide was being monitored, and an attempt was being made to drain the slide block.
January 20, 2011 11:00 am
PORTLAND (AP) -- Oregon Highway 6 has been reopened after road crews cleared a landslide that had blocked the route between Portland and Tillamook since last weekend.
The Oregon Department of Transportation said utility companies will be working on power lines in the slide area and flagging one-way traffic at times.
Motorists can expect some minor delays, and should be alert for falling rocks, mud and other debris on the roadway.
G.H.W.S. 1878-1962
Old 03-27-2014, 05:21 PM   #4056
ckurowic
ckurowic's Avatar
Oddometer: 140
Are there any upcoming pavement rides planned? I'm still pretty unfamiliar with the area and my '1200 isn't set up for anything but street riding at the moment.
2006 R1200GS
ckurowic is offline   Reply With Quote
Old 03-29-2014, 06:39 AM   #4057
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,776
Hold that thought....
Or not Do Thursdays work at all for you?
My big bike is begging me to stretch her legs...
Mr. Fisherman is offline   Reply With Quote
Old 03-31-2014, 07:26 PM   #4058
chokozip
Oddometer: 194
Hi All!
Sean
I will meet you on the long road to the middle.
Colorado/Utah 2014 ride report here:
http://advrider.com/forums/showthread.php?t=1019732
chokozip is offline   Reply With Quote
Old 03-31-2014, 07:28 PM   #4059
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,541
Originally Posted by chokozip View Post
Hi All!
Sean
Yo, Sean, how's Minneapolisatota, or wherever you is?
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 03-31-2014, 07:50 PM   #4060
chokozip
Oddometer: 194
Well I have to say its not as bad as i thought it would be.
Its almost like Bend just missing the mountains.
The sun shines most days.It has been nasty cold but they tell me it has not been like this since the 60's.
I thought there would be more snow but you can ride snowmobiles right out of the garage and go where you want.
I have missed riding the bikes over the winter but they have been in portland so not much I could do about it.
All our crap shows up with the moving truck mid week so it will be nice to get somewhat back to normal.
Old 03-31-2014, 08:05 PM   #4061
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,541
Its almost like Bend just missing the mountains......
How's the 'squiters up there?
Old 04-01-2014, 09:18 AM   #4062
layzrider
Layzrider
layzrider's Avatar
Oddometer: 193
Help save the Gifford Pinchot riding trails
Here is a photo of the trail tools volunteers use in the Gifford Pinchot NF. I am trying to get some volunteers to do tread work this summer. Some riders like to do log out but not fill ruts. Most of the single track trails are severely rutted. They are so difficult, many riders try them once and never return. I am coordinating the volunteer effort on Thumper Talk - Help save the GP riding trails. We may try to have a campout or two this summer. One day work and one day ride. Any help would be appreciated
layzrider is offline   Reply With Quote
Old 04-01-2014, 09:43 AM   #4063
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,436
April Fools campout down in Brookings is coming up next weekend (12-13), you can certainly stretch those legs out riding down the coast.
Oh, and Hiya Sean, miss ya buddy.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 04-01-2014, 10:04 AM   #4064
chokozip
Oddometer: 194
No skeeters yet everything is still frozen.My yard has about 20" of snow on the ground still.
Hi Scott. I would love to go on some rids and hang out.The hardest part of moving was leaving everyone back on the west coast.
Ill be back. We still have the house in Portland and my little bro is renting it.That gives me a place to keep a bike :)
Sean
Old 04-01-2014, 10:34 AM   #4065
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,697
i will be watching this. will try to do my part this year
none of us is as dumb as all of us
clapped_r6 is offline   Reply With Quote
Times are GMT -7.   It's 12:39 AM.
