05-03-2012, 09:14 PM
#2041 |
Oops...
My Dad used to work for John Deere back in the day. He has stories about a "paper shredder" that was build out the back end of a combine... Said the operators would carry out PALLETS of paper to be shredded- by dumping the entire load, pallet and all, into the shredder. Guess it was kind of a running joke to see what you could run through the shredder. Worked great until someone sent a *large* ball bearing through it...
Don't think this pencil sharpener's going to work too well for metal, although you would not believe some of the things I"ve pulled out of these things.
http://www.mobilemrt.com http://www.dorkpunch.com "I've been going to this high school for SEVEN YEARS. I'm no dummy!" -Charles De Mar. |
05-03-2012, 09:38 PM
#2042 |
Oops...
Still not finished, but heres a few more pics.
![]() ![]() ![]() ![]() ![]() ![]() Hard part is going to be finding a carb for the motor...
05-04-2012, 03:43 AM
#2043 |
Native Texican
Oddometer: 4,735
I'd put a grease fitting in that sharpener.
N. Texas "There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation." |
05-04-2012, 07:49 AM
#2044 |
Oddometer: 6,008
05-04-2012, 09:44 AM
#2045 | |
visionary
Oddometer: 2,043
I was really enjoying where this was going, until I read that. Why the f*ck would someone even think to try such a stupid thing??!!!! "I know, let's try.....THIS!!!" is extremely similiar to the phrase, "Hold my drink and watch this...." ![]() I'll bet that was the end of the fun for everyone!!!
"Good Times & Good Friends Make Life Better" www.artworks-unlimited.com |
05-04-2012, 09:50 AM
#2046 |
Tiene Ruta Cuarenta?
Oddometer: 2,989
Dude, NO PORN ON ADVRIDER.COM! Jeez, yer gonna get this site taken down!
2013 Triumph Tiger 800 - 2007 Harley XL1200R Roadster - 2002 BMW R1100S You can lead a politician to water, but you can't make him think. - Kinky Friedman Improve your cosmic karma here! |
05-04-2012, 10:59 AM
#2047 | |
A proud pragmatist.
Oddometer: 2,859
Have tools, will travel!
05-04-2012, 02:01 PM
#2048 |
ಠ_ಠ
Oddometer: 3,286
Have this Massey's Patent front vise:
![]() ...but it's missing the cam dog, visible in the patent drawing of the bench vise version, part "L": ![]() The spiral cam on the lever shaft pushes the dog into the toothed plate in the fixed half of the vise, while drawing the vise tight. Here is a view from beneath the bench, showing the toothed plate: ![]() The teeth on the new dog have to match the teeth on the plate. The teeth are 8 per 1-1/8", or .140625" apart. Not a problem: ![]() I made the maple pattern long, so I could have two dogs: one for a foundry pattern and one to test fit and use temporarily. The pattern and the rough casting back from the foundry: ![]() Cam surface and teeth are cleaned up with files: ![]() Cam surfaces are greased and dog is placed in position on the cam: ![]() Front jaw slides back into the housing and: ![]() It works! This bench has a vise on each corner. You can see the patternmaker's vise on the opposite side, and there is a nice quick-opening Reed front vise on the other end. You can also see two aluminum bench hooks that are part of an enclosed tail vise. I had a handful of these when I built the bench, and spaced them evenly, and intended to get and install more hooks later. There needs to be two more hooks in between each of the hooks that are already installed, based on the amount of travel the vise jaw has. Here is a shot of the enclosed tail vise: ![]() So I found some vintage bench hooks for a good price, found they were 100% better than the aluminum I already had, and so I got some more so I can replace all the bench hooks with these much larger, stronger, cast steel beauties: ![]() So the next step is to mortise in all these bench hooks so the enclosed tail vise will be usefull. Then all that remains is a drawer cabinet below for much needed additional chisel, gouge, and plane storage.
Lost on a wave that you're dreaming Dream on, on to the heart of the sunrise. Sharp, distance - How can the wind with it's arms all around me? |
05-04-2012, 02:15 PM
#2049 |
bout a dollar 3.98
Oddometer: 3,069
Helluva Nice Job HBS ,
![]() this weekend , I'm gonna try and get some pics of the Router table , insert , and lift mechanism I did a liite while back for My big P Cable router.
Marko 08 xr650l 99 xr650l 84atc200s 85atc200s 80ct110 99xr70 04xr50 85atc70 87trx70 Dumb ass people do dumb ass things
05-04-2012, 03:02 PM
#2050 | |
1.5 Finger Discount
Oddometer: 20,074
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy "Never bring a Nerf gun to a shovel fight." - My Brother |
05-04-2012, 03:56 PM
#2051 | |
Oops...
Pulled a carb off of a different weedeater, got it to *kind of* run. Need to find a better matching carb, but its complete and working-ish. I plan on re-doing the "driveshaft"- its a little offset and make the pencil sharpener shake. Pics to follow...
05-04-2012, 04:14 PM
#2052 |
At home in my jammies
Oddometer: 1,809
Oh yeah, Hold my beer and watch this!
I know what I want, but I just don't know! |
05-04-2012, 04:22 PM
#2053 |
Oops...
we DID have an interesting moment when the can vibrated off and hit the blades... Spun it around a few times and launched it across the table. A little DUCK tape, problem solved!
![]() ![]() Nowhere near the right carb, but it kinda works.
05-04-2012, 07:05 PM
#2054 |
A proud pragmatist.
Oddometer: 2,859
Not a JD...color fooled me. Rosalie would have liked that, she's studying to be a teacher and big JD fan. They still do have pencil sharpeners at the teacher's desk don't they????
![]() Carb for you? A Walbro. Free but $20.00 to ship. ![]() Eager Beaver.... ![]()
05-04-2012, 07:08 PM
#2055 |
In the snow
Oddometer: 707
OK this made me laugh fucker. Awesome job.
Some serious talent around this place for sure.
You're stronger than you think. |
| Thread Tools | |
