Thread Tools Rating: Thread Rating: 454 votes, 4.98 average. Display Modes
Old 01-17-2013, 06:05 AM   #2821
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
Originally Posted by martinnyc View Post
Sorry buddy, but the flex looks it's worst somewhere near the middle of the carrier.
that's insane, max tongue weight rating probably 500 lbs at the hitch so multiply that by X as you move further out.
MookieBlaylock is offline   Reply With Quote
Old 01-17-2013, 07:13 AM   #2822
tomski74
Silesian American
tomski74's Avatar
Location: North Tulsa where adventures happen every day
Oddometer: 1,478
All this ^^^ going on and my bike carrier post went un-noticed
Such a dissapointment for a beginner welder and an experienced attention whore
I was worried about my setup, but now I think I'm pretty safe
Now, let's see what else you FF have built
Present: '97 Valkyrie 1500, '98 VFR800 project Golas, '01 DRM650, '02VTX1800C, '02 KLX300R, '06 TRX680,
Past: '82 XT550, '83 R80RT, '02 CBR954RR, '06 CBR1000RR, '06 DL650 Wee
tomski74 is offline   Reply With Quote
Old 01-17-2013, 10:08 AM   #2823
XR4EVER
919 excuses to ride!
XR4EVER's Avatar
Oddometer: 1,090
Originally Posted by tomski74 View Post
I had a 6' piece of a channel and some other scrap metal. My friend donated a few feet of heavy wall 2" square tubing. So I decided to build me a bike carrier. Total cost = $1.35 for one bolt and a nut
The fact that this went unnoticed may have been the greatest compliment among this crowd!
Nice work! And you can't beat the price!
I hate bear grass.
XR4EVER is offline   Reply With Quote
Old 01-17-2013, 10:16 AM   #2824
tomski74
Silesian American
tomski74's Avatar
Oddometer: 1,478
Old 01-17-2013, 10:58 AM   #2825
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,391
Originally Posted by ColinDoyle View Post
...if I revealed the rack hanging off my customer's dually.
Your customer? You didn't really build that piece of shit for a paying customer, did you?
The tubing is over 1/4" thick and has no bend whatsoever. What you're seeing is the minimal slop between the tube and the receiver, when extended a few feet.
1/4" isn't shit, and what you really need is more vertical separation between the top/bottom walls, and more than one hitch, and a fawking clue - obviously. You're putting other people's lives at risk ASSHOLE.
You guys have never seen these before?
They're stupid for making them, and their customers are stupid for buying them.
jesusgatos is offline   Reply With Quote
Old 01-17-2013, 11:07 AM   #2826
XR4EVER
XR4EVER's Avatar
Oddometer: 1,090
I hate bear grass.
Old 01-17-2013, 01:03 PM   #2827
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,341
+1, yikes.
Current Steed: '08 FJR1300
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
EvanADV is offline   Reply With Quote
Old 01-17-2013, 02:11 PM   #2828
Juanjo_NY
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 4,882
Mateo Maria & Julieta Maria _ 1-17-13 @ 8:14/15 _6.10 lb each.
cheers, Juanjo
Juanjo_NY is offline   Reply With Quote
Old 01-17-2013, 02:29 PM   #2829
EvoLife
Evolving.....Slowly
EvoLife's Avatar
Oddometer: 928
Beautiful work.
Congratulations.
"If what you are doing isn't working, don't try harder, try different."
"Today I'm younger than I'm ever going to be, and I intend to act like it"
EvoLife is offline   Reply With Quote
Old 01-17-2013, 05:11 PM   #2830
yankeeone
Oddometer: 162
colindoyle, one of the rigs you showed a few posts back had a doubler were the tube goes into the receiver, If you used a thicker wall tube for the doubler, that may be a big help to stiffen things up.
Brian
yankeeone is online now   Reply With Quote
Old 01-17-2013, 05:17 PM   #2831
JamesG
Rabid Poster
JamesG's Avatar
Oddometer: 10,946
Originally Posted by AK Oldman View Post
I don't think anyone is bothered by the FJ, just distance it is from the vehicle.
Also... with the bad rearward visibility on FJs I'd be worried about sideswiping and bashing your surroundings while trying to maneuver that thing...
I am a conservative, not a Republican. There is a difference.
JamesG is offline   Reply With Quote
Old 01-17-2013, 05:59 PM   #2832
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,327
How about this?
WARNING: Most things posted above contain sarcasm.
Daamud is offline   Reply With Quote
Old 01-17-2013, 09:46 PM   #2833
Iwantabikesobad
Iwantabikesobad's Avatar
Oddometer: 1,071
quad carrier on FJ.
That thing is scaring me. Take the hint from all the well meaning folks here. Junk it before someone gets killed. It would probably be someone like me. I would be trying to get close enough to see how bad it really was when it breaks off and the quad tumbles down the freeway. There is a chance of pulling your frame horns down and causing major frame damage.
Good safe riding to all.
Yes it's my Bike, No I wont help ya move!
Proud member of Father & Daughter riding club
09 KTM Adv. The Orange ones are faster!
Iwantabikesobad is offline   Reply With Quote
Old 01-17-2013, 09:47 PM   #2834
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,305
Mostly done air engine sporting a whopping 2cc of displacement!
Still need to drill and thread the intake hole to install a hose barb, and finis welding the motor to the base. The crank will be cut down to match the flywheel, and when I get the proper belt for my lathe I will finish the flywheel up.
The goal was to have a working air engine made with nothing other than basic power tools- mainly the drill press and welder. My students will not be using the lathe on their flywheels unless they want to come in after school and figure it out...
Some of the specs: 2cc, crankshaft made out of bent up 1/8" welding rod, piston made from 3/8" rod, rest of it is just basic hot rolled bar or flat stock. Lucked out on the flywheel and found a large chunk of 2 1/2" brass round stock at a scrap yard- plan on making about 40 flywheels out of it. Figure the total cost is under $5. The welds on the base plate are done with stick, wire feed, and oxy-acet- they practice a bunch and then hopefully do their "good one" on the base for display...
I'll post pics of the students projects when they get 'em done.
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 01-18-2013, 12:33 AM   #2835
Shoganai
Let's do some livin'
Shoganai's Avatar
Oddometer: 1,761
Originally Posted by EvoLife View Post
Beautiful work.
Congratulations.
Nana korobi ya oki
"Be who you are and say what you feel because those who matter don't mind and those who mind don't matter "- Dr Seuss
Shoganai is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 07:32 AM.
