Thread Tools Rating: Thread Rating: 415 votes, 4.98 average. Display Modes
Old 06-12-2011, 08:55 PM   #1066
Will LC8
I stubbed my toe
Will LC8's Avatar
Oddometer: 587
I've got a green thumb
Awsome having a garden you don't have to bend over to work on.
Firts time I busted out the welder in about 4 years.
It was once said the man who can not touch the ground on his bike is destined to lay under it
http://abuddyforlife.org/
Will LC8 is offline   Reply With Quote
Old 06-12-2011, 09:26 PM   #1067
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,107
A few years back I purchased a TCML lift from Complete Hydraulics. I've been using it regularly without any problems until recently when the wheel vise stripped out. I would go to tighten the vise and just as it would start to tighten up it would pop and go loose again. Ended up that the vise uses a plastic threaded block inside that will eventually strip, if you have one of these vises go easy on it! I didn't want to buy another unit and just have the same crappy plastic piece that would fail again so a little home brew repair was in order.
Here's a old picture of the lift when I first purchased it.
First the vise isn't made to come apart so you need to grind the weld off where the crank fits onto the shaft going into the vise.
After sliding the vise apart this is what I found. The metal threaded shaft was in great cond, but the plastic threaded block that takes the load from the vise was stripped out....plastic!
As mentioned above the metal threads were fine but finding a new nut to fit the threads would be hard. Better to start new with a matched set. A large C-Clamp would provide the needed shaft and nut. Here's a pic just after cutting the needed pieces off the clamp.
Just finished welding in the "nut" part of the shaft using rosette welds all the way around. It now has more threaded surface area than it did originally and it's all metal!
I welded on a washer to be used as the inside thrust bearing. I will also place a nylon washer on both sides as a bearings surface.
Next I had to drill out the hole where the shaft passes through the jack assy since the new shaft has a bigger diameter.
Almost back together again.
Back on the lift and working better than new, just need to paint it to finish it up. I won't have to worry about cranking down on the vise now.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 06-13-2011, 03:31 AM   #1068
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,664
Innovative repair.
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 06-13-2011, 05:51 AM   #1069
AK Oldman
WANDRN
AK Oldman's Avatar
Oddometer: 249
Very nice job on that repair!
I didn't care for the vice on my lift right from the start. I wanted/needed something more. I'm a little guy and my Goldwing was 950 pounds. I never even mounted the factory wheel vice. Instead, I drilled a few holes, welded some nuts on the bottom side of the platform and mounted my Baxley Sport Chock to the platform. It takes maybe two minutes to pull it off and bolt it into the trailer if needed. I just ride whatever bike onto the lift and into the chock. The chock holds the bike upright while I get off and even has a safety lock to ensure the bike can't roll back out on it's own. This is the only pic I have right now. It's looking over the Goldwing at my Warrior on the lift.
AK Oldman is offline   Reply With Quote
Old 06-14-2011, 01:04 PM   #1070
Desert Skies
One brick shy...
Desert Skies's Avatar
Oddometer: 2,370
Got tired of the wind blowing my camp down in my winter trips to Big Bend. Figured I'd make a bed to put on my 16' lowboy so I went to the steel supply and picked up a few things.
Pulled out the plasma torch and welder and started making shit
Fit check.
A little bending on my homemade bender.
More welding.
A little wiring.
I'm a little further along with the project but had to take a break to built some cabinets for Desert Wife. I'll update later.
Plans are to let this take up the front of the lowboy and put my desert toys on the back for my annual trip to get dirty. Kinda like a poor man's toyhauler.
“Sorry I'm late, feck'n off takes a lot of time.”
" The 'Wing is my wife's bike - I'm just the feck'n driver." - USMCG_Spyder
" This post is full of VonBadenisms." - Gordy
Tripn' with Tom Some pictures ZZ Rider - Tom Lowry Texas Blue - Tom Lowry
Desert Skies is offline   Reply With Quote
Old 06-14-2011, 01:38 PM   #1071
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,599
Looks good so far, I like your roller.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is offline   Reply With Quote
Old 06-14-2011, 01:43 PM   #1072
Desert Skies
One brick shy...
Oddometer: 2,370
Thanks! I built the roller to do wagon wheel tyres.
Old 06-14-2011, 07:43 PM   #1073
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,599
Nice, I'll build me one of those someday.
N. Texas
Old 06-15-2011, 10:55 AM   #1074
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Sweet.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 06-15-2011, 11:01 AM   #1075
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,272
I'd like some more info on the roller, that looks like something I could build and use in my metals class!
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 06-15-2011, 12:18 PM   #1076
Desert Skies
One brick shy...
Oddometer: 2,370
Thanks! Don't have any plans for it, used the TLAR method to build it. Here is a couple shots of the bits and after assembly.
I used it to bend 1/2" EMT for the wheel that goes around the spokes. One important detail is the drive roller (top roller) needs to be knurled. One thing I would change and still might is cut the tops out of the bottom roller holes so I don't have to disassemble it to change roller position.
Old 06-15-2011, 12:29 PM   #1077
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,272
Curious, does it work on tubing as well? Did you build the circle for your handle with the roller?
-Charles De Mar.
Old 06-15-2011, 12:41 PM   #1078
Desert Skies
One brick shy...
Oddometer: 2,370
I did build the handle with it. When rolling tubing, it flattens the inside of the tubing. To keep tubing round, it would require a radius machined in each roller to match the tubing you are bending.
Here's a smaller ring I rolled out of 1/2" EMT. You can see it pretty much inverted the inner wall.
Old 06-15-2011, 01:05 PM   #1079
RocketMan
Out Rocketing
RocketMan's Avatar
Oddometer: 709
something I've been working on off and on over the past 40 years. Actually got the model kit when I was 16 but it seems way to complex at the time to start and we were still living overseas. it is an all wood 40 long by 10.5 inch beam, Sterling Model of the classic Christ Craft 63 foot Motor Yacht. Sterling made some really fantastic kits in their day, highly prized now among collectors it seems.
The kit is built with the same design as the original, same number of bulkheads with individual wood "planks' making up the front bow area, each having to be sanded and shaped to fit the curvature of the bow and adjoining plank. Decking is Mahogany just like the original and I fitted it for radio control. Kit was make in the mid 60's and plans actually show a tube type receiver and big 12 volt wet cell battery (I didn't follow that part of the plan though! and used a modern receiver and controls). I have all the running gear and railing but just haven't gotten around to adding those yet, hell at 30 plus years and counting putting it together to this state (finished about 12 years ago), whats another 15 years?? Perhaps when I retire....
When I take it out the ponds to sail kids go nuts over it and Dad's want to know where they can buy one. then I show them how its a kit and the work involved.... next thing I know they are off looking for ice cream for the kids! Ha Ha!
RM
http://roadrunes.com
"Live life to the fullest, cause buddy, once you're dead life ain't worth living" Nat King Cole
"Never trust a user with your television overnight,
Don't try to paint your masterpiece by artificial light." - The Pretenders
Always DSTDJR-----Don't Sweat The Details---Just Ride!!!
RocketMan is offline   Reply With Quote
Old 06-17-2011, 09:30 AM   #1080
AfricaWim
AfricaWim's Avatar
Oddometer: 330
That is pretty sweet !!
What good am I, if I know and don’t do, If I see and don’t say - Bob Dylan
AfricaWim is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 11:25 PM.
