11-02-2011, 03:32 AM
#1366 |
Location: The largest geological formation in the U.S.A.
Oddometer: 1,877
We traditional metal workers lost a giant in the craft due to galvanized stuff. It took two weeks after the event for him to go down, but Paw-Paw Wilson documented it for his last safety lesson. Here is a link worth reading. It's short, to the point, and parts of it are written by the victim.
http://www.anvilfire.com/iForge/tuto...n=safety3/demo I will add that it's very unlikely that you would reach the temps needed using a firepit and, most likely, you would be using the pit out of doors so you've got good ventilation. But...........don't tell me that burning zinc fumes are non-toxic.
Neutiquam erro. |
11-02-2011, 03:34 AM
#1367 | |
Oddometer: 1,877
Shop class was very beneficial to me and even 30 some years later I'm still using skills and techniques I learned there.
Neutiquam erro. |
11-02-2011, 09:10 AM
#1368 |
Pepperfool
Oddometer: 2,573
I think the Zinc worry is not applicable to washer drums.
I tried to find evidence of Galvi being used for this purpose (searching the net) and could not. I also never have seen either. It makes sense as left wet Zinc will produce a surface oxide which would stain clothes and be rough as well. I did find this and similar: There are 3 different types of materials used in washer tub construction.
Old enough to know better.... Young enough to try it again |
11-03-2011, 08:30 PM
#1369 | |
Family Dude
Oddometer: 805
I bought an old Atlas/Craftsman 12x36 lathe, but wanted a proper stand. ![]() ![]() ![]() ![]() ![]() ![]() I even used the lathe to make things! My learning curve is still pretty steep, but these are in my SL's engine and working well. Timing chain tensioner pulley, out of nylatron GSM (upper right). Made the new pin at lower right too: ![]() Idler gear bushing: ![]() They ain't much, but I have to start somewhere... |
11-03-2011, 09:29 PM
#1370 | |
Oddometer: 1,708
Awesome! A trifecta welding, carpentry and machining.
04 250 RFS 99 640 ADV 13 650 Terra |
11-03-2011, 11:29 PM
#1371 |
Oddometer: 467
thats one tool i really wish i had.....
now what is that lil green/teal beasty ast first i thought it was a morris but the lines arnt right..definatly a mini/micro |
11-04-2011, 10:45 AM
#1373 |
Anatomically Correct
Oddometer: 2,493
and there I was, scratching my head, wondering HOW you managed to weld up all those 1 by 1 lengths of wood . . . . . . . ;-}
Searching for the immaculate contraption |
11-04-2011, 10:49 AM
#1374 | |
Sleep, Wrench, Ride
Oddometer: 4,445
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 |
11-04-2011, 11:48 AM
#1375 |
Squatter
Oddometer: 349
11-04-2011, 11:49 AM
#1376 |
Oddometer: 467
ahh fiat ...must be an odd year or just an odd angle on that nose...nice to see im not the only one with a 4 wheeled thumper of sorts
11-04-2011, 08:06 PM
#1377 |
will think for food
Oddometer: 4,525
11-04-2011, 08:12 PM
#1378 |
Oddometer: 1,463
11-04-2011, 09:43 PM
#1379 | |
will think for food
Oddometer: 4,525
It's just a traditional saddle stitch. Mark out the spacing for the stitches, then use this.............................. ![]() .........diamond bladed awl to make the holes. (It's steel, "diamond" refers to the shape)..................... ![]() ...........and stitch it using waxed thread (traditionally linen, now mostly nylon)................ ![]() ................with two harness needles, one on either end. Apart from the pictured tools, all you need is a stitch marking wheel and some sort of clamp to hold the item while you stitch it. It's slow, but not hard to get a reasonable result. I'm a bit out of practice.....you can see my "reverse side" stitching is not as neat as it could be. I reckon there'd be plenty of tutorials on the net. |
11-06-2011, 02:06 PM
#1380 | |
fire and gas
Oddometer: 11,709
It's good for everyone to make their own choices regarding exposure and personal limits and I don't want to convince anyone of anything. This is outside my scope and apparently a non-issue in this case but it does seem like it might merit mention in this context. Just for the record I wasn't making it up; I have a professional acquaintance that did some cut and weld work on street lighting poles and as a result he's been sporting someone else's lungs for the last few years and has an odd yellowish pallor that would definitely be hard to fake. Make the best choice for you... but in this instance make it an informed one, please. Now the old joke about lung replacement surgery: The worst thing about it is that for the first few coughs it ain't your phlegm. uh, sorry... ![]()
You have no (expletive deleted) idea of what you are talking about. - santaferider |
| Thread Tools | |
