Thread Tools Rating: Thread Rating: 501 votes, 4.98 average. Display Modes
Old 11-10-2011, 03:14 PM   #1381
ridewestKTM
ridewestKTM's Avatar
Oddometer: 1,708
What is it?
here's something I made (I didn't design tho) I made some improvemets however.
My 950KTM makes me feel like a little kid again......because it's so tall!
ridewestKTM is offline   Reply With Quote
Old 11-10-2011, 03:29 PM   #1382
Bruincounselor
North Plains Drifter
Bruincounselor's Avatar
Oddometer: 380
Improved Red X
What do I win?
Bruin'
Bruincounselor is offline   Reply With Quote
Old 11-11-2011, 02:41 AM   #1383
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by Mr. Vintage View Post
Idler gear bushing:
Nice lathe table!
About chucking that gear, if the jaws aren't soft, or to save damage to soft jaws, lay some solid core solder between the part and the jaw. The solder will conform under the clamp pressure.
That trick works on mill vise jaws as well, or with with less than smooth-surfaced parts, a just-sawed surface for example. Can also be useful if the workpiece is flat/square only on the side facing the stationary jaw of the vice. In the last case, the solder can be used sort of like a shim.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 11-11-2011, 07:26 AM   #1384
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,350
Cut up aluminum cans or very thin copper sheet work great for that too- and probably a lot more consistent with thickness so your part will still be centered.
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 11-11-2011, 11:41 AM   #1385
ag_streak
Tiene Ruta Cuarenta?
ag_streak's Avatar
Oddometer: 3,198
Mr. Vintage, that is one damn fine job on the lathe table! Bravo!!
2013 Triumph Tiger 800, 2012 Suzuki DR650, 2006 Suzuki V-strom Sidecar Rig
ag_streak is online now   Reply With Quote
Old 11-11-2011, 01:29 PM   #1386
Mr. Vintage
Family Dude
Mr. Vintage's Avatar
Oddometer: 867
Originally Posted by Poolside View Post
Nice lathe table!
About chucking that gear, if the jaws aren't soft, or to save damage to soft jaws, lay some solid core solder between the part and the jaw....
Thank you both - very good info! This is the kind of knowledge I lack. I even tried to find someplace local to take some machining classes, but the schools here are better suited to getting a PHD than anything... well, useful.
Thank you for the compliment!
- Jeff (Mr. Vintage) -
Quota, SL350, MW250, MT250, CT90
Mr. Vintage is offline   Reply With Quote
Old 11-11-2011, 06:02 PM   #1387
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Nice! Definitely the sheet material would work better in a multi-jaw chuck. Where gap-filling is less the issue, and centering is a primary objective.
Old 11-11-2011, 08:40 PM   #1388
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,350
y'all are welcome. Glad the two years I invested studying manufacturing engineering were useful to SOMEBODY...
-Charles De Mar.
Old 11-12-2011, 04:37 PM   #1389
SingleTrackJeff
Lurker and Hangaround
SingleTrackJeff's Avatar
Oddometer: 696
Fire pit burner
Looking for help on a project
I have a fire pit I need a burner for I have found them on line for about 200 bucks but being cheep I would rather spend the real money on motorcycle stuff.
I need to make the burner ring to be covered with the fire glass we already have about an inch or so of it.
My thoughts are to make a use 3/4" soft copper tubing to make the circle and sweet ridge copper to adapt to the propane line.
Questions: Will the copper survive under the glass from the heat as I think the flame will be on top of the glass.
Do I need to have any air coming into the line before the burner or will it get enough air in the glass.
Thanks for the help
SingleTrackJeff is offline   Reply With Quote
Old 11-13-2011, 01:50 AM   #1390
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
A bbq-style gas/air venturi burner won't provide much flame height.
Drill some 1/8" holes in a square (4-90 fittings), or hexagon (8-45 fittings), or a big 'H' (2-tees and 4-caps), made from the right length galvanized pipe nipples. You'll have to fit a tee in there somewhere for the gas supply. Experiment, the pipe is cheap enough at the hardware store. The holes do not need to be directly on top of the pipe, they can be at 10 and 2 o'clock if you like.
If the regulator doesn't have enough flow, see if you can adjust the pressure. The adjustment might be under a swaged metal or plastic cap that needs to be drilled out. Like the idle air screw on an emissions carb.
I'm thinking that if the fire pit is enclosed with glass then it may have combustion air intake on the bottom, or low around the perimeter. Get some stone fire logs and you should be good to go.
Be sure you can get to all the holes on the pipe for lighting. The flame will not spread like it does on a burner.
Old 11-13-2011, 04:29 AM   #1391
HamboneSlim
ಠ_ಠ
HamboneSlim's Avatar
Oddometer: 4,587
...an old Atlas/Craftsman 12x36 lathe...
Where's the leadscrew?
Nice job on the table! I just picked up an older (late '40's) 12x54 version of this lathe and need to build a base for it. I took the lathe apart to clean, inspect for wear, and repaint. Gonna try and get it back together today.
Yours looks like it is in really nice shape, aside from the missing leadscrew.
Goddamn, well I declare,
Have you seen the like?
Their walls are built of cannonballs,
Their motto is, "Don't tread on me."
HamboneSlim is offline   Reply With Quote
Old 11-13-2011, 09:42 PM   #1392
Mr. Vintage
Family Dude
Oddometer: 867
It is on now, I just hadn't put it on yet in the picture. Someone had crashed the thing and I ended up making a new leadscrew bearing carrier for the back of the carriage. Still need some gears to make the power cross-feed work but at least I have power feed now.
I saw your lathe in the machine tool thread - basically the same deal as mine short of the color, no?
Old 11-14-2011, 11:41 PM   #1393
woopwoop
will think for food
woopwoop's Avatar
Oddometer: 5,507
I made this for a recent local small town art competition
Sheet float glass, kiln fused with encased vitreous enamels. Surface detail carved via masking and sand blasting. Steel stand.
Just missed the prize
YOG1C
woopwoop is offline   Reply With Quote
Old 11-14-2011, 11:50 PM   #1394
Russ
Russ's Avatar
Oddometer: 16,906
Very zen WW I like
Russ is offline   Reply With Quote
Old 11-15-2011, 12:43 AM   #1395
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,394
super cool
jesusgatos is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 05:08 AM.
