05-02-2012, 02:52 AM
#1651 |
Snowflakes are cold...
Oddometer: 569
![]() ![]() I was so smart that i uppdated my phone, and lost all of my pictures. Tought i had one of the dash so i could check the kevlar coating as i cant recall if it was there...? |
05-02-2012, 03:02 AM
#1652 | |
Oddometer: 569
Exept of the brake adapter, so the kalipter can fit the OEM rotor/wheel. I'll just have to figure out wich adapter that actually fitt's the Factory's? |
05-02-2012, 03:11 AM
#1653 |
Oddometer: 569
My intention is to use the axle clamps that allready is on the Factory's, as the spacer's shouldn't be much of an issue.
It's more of an challenge to line up the brake kalipter. If i have an adapter that is close enough i could modifie them, but i don't have any knowlegde or equipment to make an adapter from scratch. |
05-02-2012, 07:18 AM
#1654 | |
"Moto Porn"ographer
Oddometer: 3,800
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE www.sibirskyextreme.com |
05-02-2012, 10:32 AM
#1655 |
Three Wheel Maniac
Oddometer: 401
Holy Klono,
Have been busy and almost out of internet for a few days and I find a lot to read and to answer to. Will try to do that later tonight. Bit worn out at the moment. Nice to see some first pics of your setup now Frode. I'm in for more. I have to reread your question on the brake caliper bracket, but maybe I have an instant solution
Three Wheel Fever forever Xtankteam™ Proud sponsor of the Sibirsky Extreme Project |
05-02-2012, 01:41 PM
#1656 |
Three Wheel Maniac
Oddometer: 401
Hi Geir, not too busy at work then?
You missed an "o"
05-02-2012, 02:27 PM
#1657 |
Three Wheel Maniac
Oddometer: 401
On the rammount balls:
I have designed 2 kinds: - 1 which accepts a M8 allen bolt of which the stem can also act as a replacement for a M8 allen head, to use it in a handlebarclamp f.i. - 1 which accepts a M10 allen bolt and which can be used f.i with an M10x1,25 allen bolt,(though I succeeded, these proved hard to find in a stainless or plated version as I discovered to my surprise ) for use in the threaded holes for the mirrors of the XC. These anodised balls prove to be hard wearing, but a bit slippery. So some I sold a bunch of them to a shop where they build up adventure and special bikes (Hyper-Bas
Three Wheel Fever forever Xtankteam™ Proud sponsor of the Sibirsky Extreme Project Erik RS screwed with this post 05-02-2012 at 02:59 PM |
05-02-2012, 02:46 PM
#1658 | |
Three Wheel Maniac
Oddometer: 401
. So better not fall toomuch
05-02-2012, 02:54 PM
#1659 |
Three Wheel Maniac
Oddometer: 401
@ Don't shoot me!!!
We did a Marzocchi transplant into an XCo once, with the original brake caliper installed and (if I recall well) the original XC hub and disc. I designed an adapter with spacers therefore. I might have even one on the shelf, if not I'm quite positive there is a drawing (no energy to look now, sorry) in my workshop computer. If that is what you're looking for?
Three Wheel Fever forever Xtankteam™ Proud sponsor of the Sibirsky Extreme Project Erik RS screwed with this post 05-02-2012 at 03:01 PM |
05-02-2012, 03:04 PM
#1660 | |
Oddometer: 569
05-02-2012, 03:34 PM
#1661 | |
Planning.....
Oddometer: 5,242
Ride safe enough.... |
05-02-2012, 03:38 PM
#1662 | |
Oddometer: 65
http://advrider.com/forums/showthrea...d#post18463184 Liquid electical tape and 220 grit sandpaper.
DON'T GET IT TWISTED --ITS DUAL SPORT! ![]() NOT DUEL SPORT!
05-02-2012, 03:42 PM
#1663 |
Three Wheel Maniac
Oddometer: 401
@ Don't shoot me!!!
If I think of it, I will look into it tomorrow. If you don't hear from me, poke me by mail .I'm overly busy at the moment with the moving of my workshop to a larger premises By the way, talking about dashboards. Walter's enjoying himself on his private project in my workshop, led to the design of a basic adventure dashboard for the replica KTM690 fairing setup. Though handmade, this one comes directly from the digital design I did, so I think it can be seen as a proper pre-production model: ![]() A possible setup is what we did on the bikes of 2 crazy Norwegians last week. Mr. EtronX was in such a hurry leaving our place to start his adventure that I didn't even have time to take some pictures, but I re-recreated the situation (before the imminent placing of switches, sockets a.s.o) in my drawing programme ![]() Thanks Walter and Geir for being guinea pigs
05-02-2012, 07:35 PM
#1664 | |
Ross
Oddometer: 266
Tbone: Did you fix the stalling?
I had the same problem with my x-challange. I finally figured out that it was water in the fuel. The water was sucked up the tank vent tube following a long river crossing. Easy to clear: (this works best if the fuel has had a few minutes to settle) 1-disconnect the feed hose from the tank. (That goes to the injector) 2- push on a suitable hose and point the other end into a bottle. 3- Turn on the ignition and let it pump. Turn ignition off and back on. repeat a few times. 4- have a look in the bottle.The water will sit at the bottom of the petrol. (I had about 1/2 inch at the bottom of the bottle) 5- empty bottle and repeat until no water found. Good luck. |
05-02-2012, 07:57 PM
#1665 |
Oddometer: 414
Acerbis Neoprene Fork Socks For Sale |
