Old 05-20-2012, 05:08 PM   #1711
Aquatic
Aquatic's Avatar
Oddometer: 1,701
Bump
Originally Posted by Colebatch View Post
Pics as promised - taken in the Ukraine - on their maiden voyage to Magadan
What is happening with the oil filter cover?
Aquatic is online now   Reply With Quote
Old 05-20-2012, 08:11 PM   #1712
Kainic
Almost there
Kainic's Avatar
Oddometer: 391
Fern ... I have two straps around my bags, one vertical and one horizontal ... strapping them to the rack... with them all strapped up there is almost no weight on the overseat straps actually.
Vertically I have threaded the strap through the loops for the security cable. Horizontally I have threaded the straps through the eyelets / holes between the side pockets and the bags ... will send a photo later today. Using that system the bags are solid and tight against the rack
Colebatch - What kind of straps are you using?
Kainic is offline   Reply With Quote
Old 05-21-2012, 12:10 AM   #1713
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 780
Magadan Bag Size
Any further news/developments on the size of the Magadan bags regarding what they are size wise, compared to what they should be?
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is online now   Reply With Quote
Old 05-21-2012, 04:02 PM   #1714
Chris S
Oddometer: 194
The AS website currently says dims are:
35 x 19 x 48cm
Which comes in at just under 32L.
The middle figure matches the tape measure photo above, more or less, and the height must vary by a few inches depending on how much you roll down (which is the good thing with roll tops).
On WC's bike it looks like around half a metre tall to me.
Plus the outside pockets add 2-3 litres.
Looking forward to having a closer look myself when the June batch comes in.
Chris S screwed with this post 05-21-2012 at 11:27 PM Reason: 35
Chris S is offline   Reply With Quote
Old 05-21-2012, 11:18 PM   #1715
5er
5er's Avatar
Oddometer: 65
new information about dimension on AS WEB site: 48cm x35cmx19cm: http://www.adventure-spec.com/defaul...-panniers.html
5er is offline   Reply With Quote
Old 05-22-2012, 02:39 AM   #1716
_cy_
Oddometer: 6,437
thought these bags were priced too high until after a bit of digging about how these bags are built with kevlar, and all sorts of features.
Having tried pretty much everything out there and still frustrated by the shortage of features, I decided to build a set for myself. I wanted bags that were capable of carrying a good 35 litres of stuff. The bigger the bags are, the more weight you can get down low, and the smaller your back bag needs to be. I wanted bags that could keep your stuff dry. In the end I decided a removeable waterproof dry bag liner was the best solution as you can take your dry stuff out in a 5 second grab - and take it into your tent - or accommodation - without having to rummage thru the bag in the rain, or take a wet muddy outer bag into a tent or hotel.
Then the bags had to be lockable - a few ideas came and went before I decided to use PacSafe WrapSafe cables. The advantage of these cables is that you can not only lock the bags shut, but you can lock the bags to your luggage rack - by routing the cable through it. The bags have loops front and back for routing the cable and holding it to the bag. So by doing that we had the first motorcycle soft bags that actually offer some sort of security and lockability.
But to complete the security picture we wanted to make the bags slash proof. Not much point locking the bags shut if someone can just slice them open in 2 seconds. Again everything including internal wire mesh was considered, before deciding to sandwich a layer of Kevlar / Twaron in the bag construction. Its extremely difficult to cut and is used in stab proof and bullet proof vests. This puncture restance further adds to the durability of the bags.
Old 05-23-2012, 02:07 PM   #1717
SCflyer
SCflyer's Avatar
Oddometer: 1,657
Back in stock at 11/06/2012
Do the Brits swap the month and day or would this be correct (from the site for the bags) that they're gone until November? June 11th would be much better...
"Not all those who wander are lost" J.R.R. Tolkien
SCflyer is offline   Reply With Quote
Old 05-23-2012, 02:47 PM   #1718
Don't shoot me!!!
Snowflakes are cold...
Don't shoot me!!!'s Avatar
Oddometer: 569
I assume no normal people have problems like this on their weekend trips?
Murphys law are really written for me
Don't shoot me!!! is offline   Reply With Quote
Old 05-23-2012, 03:35 PM   #1719
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 190
This side of the pond that'll mean 11-June
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 05-23-2012, 04:57 PM   #1720
flying.moto
Earthbound Misfit, I
flying.moto's Avatar
Oddometer: 222
Originally Posted by Aquatic View Post
Bump
Yeah! I would like to know too!
flying.moto is offline   Reply With Quote
Old 05-23-2012, 05:56 PM   #1721
flying.moto
Oddometer: 222
My friend's DRZ exploded its FMF in a very similar fashion. We concluded it happens due to lack of frequent repacking. Thats mainly why i still ride with my stock pipe while saving for that fancy euro pipe Walter is rolling around with. My other friend who used to build his own thumper pipes said thumpers pulse too hard for an empty closed pipe so once packing is gone this will happen eventually.
Old 05-23-2012, 07:22 PM   #1722
Turps
Oddometer: 19
Some country's have no idea how to write dates. The rest of the world reads it as 11th june.
Turps is offline   Reply With Quote
Old 05-23-2012, 09:54 PM   #1723
The Jester
The Jester's Avatar
Oddometer: 866
If the construction of that can is the same as my freeride you might be able to save it. Drill the rivets out and remove the end cap. If there is a perforated tube going through the centre of the exhaust, and the damage is limited to the rear inch or so as it appears, you could try cutting the damaged section off and trimming the tube by same amount. Repack the can with loose fill packing and rivet the end cap back in place.
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 05-25-2012, 05:06 AM   #1724
Colebatch OP
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,991
Actually it would be the rest of the entire world that puts dates in order of size .... day/month/year ...
I mean you dont tell time by hours:seconds:minutes ... do you?
The question is why did you guys mess it up?
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 05-25-2012, 05:12 AM   #1725
Colebatch OP
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,991
Wow ... yours did that too??? After about the 5th time, I gave up trying to fix my Remus
Times are GMT -7.   It's 05:45 PM.
