Go Back   ADVrider > Bikes > Battle Scooters
Old 11-19-2009, 04:17 PM   #1
pjheckel OP
Oddometer: 65
Scooter rear tire life? How many miles are you getting?
OK so I bought some pirelli SL 26 tires and put them on my Helix and my CH250, both lasted under 1000 miles, ouch! That's with normal commuting and aggressive weekend riding, no skidding or anything crazy. I just wanna ride my scooter, not change tires or work on it! So what is everybody else running and how many miles are you getting? BTW I just replaced the pirelli with a IRC MB99, will see how long it lasts and post the results. Happy scootering!
pjheckel is offline   Reply With Quote
Old 11-19-2009, 07:55 PM   #2
ernest t bass
ernest t bass's Avatar
Oddometer: 443
You must be really flying.
Burning up a tire in 1000 miles? Wow.
With a CH250 I'd expect at least 3500-4000 out of a rear tire.
Fronts usually get cupped before they wear out.
I once put 3.50-10 tires on my CH250 - Hey, I had 2 of them from a junked 150 -
Those even lasted 2000 or so.
If A Duck Stands Still, You Can Catch Him By The Bill.
ernest t bass is offline   Reply With Quote
Old 11-19-2009, 08:10 PM   #3
Cheshire
Anachronistic rideby
Oddometer: 266
I had a Pirelli SL-26 100/90-10 as my 2nd rear tire. Lasted me about 3,000 miles, my normal somewhat-aggressive riding with cargo on the rear rack most of the time. Either you had the bad luck to get a botch tire or...I don't know. 1,000 miles is just way too short of a lifespan!!
Cheshire is offline   Reply With Quote
Old 11-20-2009, 02:36 AM   #4
Coopdway
Curiouser
Coopdway's Avatar
Oddometer: 711
I got my '04 Helix with just over 3K miles on a year ago with what I'm sure was the OEM Bridgestone. I put a Bopper on at 5100 and while in AR this past summer, stuck a new OEM Bridgestone on again at 9800. I would have made it part way home to MN, but didn't think I'd make it all the way. There's over 4K on this rear and I'm sure it will make 5K like the first one.
I don't run them until "Cord" and with my longer rides, seldom get maximum use out of tires because I like changing them at home.
Doug
Frontenac, MN
Chauncey likes to watch.......I like to ride
Coop's Corner
Coopdway is online now   Reply With Quote
Old 11-20-2009, 02:44 AM   #5
farqhuar
Lone Wolf
farqhuar's Avatar
Oddometer: 1,266
Getting 15,000 miles out of the rears on my Burgman 650 and double that on the fronts.
.... and I'm talking under all conditions - round town commuting, freeway, twisties, gravel and sand...
WTF you doing to get so little?
farqhuar is offline   Reply With Quote
Old 11-20-2009, 05:23 AM   #6
tastroman
Oddometer: 1,762
I'm getting around 4,000 miles out of my rear tire on a Daelim s-2 250. About double that on the front.
I used to get over 3,000 out of cheap Chen Chins on my old Honda Elite 250 rear. If you are only getting 1,000 something is wrong or you kid is doing burnouts on it when you are not home.
2007 Daelim S-2 250, 2013 Piaggio BV350
tastroman is offline   Reply With Quote
Old 11-20-2009, 04:28 PM   #7
windburn
Oddometer: 1,194
The Silverwing got new rear shoe at 11,000 and the front has 15,000 and still has good tread they are Bridgestone stock that have been replaced with the same. The front tire is 14' the rear is 13". The front tire ware seems it will go a long way.
I still had tread on the rear when I changed it but I was headed on a 6 week trip so I change it out before leaving.
There is a ware bar on your tire that will show when the tread has worn to the suggested replacement look for an arrow in a circle on the side of your tire then look in the tread and you will see a recessed rubber bar between the tread if you have ware down to the bar you have reached the recommended life of the tire.
windburn screwed with this post 11-20-2009 at 04:37 PM
windburn is offline   Reply With Quote
Old 11-21-2009, 06:10 PM   #8
brockster
Despair & Repair Garage
brockster's Avatar
Oddometer: 2,042
Originally Posted by pjheckel
OK, so I bought some pirelli SL 26 tires and put them on my Helix and my CH250, both lasted under 1000 miles, ouch!
Is this you???
2001 HD XL1200S
1977 Vespa + 1985 Honda Elite
CB550K project.
Man whoever came up with Ronald McDonald was dropping some serious acid.
." - SpoonKiller / tiotalruckus.com
brockster is offline   Reply With Quote
Old 11-21-2009, 06:20 PM   #9
pjheckel OP
Oddometer: 65
Ha ha! I weigh far less than my scooter. That guy is probably riding a scooter because he couldn't find a car that he could fit in!
Old 11-22-2009, 12:06 AM   #10
Motovista
Parts is Parts
Motovista's Avatar
Oddometer: 507
I've got a Kymco Vitality 4T, one of the last real Kymco small displacement scooters, not that Chinese crap they sell now, and it's got about 14000 miles on the original tires.
There is no good reason to put sport tires on a scooter, unless you are seriously racing. The bodywork will scrape long before the tires let go, if you know how to ride.
Motovista is offline   Reply With Quote
Old 11-23-2009, 05:55 AM   #11
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,155
Got a pair of Sava MC16 tires on my Peugeot scoot, put on by previous
owner about 6000 miles ago. Front looks like new, rear is showing signs
of wear, probably partly my fault.. sliding the rear end in the turns all
the time, SM style .. but I'm sure it'll do another 4k if I behave.
But it's a lot less weight to scoot around then your basic Helix.. being
only 200lbs and not more then 5hp.
I remember seeing over 20k miles on OEM Huthinson tires on these
Peugeot scoots (worked at a workshop), they _never_ wear out.
That said, I got 15k miles and still counting on my 650R's OEM
Bridgestones..
EDIT:
Get these for NoWearAtAll, but similiar on grip.. The Hutchinson Funzy!
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Old 11-25-2009, 04:14 AM   #12
Photog
Charismatic Megafauna
Photog's Avatar
Oddometer: 46,308
The MP3-250 loves to eat rear tires. Anywhere from 1500 to 3500 miles out of those. Not complaining, though...the grin factor is too high on that bike.
Everything else I have - Stella, Super 9 -- seems to last forever. I haven't bothered keeping track of tire mileage on 'em.
Only an XR1200 owner knows why Cthulhu hangs its head out a car window.
Like I like. Yep.
Photog is offline   Reply With Quote
Old 12-02-2009, 04:53 PM   #13
techguy
Scooter Trash
techguy's Avatar
Oddometer: 845
I bought my Kymco with 16,000 KM on the clock and it is now over 27,000 KM. I still have the same front and I changed the rear at about 22,000. I may have changed the factory original for all I know. The front is getting close to the wear bars and I am a fair load to haul.
Kenda front and rear. I put on a Shinko in the back. I read many good reviews from the racer boy sites and they were cost effective.
techguy is offline   Reply With Quote
Old 12-03-2009, 08:03 AM   #14
fish3006
Oddometer: 367
7,500 on the kenda rear on my people s250. wife's s250 has the same mileage; hers looks like it can 7,500 more. must be different driving styles ... :)
fish3006 is offline   Reply With Quote
Old 12-03-2009, 12:51 PM   #15
Cheshire
Oddometer: 266
I'm betting it also has to do with tire diameter. Less rubber to space those miles across, so they wear faster for the same distance travelled as, say, a 16" diameter tire.
Times are GMT -7.   It's 07:46 AM.
