Thread Tools Rating: Thread Rating: 29 votes, 5.00 average. Display Modes
Old 01-16-2010, 11:56 PM   #106
Bake OP
adventurer
Bake's Avatar
Oddometer: 10,519
Originally Posted by RonS
This is one of the coolest threads I've seen in a long time. I've got a 14-40 gear head lathe (Chinese import), a smaller gear head mill with 24x9x5 of travel (x, y, z also Chinese import), a 7 x 12 Wilton horizontal band saw and a nice Miller 200 DX AC/DC Tig/Stick welder plus some Oxy Acetylene stuff and various other tooling. I need a good sheet metal brake, shear and roller and I think I’m set to do nearly everything. I don't know how to use any of it very well but I'm learning very slowly. I’m also learning that everything I own is to small to do anything of any significance. You guys who do this every day are some lucky fuckers. Then again the grass always seems greener just past the monitor where the compiler errors are screaming at me to be addressed…
Bake is offline   Reply With Quote
Old 01-17-2010, 09:52 AM   #107
dagwood
dagwood's Avatar
Oddometer: 35,427
Originally Posted by Mr. Cob
Howdy dagwood,
Yes a small benchtop would be just perfect for my needs, I would like to have at least 18" bed length but anything up to 36" would fit into my garage. Anything larger then 36" bed length would just take up to much room, I have so much junk scattered around now I can hardly walk from one end of the garage to the other.
man the Seattle CL is full a gems.
http://seattle.craigslist.org/see/tls/1555361231.html
same lathe/ dealer with more info. sorta sounds weird. but that is a very nice example. weird that he would break it up like that.
http://seattle.craigslist.org/see/tls/1548990029.html
dagwood is offline   Reply With Quote
Old 01-18-2010, 12:09 AM   #108
RonS
Out there...
RonS's Avatar
Oddometer: 20,070
Originally Posted by Bake
Yeah, I've rented most of the lathe and milling videos at smartflix (http://smartflix.com/store/category/115/Metalworking). Very helpful. I need to rent the Darrell Holland series at some point. I even rented stuff that I didn't think I'd be doing but that looked interesting. They have good videos on the English Wheel, Shrinking, forming and a bunch of other stuff.
RonS is offline   Reply With Quote
Old 01-18-2010, 06:42 AM   #109
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,602
Here's my ball and chain.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is offline   Reply With Quote
Old 01-18-2010, 10:26 AM   #110
Mr. Vintage
Family Dude
Mr. Vintage's Avatar
Oddometer: 860
Cool thread, and well timed - I just got this from Santa (the lathe, not the Fiat):
Atlas-Craftsman 12x36. Now I need to figure out how to use it...
- Jeff (Mr. Vintage) -
Quota, SL350, MW250, MT250, CT90
Mr. Vintage is offline   Reply With Quote
Old 01-18-2010, 11:14 AM   #111
Ironhead
But Itsa Dry Heat
Ironhead's Avatar
Oddometer: 772
Very cool thread,
I love old machines and tools.
I have a Hall valve facing machine from the 30's that works like a champ.
I also picked up a Southbend 9" modelA lathe that I think was made in the 40s, ( it has a War Department tag on it ) it has the motor mounted high and behind the head stock and uses a V-belt from the motor to an intermediate shaft, then a flat belt to the spindle.
Should be a fun little lathe when I find a motor for it.
Thanks for the thread and pictures.
"I wanta be the man that my dog thinks I am"
" Lord grant me patience, because if you grant me strength, I'll need bail money and a lawyer to go along with it"
Ironhead is offline   Reply With Quote
Old 01-18-2010, 11:44 AM   #112
Chobro
spinning the wheel
Chobro's Avatar
Oddometer: 787
Nice. What is the linkage for on the fwd./reverse switch?
-Chobro
Chobro is offline   Reply With Quote
Old 01-18-2010, 12:23 PM   #113
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Can I play with it?
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 01-19-2010, 03:56 AM   #114
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,185
Hmm dagwood am i seeing Hydraulic parts there
I know the Machinists i welded for didn't like the Aluminium-Bronze MIG wire i hate the stuff Fumes i normally used the standard "bronze' rod to oxy it onto the steel piston's
i was always going to do Machining.....time...money....every bastard doesn't want me to stop welding
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Old 01-19-2010, 05:13 AM   #115
dagwood
dagwood's Avatar
Oddometer: 35,427
don't like welding (for work) but don't mind it for G work,
ended up welding hard wire all days sat on a quick change and my nose is all fucked up dry and sore now.
I don't know how you guys can do that day in and day out. and the flash burn. gad. i'm glad it's been awhile since I've done that. cheap hoods suck.
and yes . lots a Hydraulics. heavy equipment repair is a big part of it as is big presses and shears.
Old 01-19-2010, 05:14 AM   #116
dagwood
dagwood's Avatar
Oddometer: 35,427
Nice.
Damn; just a bit OCD...
Old 01-19-2010, 06:23 AM   #117
theMISSIONARY
Oddometer: 2,185
no one said i like it....gets old real quick(especially fixing mining machines and crushers) trying to get out of it but well its not happening at the moment
I've worked on and off at Delta Hydraulics for years..... if its to go in a cylinder i've just about welded it all rather be Machining Nice thread
Old 01-19-2010, 06:46 AM   #118
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,223
I envy your power feed on the knee.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 01-19-2010, 06:50 AM   #119
mmitchell57
Vulcan Halfbreed
mmitchell57's Avatar
Oddometer: 2,193
{...picture snipped..}
Looks like you have quite a bit going on there to keep with! Of course, I would have no idea on how to operate such a machine. I'd probably loose my sanctity along with a couple fingers if I tried and didn't have some supervision.
Projects - www.Goomra.com
1969 CB350 - Restoration Project
1962 Ford Fairlane 500 - Restoration / DD project
mmitchell57 is offline   Reply With Quote
Old 01-19-2010, 06:52 AM   #120
mmitchell57
Vulcan Halfbreed
Oddometer: 2,193
Warning! - The following question may seem ignorant, but it is honestly serious....
I've been seeing these left and right in this thread. What could one expect to make with such a device? I've seen them on TV as well, but never really understood the functionally.
Also, do you have a link to pictures of the Fiat? That thing looks cool!
Thread Tools
Times are GMT -7.   It's 09:41 AM.
