Old 02-23-2012, 12:09 PM   #106
istronglydislikeants
Oddometer: 2
OK, here she is, I hope I'm doing the photo thing right.. PO put clipons, round headlight, and the front brake master cyl/lever assembly is from a rd400 or something and has the brake light wires cut :X, cut hole in airbox to put foam filters on.. Got some work to do but I'd say its a pretty good start :)
istronglydislikeants is offline   Reply With Quote
Old 02-24-2012, 09:07 AM   #107
fleshpiston OP
fleshpiston's Avatar
Oddometer: 603
Nice!
I wouldn't have parked on that ant hill though
SRX600
SRX250
SR500
KLR650
fleshpiston is online now   Reply With Quote
Old 02-24-2012, 08:01 PM   #108
Brooklyn88
Oddometer: 17
Hey guys, does anyone know where to get a replacement jet for the secondary on the carb? I can find replacement pilot & main jets for the primary, but nowhere are replacement secondary jets still available. I tried boats.net & ronayers both said it was discontinued. Any leads would be awesome!
Brooklyn88 is offline   Reply With Quote
Old 02-25-2012, 07:24 AM   #109
fleshpiston OP
Oddometer: 603
Brooklyn-
You might want to ask over in "thumpers" in the XT350 thread. I think some guys were getting their jets from Kedo in Germany?
http://www.kedo.de/
The site is difficult to navigate so I didn't spend a lot of time looking.
Good luck.
SRX600
SRX250
SR500
KLR650
Old 02-27-2012, 10:21 AM   #110
Brooklyn88
Oddometer: 17
Thanks, I asked over in the othe thread also, and the also recommended Kedo. I sent them an email and got a response this morning:
Hi Jon,
sorry, but since the SRX250 has never been sold in Germany we do not stock spare parts for this motorcycle.
BTW: 30X-14343-40 is ( as far as we know ) no longer available from Yamaha.
Best regards
Carsten Schlüter
KEDO-Team
hmmm, I may be SOL on this one, unless anyone has another lead or substitute?
Old 02-28-2012, 05:36 AM   #111
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,145
You can try Sudco. give em a call. http://www.sudco.com/ 310-637-8330.
Disclaimer... I have no affiliation with this supplier. Just tryin to help a brother out.
fastdadio is offline   Reply With Quote
Old 02-28-2012, 08:32 AM   #112
hotwheels
Oddometer: 57
SRX250t jetting solution
I've been waiting a long time for this issue to surface, read and enjoy. There are NO jets available for the srx250t, the solution, drill em out. Here's how to make this bike run like it should. Drill the idle jet with a number 78 drill, drill the primary main jet with a number 54 drill, leave the secondary main jet stock. Use washers the move the needles up, primary up .070", secondary up .105", you may need to change this to suite your conditions. I see a different muffler on your wife's bike so there may need to be some adjustment to these numbers. Adjust the linkage between the two carbs so there is no progression, ie they both open at once. It's easy to see, just study the linkage and use the adjustment screw. The bike will now pull a one tooth (15t) larger counter shaft sprocket (Sunstar p/n 34615 from Parts Unlimited) with ease. I will gladly driil the jets for you, just email me and we can arrange.
hotwheels is offline   Reply With Quote
Old 02-28-2012, 03:37 PM   #113
Brooklyn88
Oddometer: 17
I was able to buy a new #125 primary main jet (#122 stock) and a #42 pilot jet (#35 stock). Are these too big/too small? What are your thoughts?
Old 02-29-2012, 06:58 AM   #114
fleshpiston OP
Oddometer: 603
I'm running the #42 pilot (stock XT350) and it helps the bike warm up quicker. Mix screw is roughly 2 1/2 turns out. Other than that everything else is stock. Stock airbox with universal cut-to-fit UNI filter and stock exhaust.
The bike runs well enough when fully warm, but I still have a little stumble right off idle. One of the carb to airbox boots is hard and crusty so I might have a leak there. Since that part is also deemed OBSOLETE by Yamaha I'll try sealing with a little silicone.
Brooklyn- What other changes have you made? Pipe? Filters?
SRX600
SRX250
SR500
KLR650
Old 02-29-2012, 10:21 AM   #115
Brooklyn88
Oddometer: 17
The rest of the bike is stock right now. I'd like to keep it as stock where I can. Yea, I got the 42 pilot jet from the stock xt350 What main jet do you run? How did you remove the brass plug over the pilot screw?
Old 02-29-2012, 10:36 AM   #116
fleshpiston OP
Oddometer: 603
I'm running stock mains.
Carefully drill the brass plug, be ready to pull up once you're through or you could damage the screw underneath! Then thread a self tapping screw into the plug and pull with vice grips.
SRX600
SRX250
SR500
KLR650
Old 03-02-2012, 02:23 PM   #117
hdscarbro
Oddometer: 28
The windscreen on my SRX250 was cracked, so I made a new one. Here are photos along with comments on the process that I used.
hdscarbro is offline   Reply With Quote
Old 03-05-2012, 10:04 AM   #118
fleshpiston OP
Oddometer: 603
^ ^ ^ ^ Very nice work!
SRX600
SRX250
SR500
KLR650
Old 03-10-2012, 11:10 AM   #119
Brooklyn88
Oddometer: 17
I put the carb back together with new diaphragms, larger main & pilot jets, and new float bushing & needle. It still runs poorly with choke off, will die often when you give it throttle. I found airleaks at the choke plunger and one of the intake boots. I ordered a new plunger & boots online, HOPEFULLY this will fix the issues. I also still need to tweak the pilot screw.
FYI this guy's diaphragm fix perfectly on the SRX 250 carb:
http://jbmindustries.com/YDLS.html
I also bought my other parts from: http://www.boats.net/parts/search/Ya...50T/parts.html & http://www.ronayers.com/fiche/TypeID.../Model/SRX_250
Old 03-19-2012, 01:32 PM   #120
Brooklyn88
Oddometer: 17
Hey all, I ordered new carb boots & one of the boots has a vacuum line connection on it. What is this for?
Times are GMT -7.   It's 01:25 PM.
