Old 12-12-2009, 02:48 PM   #16
JEDI 2.0
Not From Star Wars
JEDI 2.0's Avatar
Oddometer: 81
If you modded an Elite 150 well enough, it'll do Elite 250 speeds.
Through lots of reading, i'm NOT 100% SURE ON THIS, I haven't yet tried it but I read GY6 performance parts of many kinds will work on the Elite----upgraded ECU (make sure you get the right clip style), clutch shoes/bells/torque & main springs, belts, variator rollers but NOT any of the other variator parts. Dr. Pulley slider weights should fit in the variator with no grease. Dellorto jets should work in the stock Elite carb, again not 100% sure but pretty sure they're the same style & size. .. There's nothing directly bolt-on available for exhaust but most 150cc 4-stroke exhausts can be made to fit.
There's some really good parts available for the Elite 250 and the Helix that are direct bolt-on or plug-&-play. With the Elite 150 you have to get a little more creative.
JEDI 2.0 is offline   Reply With Quote
Times are GMT -7.   It's 03:54 PM.
