Old 11-24-2009, 10:33 PM   #1
motolab OP
motolab's Avatar
Oddometer: 2,855
BST40 carb parts
Hello all,
I want to let you all know that I have these items (makes & models mentioned below) in stock in Redwood City, California and ready to ship the same day (if placed before 15:00 Pacific time), generally at below retail (retail shown in brackets):
584.31.037.000 Throttle Valve Guide, $25.60 ea. ($36.89), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4. Also fits Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '90-'15 Suzuki DR650, '89 GSX-R750RK and '91-'98 non-USA GSX-R1100 (not available separately from Aprilia, Cagiva, Husqvarna or Suzuki) -> for inspection guidelines see http://www.moto-lab.com/gallery/view?itemid=300 and http://www.moto-lab.com/gallery/view?itemid=298 (scroll down for descriptions and links. Click image for high res view)
584.31.021.689 Needle Jet 689 X-6, $12.11 ea. ($17.69), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4 -> for inspection guidelines see http://www.moto-lab.com/gallery/view?itemid=305 (scroll down for descriptions and links. Click image for high res view)
09494-00884 Needle Jet 782M Y-5, $26.87 ea. ($34.58), fits '96-'15 Suzuki DR650 -> for inspection guidelines see http://www.moto-lab.com/gallery/view?itemid=305 (Images are from a KTM, but the concepts are the same. Scroll down for descriptions and links. Click image for high res view)
09494-00754 Needle Jet 691 Y-2, $23.55 ea. ($30.20), fits '92-'95 Suzuki DR650 -> for inspection guidelines see http://www.moto-lab.com/gallery/view?itemid=305 (Images are from a KTM, but the concepts are the same. Scroll down for descriptions and links. Click image for high res view)
09494-00685 Needle Jet 642 X-9, $22.52 ea. ($37.66), fits European model '90-'96 Suzuki DR650. Also fits '95-'02 Aprilia Moto 6.5 (not available from Aprilia) -> for inspection guidelines see http://www.moto-lab.com/gallery/view?itemid=305 (Images are from a KTM, but the concepts are the same. Scroll down for descriptions and links. Click image for high res view)
8A00 80173 Needle Jet 784 Y-2, $29.38 ea. ($33.28), fits '96-'97 Cagiva Canyon 600, '97-'07 Cagiva Canyon 500 & '03-'04 Husqvarna SM610S (this item no longer available from Cagiva or Husqvarna).
584.31.035.000 Throttle Slide (w/two slide lift holes), $26.86 ea. ($38.69), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4. Also fits fits '96-'97 Cagiva Canyon 600, '97-'07 Cagiva Canyon 500 & '03-'04 Husqvarna SM610S as part of component group 8000 80186 ($87.62) -> for inspection guidelines see http://www.moto-lab.com/gallery/view?itemid=303 (scroll down for descriptions and links. Click image for high res view). For a reduction in wear, use the slide below.
13501-32E00 Throttle Slide (w/one slide lift hole), $45.98 ea. ($58.97), fits '96-'15 Suzuki DR650. Also fits Aprilia Moto 6.5. Can be used in '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only), '03-'07 KTM 640LC4 or '90-'95 Suzuki DR650 in order to reduce slide guide, slide, emulsion tube & jet needle wear problems -> for inspection guidelines see http://www.moto-lab.com/gallery/view?itemid=303 (scroll down for descriptions and links. Click image for high res view)
13501-12D00 Throttle Slide (w/two slide lift holes), $47.73 ea. ($62.82), fits '90-'95 Suzuki DR650. -> for inspection guidelines see http://www.moto-lab.com/gallery/view?itemid=303 (scroll down for descriptions and links. Click image for high res view).
13556-44B00 Felt Throttle Shaft Seal, $2.01 ea. (2.93), fits '90-'15 Suzuki DR650, '89 GSX-R750RK and '91-'98 non-USA GSX-R1100. Fit '00 KTM 400SXC, '01 KTM 400 LC4-E, & '98-'02 KTM 640LC4. Also fits Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, (not available separately from Aprilia, Cagiva, Husqvarna or KTM).
MIK0111114110 Throttle Shaft V-Seal, $4.81 ea., fits '03 KTM 625SXC (USA only) & '03-'07 KTM 640LC4 (not sold separately by KTM).
584.31.028.000 Diaphragm $23.12 ea. ($33.29), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07KTM 640LC4. Also fits Suzuki '90-'15 DR650, '89 GSX-R750RK & '91-'98 non-USA GSX-R1100 as part number 13507-07D01 ($29.10), Aprilia Moto 6.5, Cagiva Canyon 500/600 and '03-'04 Husqvarna SM610S (not available separately from Aprilia, Cagiva or Husqvarna).
13502-41C00 Diaphragm Cover, $25.00 ($32.91), fits '96-'15 DR650 & '91-'98 non-USA GSX-R1100.
13278-02340-V Diaphragm Cover Vacuum Port O-Ring, FKM (a.k.a. Viton), $1.04 ($1.52), fits Aprilia Moto 6.5, '92-'15 Suzuki DR650, '89 GSX-R750RK & '91-'98 non-USA Suzuki GSX-R1100.
584.31.050.000 Screw (plastic cold start plunger retainer), $4.57 ea. ($6.79), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4. Also fits Suzuki '92-'15 DR650 as part number 13418-43410 ($5.85), Aprilia Moto 6.5, Cagiva Canyon 500/600 and '03-'04 Husqvarna SM610S (not available separately from Aprilia, Cagiva or Husqvarna).
13681-04010 Cold Start Slide Retainer to Cable Seal, $2.74 ea. ($3.98), fits Suzuki '92-'15 DR650, Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4. (not available separately from Aprilia, Cagiva, Husqvarna or KTM).
13418-17C00 Cold Start Enrichment Slide Shank Seal, $3.28 ea. ($4.34), fits '89 Suzuki GSX-R750RK & '91-'98 non-USA Suzuki GSX-R1100.
584.31.049.000 Starting Piston Mikuni (cable actuated), $5.70 ea. ($8.39), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4.
13411-12D00 Plunger Assy (cable actuated), $13.98 ($17.92), fits Suzuki '92-'15 DR650.
584.31.053.000 Spring, 22.5mm, For Starting Piston, $2.69 ea. ($5.59), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4. Also fits Suzuki '92-'15 DR650 as part number 13417-22010 ($2.88), Aprilia Moto 6.5, Cagiva Canyon 500/600 and '03-'04 Husqvarna SM610S (not available separately from Cagiva or Husqvarna).
13411-15A30 Plunger Assy, $33.87 ($43.42) Long style cold start enrichment plunger with knob (extends out past throttle cables), fits '90-'91 Suzuki DR650. Can be used on '92-'15 Suzuki DR650 to replace the cable operated cold start enrichment plunger listed above.
KTM0111100000 Rebuild Kit for TPS equipped models, $37.93, fits '03 KTM 625SXC (USA only) & '03-'07 KTM 640LC4. This contains the same parts as the 584.31.099.000 Gasket Set ($60.25) except the diaphragm (which rarely gets damaged) but plus the throttle blade screws and float needle, which normally only comes as part of 584.21.020.000 Needle Valve 2.8 mm ($43.99)(usually no need for the assembly, as the seat is rarely damaged) Full list of parts contained in the kit: float needle, needle seat o-ring, cold start enrichment feed pipe o-ring, float bowl gasket, main jet access plug o-ring, pilot screw o-ring, slide guide o-ring, cold start plunger retainer to cable seal, two rubber throttle shaft v-seals, two stainless steel socket throttle blade screws and instructions.
KTM0111100001 Rebuild Kit, same as above but for models without TPS, $37.93 ea., fits '00 KTM 400SXC, '01 KTM 400 LC4-E & '98-'02 KTM 640LC4. Also fits Cagiva Canyon 500/600 & '03-'04 Husqvarna SM610S. Full list of parts contained in the kit: float needle, needle seat o-ring, cold start enrichment feed pipe o-ring, float bowl gasket, main jet access plug o-ring, pilot screw o-ring, slide guide o-ring, cold start plunger retainer to cable seal, two felt throttle shaft seals, two stainless steel socket throttle blade screws and instructions.
SUZ0111100002 Rebuild Kit, $36.45 ea., fits '90-'91 Suzuki DR650. Also fits '90-'99 DR350SE. Full list of parts contained in the kit: float needle, needle seat o-ring, cold start enrichment feed pipe o-ring, float bowl gasket, main jet access plug o-ring, pilot screw o-ring, slide guide o-ring, two felt throttle shaft seals, two stainless steel socket throttle blade screws and instructions.
SUZ0111100003 Rebuild Kit, $37.93 ea., fits '92-'95 Suzuki DR650. Full list of parts contained in the kit: float needle, needle seat o-ring, cold start enrichment feed pipe o-ring, float bowl gasket, main jet access plug o-ring, diaphragm cover vacuum port o-ring, pilot screw o-ring, slide guide o-ring, cold start plunger retainer to cable seal, two felt throttle shaft seals, two stainless steel socket throttle blade screws and instructions.
SUZ0111100004 Rebuild Kit, $36.54 ea., fits '96-'15 Suzuki DR650. Also fits Aprilia Moto 6.5. Full list of parts contained in the kit: float needle, needle seat o-ring, cold start enrichment feed pipe o-ring, float bowl gasket, diaphragm cover vacuum port o-ring, pilot screw o-ring, slide guide o-ring, cold start plunger retainer to cable seal, two felt throttle shaft seals, two stainless steel socket throttle blade screws and instructions.
SUZ0111100006 Rebuild Kit, $41.98 ea., fits '89 GSX-R750RK. Full list of parts contained in the kit: float needle, needle seat o-ring, cold start enrichment feed pipe o-ring, float bowl gasket, main jet access plug o-ring, diaphragm cover vacuum port o-ring, pilot screw o-ring, slide guide o-ring, cold start slide shank seal, fuel feed tee seal, vacuum port cap, two felt throttle shaft seals, two stainless steel socket throttle blade screws and instructions.
SUZ0111100007 Rebuild Kit, $38.79 ea., fits '91-'98 non-USA GSX-R1100. Full list of parts contained in the kit: float needle, needle seat o-ring, cold start enrichment feed pipe o-ring, float bowl gasket, diaphragm cover vacuum port o-ring, pilot screw o-ring, slide guide o-ring, cold start slide shank seal, fuel feed tee seal, two felt throttle shaft seals, two stainless steel socket throttle blade screws and instructions.
13258-44B00 Float Bowl Gasket, $6.19 ea. ($7.94), fits '90-'15 Suzuki DR650, '89 GSX-R750RK & '91-'98 non-USA GSX-R1100. Also fits Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4 (not available separately from Aprilia, KTM, Cagiva or Husqvarna).
MIK0111111000 Float Needle, aftermarket, $8.94 ea. Fits Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only), '98-'07 KTM 640LC4, '90-'15 Suzuki DR650, '89 GSX-R750RK and '91-'98 GSX-R1100. (not available separately from Aprilia, KTM, Cagiva, Husqvarna or Suzuki)
MIK0111111001 Float Needle, genuine Mikuni, $12.90 ea. Fits Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only), '98-'07 KTM 640LC4, '90-'15 Suzuki DR650, '89 GSX-R750RK and '91-'98 GSX-R1100. (not available separately from Aprilia, KTM, Cagiva, Husqvarna or Suzuki)
13250-12EH0 Float Valve, $62.30 ea. ($79.88), fits '90-'15 Suzuki DR650, and '91-'98 GSX-R1100. Also fits Cagiva Canyon 500/600 and '03-'04 Husqvarna SM610S as 8000 80177.
584.31.020.000 Needle Valve 2.8mm, $31.59 ea. ($46.19), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4.
584.31.009.000 Float Assembly, $22.82 ea. (33.19), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4.
13374-35C00-V Float Seat O-Ring, FKM (a.k.a. Viton), $3.90 ea. ($5.02), fits '90-'15 Suzuki DR650, '89 GSX-R750RK & 91-'98 non-USA GSX-R1100. Also fits Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4 (not available separately from Aprilia, KTM, Cagiva or Husqvarna).
13374-46710-V Cold Start Enrichment Feed Pipe O-ring, FKM (a.k.a. Viton), $2.50 ea. ($3.61), fits '90-'15 Suzuki DR650, '89 GSX-R750RK & 91-'98 non-USA GSX-R1100. Also fits Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4 (not available separately from Aprilia, KTM, Cagiva or Husqvarna).
13279-47070 Pilot Fuel Screw, $8.43 ea. ($10.82), fits '90-'15 Suzuki DR650, '89 GSX-R750RK 91-'98 non-USA GSX-R1100. Also fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4 (stainless instead of brass)(not available from KTM).
13268-47070 Pilot Fuel Screw Spring, $2.42 ea. ($3.51), fits '90-'15 Suzuki DR650, '89 GSX-R750RK '91-'98 non-USA GSX-R1100. Also fits Aprilia Moto 6.5, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4 (not available from KTM).
13291-29900 Pilot Fuel Screw Washer, $0.94 ea. ($1.36) fits '90-'15 Suzuki DR650, '89 GSX-R750RK & '91-'98 non-USA GSX-R1100. Also fits Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4 (not available from Aprilia; not available separately from Cagiva, Husqvarna or KTM).
13295-29900-V Pilot Fuel Screw O-Ring, FKM (a.k.a. Viton), $2.42 ea. ($3.51) fits '90-'15 Suzuki DR650, '89 GSX-R750RK & '91-'98 non-USA GSX-R1100. Also fits Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4 (not available from Aprilia; not available separately from Cagiva, Husqvarna or KTM).
MIK0111221000 Extended Pilot Fuel Screw Set, $12.48 ea., includes screw, spring, washer, and o-ring; fits Aprilia Moto 6.5, '90-'15 Suzuki DR650, '89 GSX-R750RK & '91-'98 non-USA GSX-R1100, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4.
CRZ-SCR-5020M Extended Pilot Fuel Screw Set (longer than the above, with larger knob and indexing flat), $19.58 ea., includes screw, spring, washer, and o-ring; fits Aprilia Moto 6.5, '90-'15 Suzuki DR650, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4.
584.31.007.045/047 Idling Jet 45/47.5, $6.36 ea. ($9.79)(all sizes of this style jet in stock at the same price), fit '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07KTM 640LC4. Also fit Aprilia Moto 6.5, which normally takes a size 50 (not available from Aprilia). Also fit Cagiva Canyon 500/600, which normally takes a size 45 part number 0032377, 47.5 part number 0032378, 50 part number 0032381, 52.5 part number 0032380, 55 part number 0032379 (standard), or 60 part number 0032376 (standard for Brazil). Fit '03-'04 Husqvarna SM610S, which normally takes a size 52.5 part number 8A00 80174. Fit Suzuki 90-'91 DR650, which normally takes a size 47.5, part number 09492-47013, '92-'95 DR650, which normally takes a size 52.5, part number 09492-52010, and '96-'15 DR650, which normally takes a size 42.5, part number 09492-42010. Fit Suzuki '89 GSX-R750RK, which normally takes a size 37.5, part number 09492-35010. Also fit Suzuki '91-'98 non-USA GSX-R1100, which normally takes a size 40, part number 09492-40014.
584.31.023.140/142/145 etc., $4.15 ea. ($7.29)(all sizes of this style jet in stock at the same price), fit '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07KTM 640LC4. Also fit Aprilia Moto 6.5, which normally takes a size 150 (not available from Aprilia). Fit Cagiva Canyon 500/600, which normally takes a size 147.5 part number 0032395, 150 part number 0032398, 152.5 part number 0032394, 155 part number 0032393 or 157.5 part number 0032397. Fit '03-'04 Husqvarna SM610S, which normally takes a size 162.5 part number 8A00 80171. Fit the Suzuki 90-'91 DR650, which normally takes a size 147.5 part number 09491-29012, '92-'95 DR650 which normally takes a size 137.5 part number 09491-27010, and '96-'15 DR650, which normally takes a size 140 part number 09491-28010. Fit the Suzuki '89 GSX-R750RK, which normally takes a size 115 part number 09491-23011 or 110 part number 09491-22016. Also fit the Suzuki '91-'98 non-USA GSX-R1100, which normally takes a size 122.5 part number 09491-24013, 125 part number 09491-24010 and/or 127.5 part number 09491-24011.
002-157 Air Bleed 1.2, $4.15 ea. (all sizes of this style jet in stock at the same price), fit '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4 (remove the pressed in main air jet, tap the hole M4X.7 and use the same style of jet to tailor main air correction)(neither main nor pilot air bleeds are available from KTM). Fit the Aprilia Moto 6.5, which normally takes a size 1.2 (not available from Aprilia). Fit the Cagiva Canyon 500/600 as part number 0032375 (size unknown). Fit '03-'04 Husqvarna SM610S as part number 8000 80175 (size unknown). Fit the Suzuki '90-'15 Suzuki DR650, which normally takes a size 1.0, part number 09493-20007. Fit the Suzuki '89 GSX-R750RK, which normally takes a size 0 main air bleed jet, part number 09493-00001 and a size 1.0 pilot air bleed jet, part number 09493-20007. Also fit the Suzuki '91-'98 non-USA GSX-R1100, which normally takes a size 1.2, part number 09493-24007.
13247-02340 Float Bowl Drain Screw, $2.77 ea. ($4.03), fits '90-'15 Suzuki DR650, '89 GSX-R750RK and '91-'98 non-USA GSX-R1100. Also fits the Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4 (not available separately from Aprilia, Cagiva, Husqvarna or KTM).
584.31.014.000 Main Jet Access Plug, $5.75 ea. ($8.39), Fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4. Fits Suzuki Also fits '90-'99 DR350SE, '90-'95 DR650 & '89 GSX-R750RK as part number 13247-32210 ($10.14). Also fits Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S (not available separately from Cagiva or Husqvarna).
13249-41310-V Main Jet Access Port O-Ring, FKM (a.k.a. Viton), $2.45 ($3.56), Fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only), '98-'07 KTM 640LC4, '90-'99 Suzuki DR350SE, '90-'95 DR650 & '89 GSX-R750RK. Also fits Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S (not available separately from Cagiva, Husqvarna or KTM).
584.31.034.6G5 Jet Needle (adjustable) $6.35 ea. ($9.49), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4 -> for needle inspection guidelines, see http://www.moto-lab.com/gallery/view?itemid=306 (scroll down for descriptions and links. Click image for high res view).
13383-12E20 Jet Needle 6F10, $10.75 ea. ($13.80), fits '92-'95 Suzuki DR650 -> for needle inspection guidelines, see http://www.moto-lab.com/gallery/view?itemid=306 (scroll down for descriptions and links. Click image for high res view).
13383-12D20 Jet Needle 6H11 (adjustable), $17.29, fits European '90-'95 Suzuki DR650. Use on USA models to add adjustability. Also fits Cagiva Canyon 500/600 & '03-'04 Husqvarna SM610S as 8000 84404 -> for needle inspection guidelines, see http://www.moto-lab.com/gallery/view?itemid=306 (scroll down for descriptions and links. Click image for high res view).
13383-32E00 Jet Needle 6F19 (adjustable), $17.29, fits European '96-'15 Suzuki DR650. Use on USA models to add adjustability. -> for needle inspection guidelines, see http://www.moto-lab.com/gallery/view?itemid=306 (scroll down for descriptions and links. Click image for high res view).
J8-6LH05 Jet Needle (adjustable), $18.11 ea., fits '95-'02 Aprilia Moto 6.5 (not available from Aprilia) -> for needle inspection guidelines, see http://www.moto-lab.com/gallery/view?itemid=306 (Images are from a KTM, but the concepts are the same. Scroll down for descriptions and links. Click image for high res view)
584.31.032.000 Jet Needle Plastic Shim, $1.72 ea. ($2.59), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4. Also fits '90-'15 Suzuki DR650, '89 GSX-R750RK and '91-'98 non-USA GSX-R1100 as 13387-07D00 ($4.39), Aprilia Moto 6.5, Cagiva Canyon 500/600 and '03-'04 Husqvarna SM610S (not available separately from Aprilia, Cagiva or Husqvarna).
584.31.132.000 Jet Needle Metal Shim, $4.27 ea. ($6.29), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4.
584.31.045.000 Jet Needle Circlip, $1.09 ea. ($1.69), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4. Also fits '90-'15 Suzuki DR650, '89 GSX-R750RK and '91-'98 non-USA GSX-R1100 as 13394-31210 ($3.61). Also fits the Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S(not available separately from Aprilia, Cagiva or Husqvarna).
584.31.030.000 Throttle Valve Spring, $26.82 ea. ($37.79), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4.
13417-17D00 Slide Spring, $4.36 ea. ($5.59), fits '92-'15 Suzuki DR650 & non-USA '91-'98 GSX-R1100. Also fits '95-'02 Aprilia Moto 6.5 (not available from Aprilia).
584.31.042.000 Fuel Screen, $4.41 ea. ($6.49), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4. Also fits '90-'15 Suzuki DR650 as part number 13236-12C00 ($8.36), Aprilia Moto 6.5, Cagiva Canyon 500/600 & '03-'04 Husqvarna SM610S (not available separately from Aprilia, Cagiva or Husqvarna).
UP-123 Breather Filter, 1/2" barb, $13.29 (14.95), connect to the big 90 degree tube that equalizes pressure under the diaphragm. Fits Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only), '98-'07 KTM 640LC4, and '90-'15 Suzuki DR650.
14-5011 Uni filter oil, $8.57 ($9.95) Even though it says it doesn't need it, the above breather filter will work better if it has been oiled.
584.06.026.000 Airbox Side Carburetor Boot, $15.57 ea. ($17.29), fits '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4.
912-A2 M5X12, stainless steel socket head right side float bowl screw, $0.54 ea., fit the Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4, '90-'15 DR650 Suzuki, '89 GSX-R750RK & '91-'98 non-USA GSX-R1100.
912-A2 M5X12, stainless steel socket head front throttle cable bracket screws, $0.54 ea., fit Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '90-'15 Suzuki DR650.
912-A2 M5X12, stainless steel socket head TPS screws, $0.54 ea., fit '03 KTM 625SXC (USA only) & '03-'07 KTM 640LC4.
125-A2 M5, stainless steel TPS screw flat washers, $0.09 ea., fit '03 KTM 625SXC (USA only) & '03-'07 KTM 640LC4.
127B-A2 M5, stainless steel TPS screw split lock washers, $0.14 ea., fit '03 KTM 625SXC (USA only) & '03-'07 KTM 640LC4.
912-A2 M5X14, stainless steel socket head diaphragm cover, left side float bowl & rear throttle cable bracket screws, $0.51 ea., fit Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4 and '90-'15 Suzuki DR650.
912-A2 M5X14, stainless steel socket head left side float bowl screws, $0.51 ea., fit Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4, '90-'15 Suzuki DR650, '89 GSX-R750RK & '91-'98 non-USA GSX-R1100.
7991-A2 M4X8, stainless steel flat socket TPS bracket screws, $0.70 ea., fit '03 KTM 625SXC (USA only) & '03-'07 KTM 640LC4.
7991-A2 M3X6, stainless steel flat socket throttle blade screws, $0.36 ea., fit Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4, '90-'15 Suzuki DR650, '89 GSX-R750RK & '91-'98 non-USA GSX-R1100.
PP2699 Float Height Setting Tool, $24.95 ea. ($29.95), works on most carburetors.
35-2270 Pilot Jet Driver, $15.68 ea., allows easy removal & installation of the pilot jet without the risk of the head stripping.
04992063 Pilot Screw Well Tap, $10.22 (chasing the threads and lightly greasing the screw will help prevent it from sticking/seizing)
583.12.093.000 Fuel Pump Mikuni Rallye, $72.65 ea. ($91.61), fits '99-'01 KTM 640LC4 Adventure R.
585.12.087.000 Fuel Pump Mikuni DF52-601, $71.78 ea. ($91.97), fits '02- '07 KTM 640LC4 Adventure R & '08-'09 KTM 690 Factory Rally Replica.
12-1133 Fuel Pump Rebuild Kit, $5.27 ea., fits '02- '07 KTM 640LC4 Adventure R & '08-'09 KTM 690 Factory Rally Replica.
5LP-24500-01-00 Raptor Petcock, $22.80 ea. ($27.49), use on '92-'15 Suzuki DR650, '90-'99 DR350SE, '90-'95 DR250SE, '00-'12 DRZ400S & '00-'05 DRZ400SM to replace the stock vacuum operated petcock.
13508-17C00 Cap, $2.53 ea. ($3.48), fits '89 Suzuki GSX-R750RK and '91-'98 non-USA GSX-R1100. Use on '92-'15 Suzuki DR650 to cap the vacuum port when a manual petcock is installed.
13671-05A40 Clip, $1.97 ea. ($2.68), fits '89 Suzuki GSX-R750RK and '91-'98 non-USA GSX-R1100. Use on '92-'15 Suzuki DR650 to hold the above cap on the vacuum port when a manual petcock is installed.
Discussion over here: http://www.advrider.com/forums/showthread.php?t=347184
To order, please email me at dcapito@moto-lab.com or call me on (650) 363-0535. You can also order on line at https://store.moto-lab.com, but do prefer to email or talk on the phone first to make sure that you get what you need.
Regards,
Derek
motolab screwed with this post Today at 01:31 PM Reason: added new parts, updated fitments
motolab is online now   Reply With Quote
Old 03-17-2010, 04:58 PM   #2
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,950
got my kit and thanks for your help!
wrk2surf is offline   Reply With Quote
Old 03-23-2010, 03:13 AM   #3
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Derek,
Thanks for coming through for me and getting the parts to get the carb working right! I look forward to working with you on my motor!
Low594 is offline   Reply With Quote
Old 04-13-2010, 12:13 AM   #4
motolab OP
motolab's Avatar
Oddometer: 2,855
KTM fuel pumps now in
I now have in stock:
583.12.093.000 Fuel Pump Mikuni Rallye, $86.28 ea.
Will add it above as well, so the list is complete.
Regards,
Derek
Old 04-21-2010, 04:06 PM   #5
cuneesity
Ferendo
cuneesity's Avatar
Oddometer: 4,515
The BST 40 rebuild kit is where its at!
Thanks Derek!!!
Baja Blitz (The original)
cuneesity is offline   Reply With Quote
Old 04-23-2010, 09:05 AM   #6
motolab OP
motolab's Avatar
Oddometer: 2,855
Thanks Derek!!!
You are welcome, sir!
Regards,
Derek
Old 05-25-2010, 07:39 PM   #7
motolab OP
motolab's Avatar
Oddometer: 2,855
I now have a cheaper float height setting tool in stock at $22.95 (previously $44.52). I've updated the above list accordingly.
Regards,
Derek
Old 06-26-2010, 03:06 PM   #8
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,260
Thanks for making parts available in kits we need at a good price Derek.
David
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 06-26-2010, 11:02 PM   #9
Chuck az
Chuck az's Avatar
Oddometer: 174
Ordered my Parts from Derek and I can say he is first class! Very knowledgeable and fast shipping
2008 KTM Adventure
Chuck az is offline   Reply With Quote
Old 06-27-2010, 06:08 PM   #10
SCsurfer
surfing explorer
Oddometer: 171
Derek had all the parts for my BST out the same day , even parts I did not realize I needed . After talking to Derek I found that my slide was more worn than I thought . Thank's for the help and quick shipping .
Paul
'07 640 Adventure
SCsurfer is offline   Reply With Quote
Old 07-14-2010, 11:08 PM   #11
motolab OP
motolab's Avatar
Oddometer: 2,855
585.12.087.000 Fuel Pump Mikuni DF52-601, $76.57 ea.
Regards,
Derek
Old 07-22-2010, 03:41 PM   #12
motolab OP
motolab's Avatar
Oddometer: 2,855
Float bowl gasket by itself, $6.44 ea.
Added it above as well, so the list is complete.
Regards,
Derek
Old 10-02-2010, 09:54 PM   #13
motolab OP
motolab's Avatar
Oddometer: 2,855
Rebuild kits with felt throttle shaft seals to suit models without TPS.
Added them above as well, so the list is complete.
I also added a pilot jet driver that makes stripping the head of the jet essentially impossible.
Regards,
Derek
motolab screwed with this post 10-09-2010 at 03:49 PM
Old 10-09-2010, 03:51 PM   #14
motolab OP
motolab's Avatar
Oddometer: 2,855
Stock jet needles, needle clips, and metal & plastic needle spacers.
Regards,
Derek
Old 10-27-2010, 06:32 PM   #15
motolab OP
motolab's Avatar
Oddometer: 2,855
Suzuki DR650 throttle slides.
Regards,
Derek
Times are GMT -7.   It's 01:36 PM.
