11-28-2009, 05:06 PM
#16 |
Oddometer: 19
sounds like you've got many fun filled nights in the garage ahead!
11-28-2009, 06:47 PM
#17 |
Oddometer: 1,215
11-28-2009, 07:11 PM
#18 | |
Oddometer: 608
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS) |
11-28-2009, 07:14 PM
#19 | |
Oddometer: 608
11-28-2009, 07:25 PM
#20 | |
Oddometer: 608
![]() It's Boomhauer's over at maximum-suzuki.
11-28-2009, 08:15 PM
#21 | |
Oddometer: 19
It still remembered my login but my post count was gone. |
11-29-2009, 12:20 AM
#22 | |
Oddometer: 1,215
11-29-2009, 12:34 AM
#23 |
Oddometer: 1,215
11-29-2009, 08:10 AM
#24 | |
Oddometer: 3,850
"Deeply flawed people make deeply flawed decisions." |
11-29-2009, 09:00 AM
#25 |
Oddometer: 10,906
Its not a direct bolt up - the RMX swinger is designed to mount to the outside of the engine cases, using the engine cases as a stressed member. The DR swingarm is solid across the front.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038 Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703 |
11-29-2009, 05:51 PM
#26 | |
Oddometer: 1,614
I blew it up on the dyno but that was after seeing 40hp ![]() ![]() ![]() To take advantage of the FCR37 you will have to do some significant porting work. The intake port is right at 33mm. Not much point in using a carb that is bigger then the port.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
11-29-2009, 06:43 PM
#27 | |
Oddometer: 19
any Idea what was the cause of the motor blowing? I mean, what will stop it from happening again? |
11-29-2009, 08:08 PM
#28 | |
What would Scoobydo?
Oddometer: 1,668
This thread has me jones-ing for a 350 right now. Forgot to mention--I like this workstand. I'd build one, but I'm in the middle of a 40mm WP conversion on my 650.
11-29-2009, 09:04 PM
#29 | |
Oddometer: 1,614
It toasted the piston but didn't hurt anything else.It took several runs to get the jetting in the ballpark. Those early poorly jetted runs took their toll. I changed shape of the top of the new piston to give it a little more squish area - that should help. The thing that is most amazing to me is this motor was breathing through the stock TM33 carb, the ports had not been touched and the valves, seats and guides were all worn out.
11-30-2009, 11:25 AM
#30 | |
Oddometer: 19
