Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10-09-2010, 11:00 AM   #46
bwalsh
Oddometer: 7,700
Looking at these links previously posted
http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123
That one looks like the wrong size screen and he has them "on sale". This one has the correct sized screen...
http://cgi.ebay.com/ws/eBayISAPI.dll...m=190451949930
I have had a few instances where the screen locked up. Turned it off then back on and no problems. Yesterday I went to scroll the map and it wouldn't scroll. To make a long story short it seems like the unit is locked up. After messing with it for awhile I got to the "where to & view map" screen. If I push hard the buttons change color like they are being pressed but nothing happens. I tried to reboot and am now stuck on the "select a locale" screen.
Tried the on button and the + button...no good, tried the on button and holding the lower right side of the screen, no good. Also took the battery out for a minute, then over night. Still no go.
Got on Garmins website and found an update for the software. Great, maybe this will fix it. Nope! Supposedly took the software update but who knows...
So I'm guessing I need a new touch screen too?
Thought I'd get more than 15 months use out of something that cost this much...
2004 XR650L
1992 Specialized Stump Jumper FS
NWVA TAG
NWVA TAG MAP
RTE THREAD & IN LIST
bwalsh screwed with this post 10-12-2010 at 11:22 AM
bwalsh is offline   Reply With Quote
Old 10-10-2010, 03:17 AM   #47
CHRIS_D
CHRIS_D's Avatar
Oddometer: 632
That sure doesn't seem to be a screen problem to me.
Update: Garmin will transfer the lifetime map update to the refurb model.
Also for a $150 deposit, Garmin will ship you the refurb model before receiving the defective one back. It only took 2 days to get it!!
2011 Victory Cross Country
2006 Suzuki DR 650
CHRIS_D is offline   Reply With Quote
Old 10-10-2010, 04:16 PM   #48
bwalsh
Oddometer: 7,700
Yeah, it's got me scratching my head too. Kind of at a loss for what to do. Don't really want to spend $150 right now.
Anyone else seen this happen before?
2004 XR650L
NWVA TAG
NWVA TAG MAP
Old 10-10-2010, 04:50 PM   #49
seasider
Just a rider
seasider's Avatar
Oddometer: 260
Had mine three years and screen locked up. Went thru all the on line updates twice and gave in to the 150 fee. Still cheapest way outbut thinking of switching to something else anyway. Ideas? I like off road and do lots but gotta pound pavement to get there.
Lost time is never found
seasider is offline   Reply With Quote
Old 10-27-2010, 07:52 AM   #50
RobertDouglas
Tractor Pilot
RobertDouglas's Avatar
Oddometer: 23
Cool2
My digitizer started getting weird a couple months ago and I finally got around to replacing it. I've had the 550 about three years. I do a lot of finger dragging on the map, so that probably accelerated the wear. I should try to use Mapsource more to plan routes.
I got the part from Yang Lin Sen, Espeed Logistics, Hong Kong via eBay. It is slightly smaller than the original digitizer, but it still fit within the area of the gasket so I went ahead with it. It did have the adhesive on the back, but I had to peel off the plastic cover which wasn't immediately obvious.
Hasn't been road tested, but it worked immediately definitely fixed the problem.
The replacement was a little easier than I thought it would be. You will need sharp near-vision and a steady hand. I think the main tips are:
1) Carefully flip up the little red tab to remove the ribbon cables
2) Use an exacto knife or something very slender to separate the old digitizer from the LCD screen, but be careful not to cut the LCD screen.
3) If the new digitizer is a little smaller than the old one then it's crucial to get it centered or it won't fit within the area of the gasket
4) check and double-check that the screen gasket is seated in it's groove before you tighten down the screws...you don't want to score that and mess up the seal
Thanks to the folks to posted photos and tips before me
RobertDouglas is offline   Reply With Quote
Old 12-10-2010, 06:37 AM   #51
REMORA
adventurer wannabe
REMORA's Avatar
Oddometer: 26
Thank you!
I just received and installed my new digitizer from the same supplier (xingming200808). I ordered the digitizer, was billed $30., and got one already with the metallic frame, so I only needed to fit it in after I removed the old one. Many thanks to all the good guys in this thread. I might have saved myself some money I intended for the 660, but I'll wait until I get to use the Zumo on my bike tomorrow to find out if it won't go bonkers on the road.
On a sad note, I just noticed that my on/off button had a tear on one side. I put some glue around it from the inside, tried pressing the button very gently and it turned on. I hope it holds. Still I dread to ride with it in the rain.
REMORA is offline   Reply With Quote
Old 12-15-2010, 09:12 PM   #52
OldSchool750
Old Rider
OldSchool750's Avatar
Oddometer: 98
digitizer and button failures
I replaced the digitizer....the smaller one from the e-bay seller with no problems. Also, the buttons...at least three on my 550 broke around the edges and one fell out. The solution is to buy a dummy display case that is used in stores. It has all the case parts including the gold plated connector on the bottom...just no electronics. You transfer your electronics and battery into the new case which requires soldering three battery wires and one antenna coax wire. Touch screen replacement is as covered in prior posts. Result...almost a new unit.
I ordered my "dummy" case from Darrel at www.tvnav.com - 785-625-3546 several months ago. As I recall, the case was 25 bucks or so. He may still have them.
Jim
OldSchool750 is offline   Reply With Quote
Old 12-17-2010, 10:31 AM   #53
bwalsh
Oddometer: 7,700
Jim
Good idea! My unit was the display model from Crutchfield in Harrisonburg Va. No dummy cases there.
2004 XR650L
NWVA TAG
NWVA TAG MAP
Old 03-19-2011, 02:44 PM   #54
Georgewk
Oddometer: 1
Leaking Zumo
Hi, after replacing the screen my Zumo leaks. Does anyone have a solution for this? Can I use silicone to seal the screen and case? Thanks, George
Georgewk is offline   Reply With Quote
Old 03-19-2011, 05:24 PM   #55
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 2,571
Silicone is a last resort but is effective, use sparingly.
Q: Is the replacement screen EXACTLY the same size as the original?
If so, you may have the front seal twisted or out of its channel.
If the screen is undersized then you will probably need silicone to seal unless the screen is exactly centered which is difficult to do.
Note: If your Zumo leaked be sure to dry thoroughly (use a hairdryer on low heat for 3 or 4 hours) as the water creeps up the back of the main circuit board and the board will corrode over a couple days if voltage is present on the board. The unit will then be junk.
Old enough to know better....
Young enough to try it again
GS Addict screwed with this post 03-19-2011 at 05:44 PM
GS Addict is offline   Reply With Quote
Old 03-19-2011, 08:30 PM   #56
OldSchool750
Old Rider
Oddometer: 98
The vendor on Ebay now has the correct size screen. This is the correct one.
There are others that sell them also.
http://cgi.ebay.com/LCD-Touch-Screen...item3f055e8905
Jim
Old 03-29-2011, 07:22 PM   #57
PlayWithGravity
Oddometer: 11
Thanks guys. Found this thread and ordered a new digitizer, pronto. My 550 also took a crap 2-3 years into service. Can't wait to get my parts from Hong Chong and get back to Zu-min'.....
PlayWithGravity is offline   Reply With Quote
Old 04-21-2011, 03:31 PM   #58
Tesla
Oddometer: 57
Jim
They list the screen dimensions as 79mm x 64.5mm. I thought that the correct dimensions were 79.3mm x 64.77mm (3.125" x 2.550")as previously posted on this thread.Barry
Tesla is offline   Reply With Quote
Old 04-22-2011, 07:37 AM   #59
PlayWithGravity
Oddometer: 11
Thumbs down
The risk here is that you F up the procedures. Like maybe the ribbon cable doesn't connect a easily as youd expect and you end up breaking stuff. Then you're screwed because no Garmin won't warranty it, at all... And you get stuck with an oversized $700 kickstand puck. Ask me how I know.
Old 04-22-2011, 07:49 AM   #60
Tesla
Oddometer: 57
I feel your pain brother. I decided to have Garmin send me a refurb 550 for $150.00 and your post is confirmation that its the right thing for me. A guaranteed working gps and warranty for 3 months is worth it for me. If I were you I would talk to Garmin anyway........maybe they can work something out for you.
Take heart though. Do it yourselfers like yourself are not always successful when we dive into uncharted waters. I'll bet you've saved far more than you lost. Besides you know that you really wanted a 665 anyway.
Barry
Times are GMT -7.   It's 11:43 AM.
