Thread Tools Rating: Thread Rating: 35 votes, 4.86 average. Display Modes
Old 11-16-2012, 12:55 PM   #661
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,188
You didn't poison yourself
Originally Posted by Mambo Dave View Post
Please tell me I didn't just poison myself.
Mixing and matching bread theories, just before baking I saved a part of the no-knead mix I baked days ago as a 'biga' (if I'm even spelling that correctly). My loaves are smaller - like 3 cups of flour - because it's just me eating them (maybe I've accidentally poisoned too many girlfriends with my cooking?)
I went and mixed that in with my no-knead recipe (that I put slightly less yeast in with) yesterday, and cooked it all up just now.
Somehow I got a true sour dough taste (strong! a bit stronger than any sour dough bread I've ever bought... but good!) in just that small time of allowing that biga to sit, and then re-using it. Like strong enough that I'm wondering, now, if I have bad bacteria or mold or something in it, because I've heard biga for sour doughs takes quite a while to develop its flavor.
Anyone foresee a problem with using parts of the last batch as the biga with a no-knead recipe? It seems to be leading me down the path of adding taste to the traditional no knead bread.
While they aren't baking stones, I leave my four cast iron skillets in the oven for the 500 degree preheat. I use two of them, hot, to bake bread now as my poor-man's dutch oven. Three of my skillets are the same size, so I just use one on top of the other, but upside down, as the 'lid' for the dutch oven. Between those, and the two left in the oven while I'm dumping dough into the first, there is enough radiant heat that I seem to be getting away without a baking stone. It may not be traditional, but I'd suggest to a lot of guys out there who want bomb-proof stuff to just use cast iron.
For my smaller 3-cup of flour bread I cook for 15 minutes with the top one on, then 20 minutes this last time with the lid off, at 500 degrees. I was trying 15 and 15, but it seemed too short of a time for both the crust and the insides.
You're probably more likely to get some type of iron poisoning from using cast iron to bake your bread in than from any process to actually make the bread
alright, so what you did is kept a piece of one dough to use as a "pre-ferment" in your next one. The french do this all the time for baguettes. they'll keep a piece from a previous batch, add it to the next to create flavor, texture, hole structure etc. They call it a pate Fermentee when it came from a previous dough. The biggest difference between this and other pre-ferments is a pate fermentee, having come from another dough, has salt in it. I worked at a bakery that did that. We called it "scrap". Yours must've been pretty old, or kept out of refrigeration to get that sour. Eventually, bacteria will take over the yeast and you'll end up with a sourdough starter. It probably wasn't quite there yet, but you could've refreshed it over a few days and it likely would've become one. That's how you got the sour flavor.
The no knead bread isn't as revolutionary as the articles would lead you to believe. Mixing flour and water together will develop into a bread dough with little to no help as many are seeing. It is considered a "straight dough", so many would argue its inferior to one that uses a preferment, yeasted or sourdough, but it isn't because you basically ferment the whole batch in the same manner one would when using a preferment. Make sense?
The no knead method can be used just as well in 3-4 hrs, with 2-4 folds, as in the 12-18hrs of that article. The difference is that you would do what you just did and use a preferment to jump start the fermentation, thereby eliminating the need to have a full batch of dough sitting for 12 hrs. Bread takes time. There is no way around that. However, there are 100's of ways to create that time. The long fermentation of a straight dough as in the no knead recipe, or by using pre-ferments. You wouldn't want to perpetuate the dough. ie: keep pulling a piece to add to the next since that would become a sourdough, or maybe you would? It depends on how you want your bread to taste. In your case, it also might have been so sour because I'm assuming you still did that long fermentation from the no knead recipe. If you used more yeast to shorten the process, it might have been less sour, but more complex. It sounds like your bread when straight to bacteria.
As for the pans, you're looking for thermal mass. Cast iron pans have a ton of thermal mass. Probably more than most pizza stone. When you put bread into your cast iron pan (great that you're preheating-required), pizza stone, my new brick oven or my commercial deck oven, the bottom heat radiates bottom up creating lift and eventually (with enough steam) a nice crust. The reason you can't make really great bread in a convection oven which pummels your dough from all sides. You want a more even, gradual bottom up heat. the thermal mass creates that, and helps maintain a better baking environment.
Click Here!
2012 Triumph Tiger 800 XC
2008 Yamaha WR250R
1971 Lambretta DL
levain screwed with this post 11-16-2012 at 01:02 PM
levain is offline   Reply With Quote
Old 11-16-2012, 01:31 PM   #662
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,369
Wow, you ARE the expert, and thank you so much for the response - leaving it out of refrigeration was exactly what I did.
Somehow, in the amount of information I've garnered in studying how to make breads, it was shown that if one is going to keep the biga (in my case a pate fermentee - awesome new term for me to learn about by the way) for any length of time, to keep it in the refrigerator. Well, I didn't exactly consider less than 48 hours a proper length of time, and in the videos I watched they didn't seem to go over what to do with the biga for shorter amounts of time, lol... so I made it up and stored it outside of refrigeration.
I don't know what other direction to take no knead bread in its recipe since, while good looking, the complexity of taste just wasn't really there with the 12-18 hour recipe so many of us are trying to use these days. If it won't kill me, I'd rather keep using (or occasionally use) a piece of the pate fermentee from each batch just to see where it takes it for taste (though, as I write this, the piece I took off of this newer sour dough is in the refrigerator this time - and I'll keep doing that since the more I think about it, the more ... risky... it seems that leaving it out may allow it to get moldy or bad bacteria or something ... there must be a reason other people don't leave it out for near-future use, and that the end product stood out so well that you were able to pick out exactly what I did wrong ).
Thanks again!
Mambo Dave is online now   Reply With Quote
Old 11-19-2012, 07:51 PM   #663
YBViking
Bedroom Adventurer
YBViking's Avatar
Oddometer: 589
French Bread - first try in the oven...film at 11....
first crack at french bread bagette (can you help me out here Klay- did i spell that rite?)...
also- while searching for my baking pans, spied the stove top pancake griddle...jeez instant 4 lb thermal mass right here! no need for me to buy one of those fancy paving stones...and to boot- i can bake directly on it!!
not my pic0- but you can see the griddle.
I'll post up pix as soon as it comes out of the Oven!
Levain- i know i need to add some 'steam' for the first 10-20 mins- would a cup of water be enough? or just add plenty and remove after a bit?
How's that outdoor oven workin out? showed it to my dad (Old German, mason by trade, cranky by nature)- he wants to know if you can make Lithuanian brown bread in that- he recalled buying bread behind a tenement in Brooklyn where some emigre's built their own oven to bake bread in for the neighborhood.
Never enter a battle of wits with an unarmed opponent!
Life's too short for hate...or ex-wives, cheap booze and the road not taken
Cigarettes are nails in my coffin- but I pounded them in
I'm going to Hell on the express bus.....That poor NUN........
I'm always auditioning the next future ex-mrs YBViking- PM me for an appt
YBViking is offline   Reply With Quote
Old 11-19-2012, 08:33 PM   #664
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,188
Steam is a good idea for sure, but it might be too late. I've never thought about the pancake griddle, but that actually might work quite well.
As for your dad, tell me more about this lithuanian brown bread. Maybe, between us we can come up with an ADV version. I still haven't baked in the oven. It's ready to go, I've just been so busy and its part of a renovation on our new home that we don't live in, so it just hasn't happened. I'm thinking soon though. I might bake a special bread for Thanksgiving.... Pictures soon if it happens, but this is a very busy time of year for me...
Click Here!
2008 Yamaha WR250R
1971 Lambretta DL
Old 11-19-2012, 10:00 PM   #665
YBViking
Bedroom Adventurer
YBViking's Avatar
Oddometer: 589
Fresh from the oven! Wil let it cool and check the crumb in the Am
By look and feel the crust is fairly thin but the loaf is heavy. I think i should have given it another hour to rise before shaping the final fluff.
Old 11-20-2012, 10:26 AM   #666
IDScarecrow
IDScarecrow's Avatar
Oddometer: 1,330
Any advice or recipes for dinner rolls? I am going to a friend's house for turkey day, and, having had my bread they asked me to bring a loaf or two "and rolls." I haven't tried making rolls before, but thoght I might just use the Jim Lahey recipe, divided into bits. But then how to cook it? I can't do it in the pot, so on a baking sheet with some water in the oven? Or should I use a different approach altogether?
"Pain is inevitable. Suffering is optional."
IDScarecrow is offline   Reply With Quote
Old 11-20-2012, 10:59 AM   #667
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,188
YB's pancake griddle isn't a bad approach. Just take your dough, divide it into smaller bits and bake those. We make a roll that we do that with.
As for steam, there are lots of ways to introduce steam. I'm no expert at that though since my ovens have steam generators. Spray bottle. preheat a pan and toss some ice cubes in there.
Click Here!
2008 Yamaha WR250R
1971 Lambretta DL
Old 11-20-2012, 12:20 PM   #668
YBViking
Bedroom Adventurer
YBViking's Avatar
Oddometer: 589
i just put a cast iron frying pan in for the pre-heat...added about a cup and a half of water- viola- instant steam (set the smoke alarms off at 10pm while it baked).
i have seen folks roll out a baugette then use scissors to cut a bunch of 'rolls' from it: this is from King Arthurs bread site:
https://docs.google.com/viewer?url=h...ve_shaping.pdf
looks pretty easy....
BTW= the griddle had a great thermal effect- browned the top and bottom of those loaves well, crust was thin as predicted but the crumb as waaay tooo dense. It was my own fault- it was getting late (Reville for me is 430am), letterman was on and i had to move things along. Still edible, but I didn't alllow it time to rise enough. the gas bubbles are very small.
Next time- i'm going with a slightly wetter mix, full rise, then a shape up, full rise again and into the oven it goes
Might add a touch more yeast too, or maybe get the yeast started in a cup of flour first, then add to the rest...
Thoughts?
I"ll have to ask my dad about that brown bread- he hasn't seen it in years and i seriously doubt the oven is still there or working- but he'll know who to ask. Big, round, crust didn't crackle, but was incredibly chewy- as a kid my jaws ached after eating one giant slice
Old 11-20-2012, 05:36 PM   #669
Barnstormer
Polar Bear Wrangler
Barnstormer's Avatar
Oddometer: 2,270
Pretty happy with this one- much better oven spring and finished height. Normal no-knead, plus a couple extra folds part way through.
Barnstormer is offline   Reply With Quote
Old 11-20-2012, 06:03 PM   #670
YBViking
Bedroom Adventurer
YBViking's Avatar
Oddometer: 589
That looks mighty tasty!.. what was your oven temp? steam/no steam? kind of flour? sorry for so many ?'s, but i'm always jealous of bread that looks better than mine.
that said- went to work today (did i mention i quit my job?)- and saw i still had flour on my shoes from baking bread last night...and realized I was happier baking bread than doing what i've done for the past 25 years!....looks like a lot of baking in my future
Old 11-20-2012, 06:57 PM   #671
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,188
Jumping through the hoops in RI
I was contacted last week by a chef that has been doing the kitchen grind for 15 years. He has grown to love the simple challenge of making a perfect loaf of bread. Looks like I may have a consulting gig in the new year helping him open a bakery.
There's something very soulful about making bread. We're in the middle of a 4500loaf, 8000pastry Thanksgiving right now. Nothing is better for us than a well planned holiday with beautiful bread stacked everywhere.
Good times
Click Here!
2008 Yamaha WR250R
1971 Lambretta DL
Old 11-20-2012, 07:31 PM   #672
YBViking
Bedroom Adventurer
YBViking's Avatar
Oddometer: 589
Good times
I envy you.
Happy Thanksgiving
Im gonna go make bread!
Old 11-20-2012, 10:09 PM   #673
Commuter Boy
Oddometer: 2,844
Use a soft sandwich bread recipe, and brush the tops with egg wash or melted butter before baking.
I've been using Peter Reinhart's buttermilk white bread for rolls over the last year.
Commuter Boy is offline   Reply With Quote
Old 11-21-2012, 12:34 AM   #674
Barnstormer
Polar Bear Wrangler
Oddometer: 2,270
That's regular flour, 500* oven, in a cast iron pot (with lid for 30 mins, lid off for about 10). It's the first time I've added a couple fold/kneads to it, (on advice from this thread), and I got a much finer crumb than I expected. Good flavor, I like the really dark finished loaf.
Old 11-21-2012, 07:16 AM   #675
mb90535im
'05 R1200 GS
mb90535im's Avatar
Oddometer: 5,143
Bloody Mary Bread
`Not much to look at since it's out of a machine, but tasty.
"Dang man I'm impressed." - Willy-B
"Are you OK? ... Are you sure you're OK?" - Honcho
"Disturbing and funny, all at the same time." - MrTwisty
mb90535im is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 05:38 PM.
