Old 12-01-2009, 03:11 PM   #1
California OP
Motorcyclist
California's Avatar
Location: Flower Mound, TX after 56 years in Carmel, Ca
Oddometer: 2,723
Send a message via AIM to California
changing spark plugs?
So I brought home a 2007 SilverWing, and now it won't start! It cranks like crazy, but no run! What should I start looking for, does it have a tilt/safety fuel switch? I didn't drop it, but I almost did while messing with the brakes and trying to see how tight a u turn I could do and where the hell are the spark plugs on this thing?
Stupid is as stupid does....
California, aka Leslie V Leslie.
Two roads diverged in a wood, and I
took the one less traveled by,
and that has made all the difference
California is online now   Reply With Quote
Old 12-01-2009, 03:40 PM   #2
Photog
Charismatic Megafauna
Photog's Avatar
Oddometer: 46,042
Sorry if this sounds dumb and you know it already...but does it have a brake interlock? You may have to hold the rear brake lever in to get it to fire. It's a common DOH! moment for folks who just bought a scoot.
Only an XR1200 owner knows why Cthulhu hangs its head out a car window.
Like I like. Yep.
Photog is online now   Reply With Quote
Old 12-01-2009, 04:51 PM   #3
Roose Hurro
Oddometer: 86
Don't forget to make sure you also have the Kill Switch set to "run"...
Roose Hurro is offline   Reply With Quote
Old 12-01-2009, 05:50 PM   #4
viclavigne
viclavigne's Avatar
Oddometer: 46
Simple stuff is usually the culprit, as already stated.
Kill switch accidentally flipped over, forgetting to hold a brake, trying to start with the side-stand down.... all can make you do the duh! slap on the head.
Vic
viclavigne is offline   Reply With Quote
Old 12-01-2009, 08:40 PM   #5
windburn
Oddometer: 1,135
Starting
The Kickstand needs to be up as well
Right below your crotch is an access panel for the spark plug you need to lift the seat and remove two screws then it come up and out. it is show in the owners manual if you have one. if not you can go to the Silverwing forum and print one.
I have a 2007 and it runs so well, so far and is so reliable I'm devoted to the machine and I have 15,000 miles on mine.
windburn is offline   Reply With Quote
Old 12-01-2009, 08:40 PM   #6
California OP
Motorcyclist
California's Avatar
Oddometer: 2,723
Yes, I know about the kill switch, and the brake lever, and the kickstand, but cranking is not the problem, starting is. It cranks like crazy, it just doesn't fire?
HELP!
Old 12-01-2009, 08:45 PM   #7
windburn
Oddometer: 1,135
silverwing forum
This site may help you find your answer.
http://silverwing.org/cgi-bin/forum_show.pl
Old 12-03-2009, 06:31 PM   #8
viclavigne
viclavigne's Avatar
Oddometer: 46
HELP!
I don't have a SilverWing, but my general experience with scooters is that the safety switches discussed will allow the starter to crank, but keep the engine from actually catching and running.
It could even be a bad or stuck switch, not impossible for the side-stand switch to go bad. Also - and this may sound oversimplistic - but double-checking that it has enough fuel.... maybe your fuel meter is wrong.
Vic
Old 12-03-2009, 11:50 PM   #9
wanna bECO
wanna bECO's Avatar
Oddometer: 720
likes already bin said... some folks calls it a kaiser blade others call it a sling blade, I call it a sling blade.. mmm hmm. .. I rekon it's got no gas in it.
Just cuz my bike is shiny, doesn't mean that I'm a hiny
current stable
'94 Harley .... a blue one
'82 Honda passport
'87 Honda spacy 250
And an E Bike
85 spacy 250
81 passport (in pieces, many parts for sale)
The hit's just keep coming.. bought another 81 passport (11-28-09)
http://tiny.cc/ITgetsBETTER
wanna bECO is offline   Reply With Quote
Old 12-04-2009, 03:15 AM   #10
Photog
Photog's Avatar
Oddometer: 46,042
Mmmm-hmmmm.
(great movie)
Like I like. Yep.
Old 12-04-2009, 07:01 AM   #11
California OP
Motorcyclist
California's Avatar
Oddometer: 2,723
I like the way you talk, hmmmmmmm, i like them fried taters, hmmmmmm.
Yes it has gas, that's the first thing I did! I checked the gas level, and even though the guage said it had gas, I added another gallon in case the guage was no good.
Gonna pull the plugs today and see what they look like and whether they're getting spark. We'll see.....
As far as cranking and not having spark, in my experience, the Japanese manufacturer's safety switches DO NOT allow the starter to crank.
Old 12-04-2009, 08:04 AM   #12
wanna bECO
wanna bECO's Avatar
Oddometer: 720
ya know youre right, I just went and tried to start spacy without t.he brake pedal on, no cranky cranky. Still.... it's always something stupid... the run/start thing.. that switch is my arch nemesis. One day I did 20 minutes of crankin', added gas, pulled plugs... and cusses like a fuqing sailor. flipped that switch and it fired right up. whats worse is how you beat yourself up.... I didn't enjoy the ride, but i was shakin my head the whole time.
current stable
'82 Honda passport
'87 Honda spacy 250
And an E Bike
85 spacy 250
Old 12-04-2009, 02:59 PM   #13
brockster
Despair & Repair Garage
brockster's Avatar
Oddometer: 2,039
Laugh
Well, if you didn't do something stupid once in a while, you wouldn't be a human.
2001 HD XL1200S
1977 Vespa + 1985 Honda Elite
CB550K project.
Man whoever came up with Ronald McDonald was dropping some serious acid.
." - SpoonKiller / tiotalruckus.com
brockster is offline   Reply With Quote
Old 12-04-2009, 03:17 PM   #14
viclavigne
viclavigne's Avatar
Oddometer: 46
That may be model-specific. I used to think the same thing, but found out it ain't necesarily so.....
Old 12-04-2009, 05:23 PM   #15
windburn
Oddometer: 1,135
Ok, help me here , is there not three things that make this thing go. Gas, Spark and Compression.Your right get those sparky's out and check them and the compression. could the timing be fubared, it seems unlikely. This is one fine bike.
Times are GMT -7.   It's 06:15 AM.
