Old 12-02-2009, 03:45 AM   #1
monkeywaythere OP
Scooter explorer
monkeywaythere's Avatar
Oddometer: 90
2 stoke mix?
hi people hope some can help i have a 1998 liquid cooled pug speedfight
it has a polini 70kit on 360degree race crank polini race head race exhaust delorto race carb gear up kit multivar ect ect the prob is i now have to mix the petrol and oil so what should i do it to?
been looking and for every 1ltr use 33ml of oil is this right ?
cheers in advance.
stuart
getting ready to explore a new world!
monkeywaythere is offline   Reply With Quote
Old 12-02-2009, 06:11 PM   #2
B02S4
Aye
B02S4's Avatar
Oddometer: 1,081
Greetings Stuart, debating premix ratios are sort of like engaging in religious or political discussions.
Your current mix is approx. a 30:1 ratio and that is a reasonable ratio to run. I personally would not go to a higher ratio (less oil per unit of fuel) than that for a performance 2T motor.
Most performance 2T motors will do just fine on a 20:1 to 30:1 premix ratio, with a good synth, properly jetted.
Keep in mind that all other things equal, as a general rule the more oil you premix (that is, the more oil you mix with a given volume of fuel), the leaner your air/fuel mixture will go on a relative basis.
Just as important, what specific oil are you using?
B02S4 is offline   Reply With Quote
Old 12-02-2009, 11:46 PM   #3
monkeywaythere OP
Scooter explorer
Oddometer: 90
Hi and thanks for the words of wisdom. I'm using castrol actevo its synthetic oil but will be running rock oil (strawberry smell) when i finish this bottle. its Putoline "strawberry scented TT scooter" 2 stroke oil. that too is fully synthetic.
should this be ok?
Old 12-03-2009, 03:32 PM   #4
B02S4
Aye
B02S4's Avatar
Oddometer: 1,081
I'm not familiar with that stuff, what is it rated as?
Old 12-03-2009, 05:50 PM   #5
brockster
Despair & Repair Garage
brockster's Avatar
Oddometer: 2,042
I've been using the Motul 800 Off-Road version since my engine was rebuilt. I premix since it's not an oil-injector engine.
No soft or hard seizures in the engine at all. I'm running roughly 2.5% to 3% range. I can tell when I'm closer to the (recommended) 2% mix because the engine note sounds edgier and flatter.
My only issue is that the oil costs about $15.00 a quart. But it's cheaper than a rebuild.
2001 HD XL1200S
1977 Vespa + 1985 Honda Elite
CB550K project.
Man whoever came up with Ronald McDonald was dropping some serious acid.
." - SpoonKiller / tiotalruckus.com
brockster is offline   Reply With Quote
Old 12-03-2009, 11:48 PM   #6
monkeywaythere OP
Scooter explorer
Oddometer: 90
not shaw what you mean by rated as? if you google it you will find it ,all i know is that a lot of off roader use it and they seem not to have any problems with it.
I have done a bit more research and have been advised to use 35-40ml per ltr of fuel. Got to look after this engine doing over 3000miles june july time in 7 days and in jan/feb doing 500+ in 2 days.
The whole scooter is geared up for long distance touring (or will bewith in the next week or 2!)
Old 12-04-2009, 02:51 PM   #7
B02S4
Aye
B02S4's Avatar
Oddometer: 1,081
Originally Posted by monkeywaythere
not shaw what you mean by rated as? if you google it you will find it ...
I was referencing the API or JASO certification. Perhaps you could google it also, eh?
Old 12-04-2009, 11:51 PM   #8
monkeywaythere OP
Scooter explorer
Oddometer: 90
Hi there mate just had a look and found a thing that said it was
JASO FC + pre-mix & injection recommended application: Road and Race does that mean any thing?
Old 12-05-2009, 09:19 AM   #9
B02S4
Aye
B02S4's Avatar
Oddometer: 1,081
...JASO FC + pre-mix & injection recommended application: Road and Race ...
That is good stuff. It will be fine. When it comes to 2T's it is best to use a good full synthetic oil.
Old 12-05-2009, 09:23 AM   #10
B02S4
Aye
B02S4's Avatar
Oddometer: 1,081
Originally Posted by MOPED MEDIC
...I have four two stroke scooters and run them all on Walmart $11 a gallon outboard oil...
So what?
Old 12-05-2009, 02:17 PM   #11
brockster
brockster's Avatar
Oddometer: 2,042
Go ahead and put bottom-feeder oil in your scooters if you want.
I'm going to have a LOT less carbon buildup and other contaminants on my piston and in my cylinder.
Motul 800 has worked perfectly for me so far and I am loath to change to anything else - let alone trolling motor oil sold by Wal-Mart.
Just trying to ride through the parking lot without getting clobbered by a mouth-breather is a mini-adventure...
2001 HD XL1200S
CB550K project.
Old 12-06-2009, 01:02 PM   #12
B02S4
Aye
B02S4's Avatar
Oddometer: 1,081
...although synthetic probably would win a taste test. Where the benefits of synthetic oil are most realized in two stroke applications is in the 50:1 to 100:1 ratios racers use...
That is simply incredible.
What racers do you know that run such absurd ratios?
Old 12-06-2009, 04:51 PM   #13
brockster
brockster's Avatar
Oddometer: 2,042
50:1 is 2%. Which is what I am supposed to be using since break-in.
So that ratio doesn't seem too far out.
2001 HD XL1200S
CB550K project.
Old 12-06-2009, 06:56 PM   #14
B02S4
Aye
B02S4's Avatar
Oddometer: 1,081
Originally Posted by brockster
50:1 is 2%...
You can run whatever ratio you want, it's your motor, however as a general rule you're not going to get max power at that ratio, presuming you run pre-mix only. A 50:1 mix with a decent 2T oil is probably going to be just fine if you don't routinely stress the motor.
My comment to the other poster about what I consider as an "absurd" 100:1 ratio was in the context of racing small-bore 2T aircooled motors & max power generation. I personally wouldn't intentionally run that ratio in a weed wacker. That said, YMMV (your mixture may vary).
B02S4 screwed with this post 12-06-2009 at 07:54 PM
Old 12-06-2009, 11:55 PM   #15
monkeywaythere OP
Scooter explorer
Oddometer: 90
So the original question will i be ok mixing 35ml to every 1ltr of fuel?
stuart
Times are GMT -7.   It's 01:15 AM.
