Old 09-17-2004, 07:57 PM   #1
mutineer OP
Raoul Duke Lives
mutineer's Avatar
Oddometer: 18,824
Using /5 forks on 1969 R60/2 US?
the '69 is the only year that had telescopic forks.
My crash this summer stove up the front end real good.
I can't find forks for a '69 anywhere. I need the whole front ends, forks, trees, etc.
Will /5 forks work?
If I can't find something soon I'll probably go with an Earles set up
"Life is as good as you let it be" - Chain
"well . . . it ain't for everybody" - Goonie
mutineer is offline   Reply With Quote
Old 09-17-2004, 10:15 PM   #2
Tim McKittrick
Oddometer: 1,446
I like the earls set up on my R69s and R50 mongrel bike fine- but to convert you would need a complete front end. fender, fork, swingarm shocks top plate, headlight ears, brake backing plate, possibly a front wheel, etc. I think the /5 forks will work, and would probably be an easier swap.
of course, with the Earls set up you get to have the front end RISE under hard braking.
Tim McKittrick is offline   Reply With Quote
Old 09-18-2004, 09:18 AM   #3
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
I beleive they are the same. Did you tweak the trees?
dead
Chopperman is offline   Reply With Quote
Old 09-18-2004, 10:55 AM   #4
mutineer OP
Raoul Duke Lives
mutineer's Avatar
Oddometer: 18,824
tweked pretty good - the whole thing is gona need replacing
I am terrified I tweaked the tube too, but it looks OK.
Old 09-18-2004, 12:12 PM   #5
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
Hmm. If you bashed it hard enough to tweak the trees there is a good chace he frame is bent too.
dead
Old 09-18-2004, 01:07 PM   #6
Tim McKittrick
Oddometer: 1,446
I have had to replace a /2 frame after the bearing cups in the steering head streched and the races started moving about. I would pay careful attention to the fit of the bearing races as well as any possible bending of the frame. The /2 frame is very robust and I suspect the relatively thin bearing cups will deform before the frame will bend.
Old 09-18-2004, 04:12 PM   #7
Stephen
Stephen's Avatar
Oddometer: 3,162
I had a 1970 R75/5--quite awhile back, now--and a friend has an R69US...I know that the forks are not identical, but it may be a distinction without a difference, if you know what I mean. They sure look mostly the same, but your may run into some interesting little details, say, when fitting headlight ears. Knowing how stubborn BMW is about change, I'd expect them to be interchangeable at the steering head. Oh, I know that the spring rates are different; the /5 are stiffer. Big surprise. And I seem to recall that the studs for the fenders are different, as the /5 used a plastic fender with smaller stays.
Good luck. Post some before and after pics.
Stephen is offline   Reply With Quote
Times are GMT -7.   It's 06:44 AM.
