Old 12-29-2012, 02:01 PM   #17521
LadyDraco
KillerSmileIHazIt !!
LadyDraco's Avatar
Oddometer: 29,949
Hey I have been in Tracy Calif ...
TISE
Life is what you make of it~If it don't fit make alterations
Check it from time to time as I'm always adding to it..
My Rides and life on the Farm
Just because the road is rocky doesn't mean your spirits should get rocky, too.{Crazy Cora}
LadyDraco screwed with this post 12-29-2012 at 02:52 PM
LadyDraco is offline   Reply With Quote
Old 12-29-2012, 02:13 PM   #17522
T
T's Avatar
Oddometer: 5,414
Originally Posted by JaxObsessed View Post
Damn....
I hate being obsessed..... and poor.
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_797wt_1168
Greetings from central PA.
That sure is a pretty little PA setting Jack. And that collection of Yammies ain't too shabby either.
Inconsequential Adventurer
T is offline   Reply With Quote
Old 12-29-2012, 02:22 PM   #17523
Scotty P OP
Funny like a Moran
Scotty P's Avatar
Oddometer: 13,580
Originally Posted by Hack View Post
I don't see the word "free" anywhere?
Hmmmm....ASSumptions! I didn't see any $$$ signs either.
06 KLR 650 "FBG" 99 Triumph 885i Tiger "Girlie"
Smokehole after midnignt..."I'm hungry", "me too" How about some Bitches n Gravy?
I'm a thread bully with no Ragrets.
Scotty P is offline   Reply With Quote
Old 12-29-2012, 02:36 PM   #17524
T
T's Avatar
Oddometer: 5,414
Lead going for about a buck a pound. It's the shipping that'll kill ya.
Grandpa use to cast his handgun bullets; you need a Brinell hardness of 15-17 (unless ur gonna copper coat 'em.)
BTW: Don't breath the fumes when you melt it down.
Old 12-29-2012, 02:43 PM   #17525
eddie bolted
BOING!!!
eddie bolted's Avatar
Oddometer: 3,815
were you really in Calif,........Tracy?
If it stops raining now, i'll be pissed!(BEANTOP)
It's mostly Dan........I knew he couldn't keep a secret(SCOTTY P)
eddie bolted screwed with this post 12-29-2012 at 03:02 PM
eddie bolted is offline   Reply With Quote
Old 12-29-2012, 02:51 PM   #17526
LadyDraco
LadyDraco's Avatar
Oddometer: 29,949
Yuppers for a few days...
Didn't live there thou...
But remember I have been cross country on the bike few times....
TISE
Old 12-29-2012, 03:21 PM   #17527
WayneJ
2015 LFC Mayor
WayneJ's Avatar
Oddometer: 5,947
I didn't have a hardness tester but the linotype alloy was going over 1000 fps in my 45LC Blackhawk with no barrel leading.
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
20% Smug Mug Credit
WayneJ screwed with this post 12-29-2012 at 03:27 PM
WayneJ is offline   Reply With Quote
Old 12-29-2012, 03:48 PM   #17528
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,703
Gas-cutting is generally caused by bullets that are too small or a chamber throat that is bigger than the cylinder allowing gas to get by the bullet and "cut" the lead making it soft around the base. If everything fits correctly, you can easily push 15 bn lead to 1200 or better. I used to push gas checked 200 grain lead in my IHMSA gun to 1800 fps with no leading.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is online now   Reply With Quote
Old 12-29-2012, 07:26 PM   #17529
Scotty P OP
Funny like a Moran
Scotty P's Avatar
Oddometer: 13,580
That was my biggest concern.........next to handling it. But then again, am I really worried about lead poisoning at my age.
Maybe I should just stick with copper jacket.
Old 12-30-2012, 08:34 AM   #17530
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,703
Melt and cast outside with either a breeze or a low powered fan blowing the smoke away from you.
You will get hot.
The worst thing that you can do is let a drop of sweat fall into the molten lead.
IT WILL EXPLODE ! ! !
I never wore gloves (but would now) and I have the scars to demonstrate.
Wear glasses and a long sleeve, cotton, tee shirt. Absolutely NO synthetics - if the lead splatters and hits polyester, it will melt into your skin. Tends to be a skosh painful.
Take your time and have absolutely NO distractions.
Mike -
Old 12-30-2012, 09:06 AM   #17531
WayneJ
2015 LFC Mayor
WayneJ's Avatar
Oddometer: 5,947
If you cast in a well ventilated area and wash your hands before sucking on your fingers, lead poisoning is not a problem.
Even if you do suck on your fingers without washing them, cigarettes probably will(maybe already have) do more harm to you then the lead.
I think the most dangerous thing about molten lead is the possibility of spills or splashes. It's really freakin'' hot and takes a long time to cool off.
And like Mike says, you don't want any moisture getting in it.
Ain't they purdy?
20% Smug Mug Credit
Old 12-30-2012, 09:24 AM   #17532
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,703
There is a product available from Brownell's called "D-Wipes" that comes in both toweletts and lotion that is designed to specifically remove lead from your skin. And, since I worked at a range and had to get b-annual lead checks, I proved that using D-Wipes was effective.
Mike -
Old 12-30-2012, 09:37 AM   #17533
Scotty P OP
Funny like a Moran
Scotty P's Avatar
Oddometer: 13,580
I'm in need of CCI 550 magnum primers...........with everyone freaking out, it may be months before I can chunk any 357.
38s will have to work for now.
Back to the basement to prep more cases.
Old 12-30-2012, 09:38 AM   #17534
Scotty P OP
Funny like a Moran
Scotty P's Avatar
Oddometer: 13,580
Originally Posted by WayneJ View Post
Ain't they purdy?
Old 12-30-2012, 09:54 AM   #17535
Hack
Hack's Avatar
Oddometer: 3,903
With all the hot-air around here and lack of bullets will this be what the next ride-to-shoot looks like?
Hack is offline   Reply With Quote
Times are GMT -7.   It's 12:09 PM.
