Old 12-30-2012, 12:10 PM   #17536
VACommuter
VACommuter's Avatar
Oddometer: 1,817
Sounds like we need a ride to load! (RTL) Followed shortly thereafter by a Ride Top Shoot. RTS. I still plug away with my single stage Lee press. Takes a long time to produce a batch!
VAC
I don't win shit.
2000 BMW K1200LT w/Sidecar "Bavarian Princess"
2002 KLR 685 w/ Enduro Sidecar "Dirt Nasty"
2003 KLR 685 "Street Ugly"
2007 KLR 719 "Muscles from Brussels"
VACommuter is offline   Reply With Quote
Old 12-30-2012, 12:17 PM   #17537
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,705
I used a single stage to load for IPSC the first year I shot it. I was going through 400-500 rounds a week between matches and practice so I'd load 100 rounds a night or do a marathon and stay up all night. Once I bought the first Dillon it was a piece of cake. I could load 500 rounds of .40 or .45 in a little over 30 minutes. The only thing I load that takes time now are match grade (sub MOA stuff) rifle. With all of the prep work, it takes several minutes for each round.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is offline   Reply With Quote
Old 12-30-2012, 03:21 PM   #17538
ecubed
LFC Cat
ecubed's Avatar
Oddometer: 695
Ride to Lead-Lead to Ride,,,RTL-LTR
I've cut many a sprue from the Lyman molds as a young boy to now.....sized, lubed and loaded which means handling bullets many times over....built many a shotgun shell....molded lead soldiers and painted them with lead paint. Molten, cut, grind, file, sand.....dug up lead at old shooting ranges....played with crates of lead solder, Linotype and wheel weights and formulated alloy ingots....built my own hardness tester....worked for 18 years in an electronic PCB manufacturing house with multiple wave solder machines which I had to build and modify fiberglass assembly solder fixtures for the line and clean out the machines...put lead solder in my mouth.....played with jars of mercury building manometers for industrial gauges and multi-cylinder engine synchronizers.....put mercury into throwing darts....mercury was in primers and propellants and the burnt residue in firearms.....worked on many brake shoes and drums..with air hoses...Hell, even lived in an asbestos sided house in NJ. We had liquid carbon tetrachloride and fire extinguishers, methyl ethyl ketone, trichloroethylene, sulfuric and muratic acid in glass jars and every other form of Kalifornia baby killing solvents in the house...chlorine, gasoline, ammonia, used oil, paint strippers, varnish, stains, acetone, lacquer thinner, turpentine, toluene, R-12 and every form of liquid-airborne metal and paint by heat or welding.....
.....Damn, now I forgot my point.
Oh yea, I turned out alright?
'02 XRL '95 K11RS '14 KZ1000ABS
ecubed screwed with this post 12-30-2012 at 03:42 PM Reason: forgot toluene
ecubed is offline   Reply With Quote
Old 12-30-2012, 03:22 PM   #17539
Scotty P OP
Funny Like a Clown
Scotty P's Avatar
Oddometer: 13,710
Originally Posted by 6USMC6 View Post
You can use small rifle primers in a .357 as long as you haven't lightened the mainspring.
You can also use small pistol primers in a .357 as long as you don't use a hard to ignite powder like WW296 or H110 and you don't try to load it hot.
I didn't know about the rifle primers.........thanks
06 KLR 650 "FBG" 99 Triumph 885i Tiger "Girlie"
Smokehole after midnignt..."I'm hungry", "me too" How about some Bitches n Gravy?
I'm a thread bully with no Ragrets.
Scotty P is offline   Reply With Quote
Old 12-30-2012, 03:25 PM   #17540
Scotty P OP
Funny Like a Clown
Scotty P's Avatar
Oddometer: 13,710
That sure does explain a lot...........
Sorry, couldn't help myself.
Old 12-30-2012, 04:01 PM   #17541
WayneJ
LFC Nobody
WayneJ's Avatar
Oddometer: 6,080
Just remember you will have to back off the powder charge you're currently using if you change primers.
And like Mike said, if your not using a ball powder, you don't need magnum primers.
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 12-30-2012, 04:16 PM   #17542
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,705
Scotty -
Load 5 rounds with sm rifle and try them. The biggest thing is having enough spring pressure to set them off. I run rifle primers in all of my sm primer 1911s - even with wimp loads - because it simplifies inventory. I have to keep small pistol primers for Mary's Glocks - otherwise I would load everything with small rifle. If you'll tell me what load you are using I can give you a safe starting point for small rifle in the place of small pistol. With magnum handgun loads, unless you are loading a max load - foolish in anything but a Freedom Arms, a TC or a Blackhawk - mag pistol to sm rifle is generally one-to-one. If you already have a load with magnum primers, back it off .1 to .2 (one to two tenths) and chrono.
Mike -
Old 12-30-2012, 04:38 PM   #17543
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,740
6, I want 300 grain bullet at 3,000+ fps out of my Casull! Now that is what I call home defense.
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Old 12-30-2012, 04:41 PM   #17544
WayneJ
LFC Nobody
WayneJ's Avatar
Oddometer: 6,080
20% Smug Mug Credit
Old 12-30-2012, 04:51 PM   #17545
Scotty P OP
Funny Like a Clown
Scotty P's Avatar
Oddometer: 13,710
Thanks guys.
Old 12-30-2012, 05:03 PM   #17546
ecubed
LFC Cat
ecubed's Avatar
Oddometer: 695
Now you just have to remember what priners and load you put in what batch.....what was I sayin'??
I have had to take a few batches apart.......
Old 12-30-2012, 05:30 PM   #17547
Scotty P OP
Funny Like a Clown
Scotty P's Avatar
Oddometer: 13,710
I think that is why they make these.....
Old 12-30-2012, 05:34 PM   #17548
Lonestar2112
scatology expert
Oddometer: 7,740
Scotty you need to remember just two things.
1. Wait with the smokes until you are done! Wash the hands too before you fire up.
2. Don't open the Bourbon until you are DONE for the day.
F*CK CANCER
Old 12-30-2012, 06:04 PM   #17549
Scotty P OP
Funny Like a Clown
Scotty P's Avatar
Oddometer: 13,710
Got it.........Don't be a Tater Salad
Old 12-30-2012, 06:21 PM   #17550
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,705
I get 1650 with a 300 grain bullet out of a 7 1/2" barrel.
The same load in my 22" carbine goes 2100.
Hit a deer in the ass and he'll kiss it.
Mike -
Times are GMT -7.   It's 07:22 AM.
