Old 12-07-2009, 09:23 AM   #1
Yellow Pig OP
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 5,993
Thumb Living with a Husky TE510!
So I just got rid of my trusty, old BRP and picked up a 2010 Husky TE510.
I will chronicle my life with this new bike and let you know both the good and the bad.
The reason for the switch was that one the BRP was getting a bit tired and I was getting tired of no e-star, two, and more significantly, was that I picked up a KTM 950 SE at the beginning of the 2009 riding season. With the SE in the stable I found that it could do 80-90% of what the BRP could, so there was too much overlap between the two bikes. I found that I needed a smaller more trail worthy bike that would be more suitable for technical terrain, but still be street legal. The TE fit the bill and on top of this was EFIed so i would not have to fool around w/ jetting given the typical 6000ft/2000meter elevation changes encountered here in Colorado on an average ride.
Since I picked up the bike we have had an arctic cold front here in Colorado that has prevented me from actually riding the bike. The only thing I have been able to do is put a few breaking miles around town and de-smog/power up the bike.
Initial impressions: The husky seems very well make, with great components and a good fit and finish. Initially it seems much vibe-er than mu old XR which was butter smooth. I hoping that it gets better once the engine has had a chance to break in. The stock Brembo brakes are phenomenal. Great stopping power and feel. I love how the bike was made to run in race mode. All the additional stuff was designed to be easily removed. Even the OEM exhaust, a top of the line Arrow is a great piece of gear that will not need to be replaced w/ an aftermarket exhaust.
Now this just needs to go away so I can actually ride the thing:
More to follow...
PROS:
- I love the look of the bike
- Fit and finish seems great
- Comes w/ quality components
- Incredible brakes
- Easy to work on, seems like Husky tried to use the same size bolts as much as possible
- Easy to de-smog/power up
- Shop manual comes w/ the bike on a USB key
CONS:
- Small tank (1.9 gal), the only aftermarket tanks a 3 gal IMS which with an average off-road MPG of 40-45 miles netts a range of 120-135 miles.
- So far the bike is a bit vibe-er that the BRP, but that could get better once the bike is broken in.
- Exhaust is extremely hot where it enters the muffler. Needs to be wrapped w/ header wrap to keep from burning pants and melting air-box.
- Gear shifter lever is ridiculously short (1.5 inches shorter than you average one)
- Foot-pegs are small and look like they are a cheap cast material prone to shattering
- OEM Arrow exhaust is way too loud for trail riding
- OEM radiators are very exposed and vulnerable. Not factory protection what so ever.
Planned Up-Grades:
- Uptite skid plate
- Cycra Handguards
- Heated Grips
- Pro Grip Rally grips
- IMS 3 gallon Tank
- Motosportz rear disk guard
- Zip Ty Gear shifter lever
- Zip Ty case saver
- Fastway foot pegs
- Taller gearing (will start w/ 14/47 or 15/47. Stock is 13/47)
- TE610 rear rack subframe
- PMB rear rack
- OFG racing radiator guards
- Husky dB killer insert
- Power Commander w/ Autotune
Initial Set Up:
The Husky comes from the factory w/ ever thing you need to get it running right. The so called Husky power-up kit comes with a plug for the O2 mid pipe sensor (remember the bike has EFI), a resistor plug for the EFI that switches the mapping to race mode, a free flowing air filter basket, and a removable catalytic converter situated in the mid pipe.
Husky Power-Up:
1- Remove air filter restrict or and replace w/ open basket.
This is what the Husky comes w/ from the factory. It's amazing the bike is even able to run w/ such low air flow. This must be how they manage to be 50 state street legal, pass CARB and Euro-3 restrictions.
So you get rid of that nonsense and put this in:
Ahhh! Much better!
I opted to keep the flash-back screen in the air-box for now. I need to see how the bike runs first.
2- Remove the exhaust end piece and slide out the cat converter:
This is where it sits in the mid pipe:
3- The Husky had this strange octopus attacking it so I whacked it off w/ a hammer and threw it away:
Gotta make sure you plug this thingy up (yes that is a technical term):
4- Take out the O2 sensor and plug the hole:
5- Once the O2 sensor is taken care of the spot where it was plugged into the EFI system needs to be taken car of. Husky provides this nifty plug w/ a built in resistor that tells the system the O2 sensor is no longer there and to get on w/ race mode.
WARNING: George from Up Tite Racing just told me that the moment you plug the race mode adaptor into the bike and turn it on it puts a code in the ECU which void your warranty!!!!
I wish my dealer had mentioned it or it was written in the manual. After all the bike comes from the factory w/ all these upgrade components.
Oh well, gotta pay to play.
Thats it now you are ready to roll.
I did a initial oil change at 35 miles. The oil looked pretty rough for such short mileage and there were a few metal flakes in the oil screens, plus a chunk of head gasket came out of the oil pan.
Oil changes are super easy:
- Remove drain plug
- Clean magnetic drain plug
- Remove 2 screws that hold oil screen #1 on left side of bike
- Remove Allen head plug that hold oil screen #2 on left side of bike
- Remove oil filter on right side of bike
- Close all holes
- Add oil (1700 ml for oil & filter change) and go
Yellow Pig screwed with this post 01-08-2010 at 08:00 PM
Old 12-07-2009, 11:09 AM   #2
bobfab
bobfab's Avatar
Oddometer: 799
very jealous. Love the new huskys, keep us posted
Project Labor of Love: 1972 CT90 Rebuild
Current Stable: DRZ400 | VFR800 | DRZ250 | CT90 | CB125
Need an airfilter for your DRZ250!? I have too many, PM ME
bobfab is offline   Reply With Quote
Old 12-07-2009, 11:34 AM   #3
moto_loco
poser extraordinaire
moto_loco's Avatar
Oddometer: 105
Great write up on your new Husky 510. They look ready to pounce...
just like that sweet BRP you have.
I learned a few things I would have never known otherwise. Thanks for taking time to post it.
moto_loco is offline   Reply With Quote
Old 12-07-2009, 01:28 PM   #4
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 3,932
I didn't see the Uptite "Y" fitting, it's a good idea to have, more even cooling between the rads & can't melt (never heard of one melting BTW)
If you haven't read it already, here's a great link for 510's secrets.
SCOTT SUMMERS: ME & MY HUSKY | News | Dirt Bike Magazine
P.S. congrats on getting the "Wolf"
P.S.S. A great Husky community with friendly people & loads of Husky experience can be found here
Cafe Husky
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus screwed with this post 12-07-2009 at 01:34 PM
Ruffus is online now   Reply With Quote
Old 12-07-2009, 01:38 PM   #5
AZ TOM
Oddometer: 2,355
Owned a few including 06 TE 510 & 07 TE250. Bottom line if the 650 R had an E-start there would be no better bike on the planet!!
AZ TOM is offline   Reply With Quote
Old 12-07-2009, 02:08 PM   #6
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 5,993
No need for it the 2010 Husky has several imporvements:
- Kayaba vs Marzocchi
- 15mm shorter swing arm
- Frame reinforced at critical points
- New more flexible IPD Graphics and plastics
- Rear LED tail light
- New more powerful headlight
- New high flow water pump
- Last but not least a factory Y fitting
I beleive there is a factory TSB that allows you to retrofit the upgraded pluming to certain model years.
PS I'm danbartol on Cafe Husky & danbart on Husky Talk and TT!
Yellow Pig screwed with this post 12-07-2009 at 02:23 PM
Old 12-07-2009, 05:00 PM   #7
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 3,932
Sweet
Welcome to the club
06 Husky TE510
Old 12-07-2009, 09:23 PM   #8
Jrmobb
Jrmobb's Avatar
Oddometer: 202
Congrat and welcome to the husky family! So far I love my 09.
It will be interesting to see if the FI will still compensate for altitude even when in race mode since there is no o2 sensor.
09 Te510, 01 KTM 640E, 05 TTR125L
Jrmobb is offline   Reply With Quote
Old 12-08-2009, 01:24 AM   #9
mousitsas
Oddometer: 2,145
The O2 sensor is narrow band and ony works in closed loop mod. Closed loop mod ony works in partial steady throttle. At all other times (which are many) the altitude compensation is accomplished by the airbox pressure sensor.
In other words, there should not be any problem at all.
Old 12-08-2009, 01:42 AM   #10
Jrmobb
Jrmobb's Avatar
Oddometer: 202
But when in open loop mode doesn't the bike not read sensors it just uses its pre programed settings kinda like a carb?
I would like to try power v with the auto tune setup. just hard to justify the price when my bike seems to run good now.
Old 12-08-2009, 03:27 AM   #11
mousitsas
Oddometer: 2,145
Even a carb has an inherent air pressure compensation mechanism, provided by the ventouri effect. In motorcycle fuel injection (modern cars are closed loop at all times), this is done by the air pressure sensor. I doubt that open loop mode would be able to work without this taken into account by the CPU at all times. Maybe someone more knowledgable could tell us more.
Autotune is a great idea if you change setup frequently and dont want to pay for dyno every time. Since you are fine, better spend the money on tyres! Unless of couse you are a gadget addict, in which case you will get it sooner or later anyway!
mousitsas screwed with this post 12-08-2009 at 03:32 AM
Old 12-08-2009, 06:25 PM   #12
BikePilot
BikePilot's Avatar
Oddometer: 10,901
I'm pretty sure the O2 sensor is not the primary means of compensating for altitude - as noted the MAP sensor and if it has one, barometric pressure sensor will manage that just fine. Until recently most street bikes did not use O2 sensors and they still manage to compensate for altitude just fine:)
The TE looks like a fantastic bike. I rode the SM510 around a bit and quite liked it. Great power, sharp handling etc. It also vibrated a bit, but not terrible by any means and not an abnormal amount as compared to competition oriented 450's.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 12-08-2009, 06:49 PM   #13
vwluv10338
Oddometer: 67
Most EFI systems are only in closed loop when crusing or at idle. The vehicle will use the feedback from the O2 when crusing to fine tune the standard map programmed in the ECU. This is mainly for fuel economy and emissions. Unplugging it will not hurt anything and it will just be running off the standard maps based on RPM and MAP sensor data (load).
E
vwluv10338 is offline   Reply With Quote
Old 12-08-2009, 07:02 PM   #14
269gs
269gs's Avatar
Oddometer: 108
Was the Yamaha wr250r on your radar at all? Ill be anxiously awaiting a comparison between your old Xr and the new Husky as I am in the same boat you were in.
269gs screwed with this post 12-08-2009 at 07:08 PM
269gs is offline   Reply With Quote
Old 12-08-2009, 07:08 PM   #15
error cooled
anything but asphalt
error cooled's Avatar
Oddometer: 965
I read that on the TE310 you cannot kick start the bike with a dead flat battery because the EFI primes only via the battery and not the magneto like of FI Only MX bikes.
Is that the same for the TE510? That would be a shame...
1988 Honda XR600R - vintage, street legal torque monster
1996 Suzuki DR350SE - dual sport anvil, buddy bike
The Blue Ridge Trail - Virginia via gravel, dirt, two track and backroads.
error cooled is online now   Reply With Quote
Times are GMT -7.   It's 06:58 PM.
