Old 03-10-2010, 12:18 PM   #76
2Plain
and simple
2Plain's Avatar
Oddometer: 15
Any updates?
Hello- I'm interested in any updates / ride impressions moving from the 650R to the Husky. I am thinking about pulling the trigger on an 08 TE510 and have a buyer for my 650R.
I am looking for the one-bike-does-it-all to ride trails with my 10 yr old son. But also ride (single track-to-fire roads) with buddies and do an annual week long touring trip with mixed pavement/off-road. A tall order for one bike..........and the 650R did it well except for the tight stuff ( and kicking the bike everytime my son needs help).
2Plain is offline   Reply With Quote
Old 03-10-2010, 02:39 PM   #77
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,208
Given your requirements, personally I don't think the 510 would be a good bike. It really is an enduro machine with lights etc. I think, given your requirements, a TE610 or the new 630 would better suit you (it also has the magic button).
Just my $0.02 and thus worth...exactly that.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Mercury264 is online now   Reply With Quote
Old 03-14-2010, 08:22 AM   #78
Yellow Pig OP
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,576
OK so I still have not been able to do any true off-road riding to give the bike a proper test, but I have decided that the Husky dB killer is way too restrictive, so I took advantage of the FMF sales deal and ordered an FMF Q4 exhaust.
I have a cheap Scosche dB meter so I decided to do some unscientific sound testing following the USFS standard ( open area, 20" from exhaust tip at a 45 degree angle) and the various configurations of the Arrow and the FMF exhaust.
Here are the pseudo scientific results It's hard to get a steady 6500 RPM since the bike gets in the power-band and takes off):
OEM Arrow uncorked
1- Idle 98dB
2- 6500 rpm 110dB
3- Peak 130dB
OEM Arrow w/ dB Killer
1- Idle 86dB
2- 6500 rpm 96dB
3- Peak 103dB
OEM Arrow w/ OEM spark arrestor
1- Idle 93dB
2- 6500 rpm 103dB
3- Peak 110dB
OEM FMF Q4 uncorked
1- Idle 95dB
2- 6500 rpm 104dB
3- Peak 113dB
OEM FMF Q4 w/ OEM spark arrestor
1- Idle 92dB
2- 6500 rpm 102dB
3- Peak 110dB
The bottom line is that the Husky is just a loud bike. It also make a significant amount of intake noise.
According to my highly calibrated butt dyno the open Arrow felt the fastest on the top, but was a bit less torque on the bottom, the Husky dB killer was nice and relatively quiet, but significantly choked up the bike and the FMF Q4 w/ spark arrestor was the best compromise of sound muffling and performance. It also felt like it added a bit of torque to the bottom end, while loosing a bit of top end.
I'll add pictures and some video clips when I get a chance.
Yellow Pig screwed with this post 03-14-2010 at 10:07 PM
Old 03-15-2010, 07:53 AM   #79
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 7,576
Here are the numbers side-by-side:
Note: even though the Arrow and the FMF have similar numbers w/ the spark arrestor in I personally think the FMF does not sound as loud since the tone of the muffler is a bit lower. The Arrow still has a bit of raspy, tinniness to it that makes it seem more offensive to the hear. I understand this is purely subjective though.
Old 03-15-2010, 10:46 AM   #80
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Question for you.
How did you determine the rpm for testing (6500 RPM)?
I'm wondering if the arrow exhaust for the 2008 bikes is different (noise output) than the 2009-10 bikes? I do know that they did change the exhaust system in 2009 and got away from the power up kit arrow exhaust. Maybe an alternative would be to intall a 2008 power up kit arrow exhaust on the new 2009-10 bikes to afford a noise reduction.
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 is offline   Reply With Quote
Old 03-15-2010, 12:02 PM   #81
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 7,576
My TE has a digital tachometer built into the speedo.
6500 rpm was hard to hold because of the power band.
I should have gone w/ 5500, it would have been easier to get a consistent rpm/reading.
Old 03-15-2010, 01:56 PM   #82
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
The reason I asked about the rpm is because through all the details I've read about the SAE noise test indicate a 3400 RPM for that engine displacement.
check out this link and the KTM 530 rpm test requirement on page 4:
http://parks.state.co.us/SiteCollect...Supplement.pdf
Old 03-15-2010, 05:58 PM   #83
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 7,576
Fast you are right. I have since done a bit more reading.
That's why I'm saying pseudo scientific test: I do not know how accurate the Scosche digital sound meter is or how accurately I followed the sound testing instructions.
I did 20 inches from the muffler tip a 45 degree angle at 1/2 max RPM.
The 510 does at leat 11K rpm, so I should have been at 5kish for sound testing. The actual calculation for testing rpm is something like x/stroke.
A few things I know were off:
1- I think the test needs to be done in a completely open area (I was by the garage, but facing away)
2- The test should be done on a soft surface like dirt or grass (I was on concrete)
3- My car was prked next to the bike.
4- Most bikes in the 450cc range 525/530cc range get tested between 3500 and 4500 RPM
The important thing is relative change between the exhausts.
Note: The FMFs and most other exhaust manufacturer are known to be optimistic w/ their exhaust ratings.
Yellow Pig screwed with this post 03-15-2010 at 06:05 PM
Old 03-15-2010, 06:06 PM   #84
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 7,576
I do plan on re-testing the mounted FMF at lower rpms.
Old 03-15-2010, 06:42 PM   #85
NorCalslowpoke
NorCalslowpoke's Avatar
Oddometer: 1,239
I owned a 650r and went to an 07 510, for the same reasons you are considering it.
The 510 sounds like it would be a pretty good "do it all" bike in your situation. If you did more street miles and very little tight trails, I'd say no way, keep the 650r (or go with a 610/630).
The 510 will not have that "no way I can break this thing" anvil type quality of the 650r. You will do more tinkering & maintenance.
If you go with the 510, plan on changing the counter shaft sprocket to suit your ride for the week/day. The bike has very narrow gear spacing. This is great for off road riding, you will always have a correct gear (or two).
I geared mine way up for a Baja trip, worked great. I will gear it down for local trails. Also you will need to budget an aftermarket seat and getting the suspension set up for you.
It is a bit vibey when riding on the street, but so is the 650r. Get vibranators to help with the bars.
http://www.vibranator.com/
I was able to get the hang of starting the 650r & I would buy one again, but...it was a handful in the tight stuff, just way too much bike for my lame skills.
The 510 is a pretty damn good "do it all" bike, even if it is on the "race bike with lights" side of the equation. If I did only single tract, I probably go with an even smaller bike (450/310?).
My 07 510 (carbed) is very easy to work on, so maintenance is a pleasure, not a chore. There are some tricks/quirks, like any bike.
An intangible: Most Husky owners are pretty cool (myself excluded..:) and CafeHusky.com is a great source for info/help.
Someone else mentioned the 610/630. Problem with these stellar bikes is that they weigh as much as a 650r. It would be a top choice for an "only one bike" bike, if you don't have a street bike.
Would I make the change again? Yes Do I miss my 650r? Sometimes, but never, ever in the tight stuff...
Scott in Sacramento
2007 Husqvarna TE510 gone :(
1970s Moto Guzzi
http://www.burtonco.com Sacramento Appraiser
NorCalslowpoke is offline   Reply With Quote
Old 03-15-2010, 08:28 PM   #86
2Plain
and simple
2Plain's Avatar
Oddometer: 15
Scott & Mercury264- Thanks for the great info and input!
Yellow Pig- Sorry for the unintentional hijack. I have read many of your posts regarding the 650r in the past....so was interested to read your impressions of the TE510. I just picked-up the 08 TE510......so will be following this thread with interest. Snow is still melting off in our area so local riding is a ways off.
Cheers
Old 03-16-2010, 07:49 AM   #87
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 7,576
Thanks for the compliments!
Once the darn snow clears here in Colorado and I finally get to do some real dirt I'll post a real write-up/comparo between the BRP and the Husky.
Till then I have to content myself w/ tinkering.
This weather is killing my wallet.
I'm headed to Moab in the end of April, that should provide for some proper proving grounds!
Old 03-17-2010, 08:44 AM   #88
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 7,576
Someone on TT finally found the correct testing RPM:
The SAE J1287 testing RPM it is: RPM = 250,000 / stroke (mm).
This is your standard- 45' angle 20" test in a clear area outside.
08-09Husqvarna TE250/310 55mm 4545
08/09 Husqvarna TE450 60.7 4118
08/09 Husqvarna TE510 67.8 3687
08/09 Husqvarna TE610 76.4 3272
Needless to say I was almost double the RPM range. I think that goes to show that even when within the minimum standard 96dB rating the bikes are loud. I don't know of anyone that rides at 3600RPM. So anything not meeting the minimum standard is ridiculously loud.
Yellow Pig screwed with this post 03-17-2010 at 08:49 AM
Old 03-18-2010, 09:57 AM   #89
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 7,576
So I just got done re-testing the Husky at the proper rpm (3650). I only tested the FMF Q4 with spark arrestor inserted and adjusted the other numbers mathematically using the difference I measured between dB at 6500 and dB at 3650 (6dB).
Not the most scientific way , but it gets me in the ball park and I did not feel like dismounting and remounting a bunch of exhausts.
Here are the results:
Old 03-18-2010, 09:59 AM   #90
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 7,576
Got some graphics to spiffy up the ugly tank:
Times are GMT -7.   It's 05:24 PM.
