07-27-2010, 08:44 AM
#106 |
Allergic to Asphalt!
Oddometer: 5,990
In the mean time I've upgraded the headlight to an 8" Trail Tech Race light which I have retro fitted w/ a Bi Xenon HID, a Baja Designs Yellow polycarb Shield and an H-4 7" Hella Hi/Low conversion. (The 7" adapter and headlight is made by Boatman on ADV)
![]() ![]() It takes a bit of finagling to get all the wiring tucked nicely away behind the headlight. Not much room back there to hide everything. ![]() I also used the HID ballast mounting plate to make a custom dash to hold the OEM speedo and a couple of switches and the keyed ignition. So far I've got the heated grips switch and a master light switch so I can turn off the lights. This came in handy this past weekend when I killed the battery trying to start the bike with it's hot start problems. ![]() Low Beam ![]() High Beam ![]() Note: I could initially feel the additional weight of the headlight up front, but after a few miles of recalibration that feeling has disappeared.
07-27-2010, 08:45 AM
#107 |
Oddometer: 5,990
So far I've gone 1150 miles on the bike and it has been lots of fun.
A Couple of thoughts on the bike so far: I checked the valves twice so far, at approx 350 miles and just yesterday at 1150, they have not moved a fraction of an inch and are still on the loose side of the speck. This despite having been flogged relentlessly in the Whitewash sand dunes, ![]() on the Colorado single track and despite running hot and having over heated several times. The seat mod w/ memory foam has turned out to be not so great. The profile and trim is perfect, but the memory foam material is not good. Rock hard when it's cold and way too soft when hot. Will have it redone in the same profile w/ some med. density foam. I'm not too fond of the close gear ration on the bike and wish it had a wider ratio, seems more practical for all around riding, plus you don't constantly have to shift gears to be in the sweet spot. The vibrations have not gotten any better, you just get used to them. This past weekend I rode my buddies 525 and was amazed at how smooth the bike is, much like my old XR650R. Why does a modern bike like the Husky have to vibe so much? That really made it hard to get back on the Husky. The Husky starter seems weak and anemic compared to the starter on a 525 which turns the bike over w/ vigor and decisiveness.
Yellow Pig screwed with this post 01-11-2012 at 04:21 PM |
07-27-2010, 10:34 AM
#108 |
Once you go Triple...
Oddometer: 20,420
My bike used to overheat a lot (it's what killed my 450) but since I added Engine Ice, a higher pressure rad cap (1.8 ?) and, most importantly, a fan (I just wired it to a manual switch - no thermostat so when the bike is running, I have the fan pretty much running all the time) and so far (touch wood) it's been fine and not overheated once and it's been pretty hot here of late.
What is the problem with hot-starting ? Does it not turn over (I had to use the manual de-comp on my 450 all the time to get the engine turning over but not so much on the 510) or does it turn over and just not start ? I was going to install a switch for the headlight like you but I was told (or read somewhere mebbe) that it wouldn't help since the lighting runs directly of the stator and so doesn't help charge the battery/give more power to the starter ![]() Good luck with both problems Edit: Sorry...should read your entire post before I post
'12 Tiger 800XC '07 TE510 '02 Sprint ST '99 XR650L '99 Speed Triple |
07-27-2010, 10:44 AM
#109 |
Twisted Throttle
Oddometer: 1,673
8000+ miles on my TE510 and never a problem with starting while warm nor any over heating in 90 to 100 temps.
Were you not the one that plugged your exhaust with something to quiet it down? Wondering if that is causing your overheat and starting issues with improper fuel metering ... What idle speed do you have your bike running at when warm?
11 Husqvarna TE630 11 Husqvarna SM630 08 Husqvarna TE510- sold 10 Yamaha FJR 1300 |
07-27-2010, 11:41 AM
#110 |
Oddometer: 5,990
I just have the FMF quiet insert. The Autotune in theory should adjust for any changes in the fueling since it's running on a wide band open loop O2 sensor.
07-27-2010, 12:11 PM
#111 |
Oddometer: 202
Thanks for all the updates. Im also running into the over heating issues. It seems my fan is on constantly whenever the weather is warm and im ridding single trail. Im sooo glad i have the overflow can since it boils over so much. I need to put Georges T inline and get the 1.8 rad cap and I think it will fix allot of my troubles.
The bikes always start up easy and the only time it has left me stranded was when the battery was super dead. I had to kick start it since starter would not crank. I got the smart idea to just kick start it and ride it around to charge the battery. I stopped for a second and the battery could not prime the fuel pump anymore and then it would not kickstart. I plan on carring a small jumper cable to prevent this from now on. my 09 TE510 only has around 1650 miles Autotune using o2 sensor puts the system in Closed loop. Closed loop uses the o2 sensor reading and constantly adjusts for changes.open loop saves the settings and works like a electronic carb(no o2 sensor). Weird how backwards it sounds huh
09 Te510, 01 KTM 640E, 05 TTR125L |
07-27-2010, 01:36 PM
#112 | |
Oddometer: 5,990
By the way there is a new High Flow Water pump out that has a re designed impeller thats flows much more water. The stock impeller looks like crap. The Husky POS on the left: ![]() Husky High Flow Impeller ![]() Now I just need to find out where to source one!
07-27-2010, 03:15 PM
#113 |
Oddometer: 20,420
Isn't there an argument that you don't actually want more flow - you want the coolant to stay in the radiator longer to give it more time to cool down
07-27-2010, 03:38 PM
#114 | |
Oddometer: 5,990
07-27-2010, 03:55 PM
#115 | |
Oddometer: 20,420
Please report back.
07-27-2010, 06:51 PM
#116 |
Oddometer: 202
That impeller looks very interesting. Thanks for the post, I might have to investigate that more. At this point the overheating issue is one of my biggest complaints.
07-29-2010, 10:17 AM
#117 | |
Twisted Throttle
Oddometer: 1,673
07-29-2010, 11:11 AM
#118 | |
Oddometer: 20,420
![]() That is mighty impressive Love to know if you've had any issues with it during that time ? Have you had to replace the cam chain/valves etc. ? How many times have you had to re-shim the valves ? Thanks
07-29-2010, 04:46 PM
#119 | |
Twisted Throttle
Oddometer: 1,673
http://www.advrider.com/forums/showthread.php?t=365470 .
07-29-2010, 04:52 PM
#120 |
Oddometer: 5,990
I'm at 1150 and just checked the valves for the 2nd time and they are still on the loose end of the spec.
