Old 01-21-2010, 06:59 AM   #46
Bob Tosi
Bob Tosi's Avatar
Oddometer: 1,607
thanks, got to get one of those. will this set up work on a 96 KTM 620 RX/C?
When you're lost in the wild and scared as a child. And death looks you bang in the eye, and your sore as a boil, its according to Hoyle to cock your revolver... and die. But the code of a man says "fight all you can" and self-dissolution is barred. In hunger and woe, its easy to blow... Its the hell-served-for-breakfast thats hard........Robert Service
Bob Tosi is offline   Reply With Quote
Old 01-21-2010, 07:03 AM   #47
Boatman OP
Upward and onward!!
Boatman's Avatar
Oddometer: 10,410
If you have the power to run the stock TrailTech Hella 4000 then you should be good to go. You can use any standard H4 bulb in this reflector or go with an HID set up for less power consumption.
What bulb is in your bike now?
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is online now   Reply With Quote
Old 01-23-2010, 08:23 AM   #48
skierd
Wannabe Far-Rider
Oddometer: 2,957
Boatman - I saw your photos here http://www.advrider.com/forums/showp...0&postcount=10
8" TT light
H4 conversion on hi-beam
Is it just the angle or does the H4 kit throw a bunch more light on high? Pretty interested in this kit...
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 01-23-2010, 09:07 PM   #49
Boatman OP
Upward and onward!!
Boatman's Avatar
Oddometer: 10,410
That's not a good side by side comparison,, the snow is making the H4 look brighter.
I took these tonight, you can see that as in quantity of light they are not too far apart, the H4 widens the beam some, whereas the 4000 is more of a spot.
Hella 4000 Euro halogen...
H4 conversion Hi beam...
and for giggles, Hella 4000 Euro HID...
Old 01-30-2010, 05:33 PM   #50
Boatman OP
Upward and onward!!
Boatman's Avatar
Oddometer: 10,410
Been working on a cover for the TT lights,,, getting close. I have the shape worked out just need to perfect the thermo forming. The sample has a couple obvious flaws.....
Stock TT light....
My H4 conversion...
Profile....
Old 02-17-2010, 09:41 AM   #51
950TRANSALP
950TRANSALP's Avatar
Oddometer: 794
Cool2 $376.00 each
Checked price on these yesterday .... local NAPA is a dealer .
I can't imagine them putting out as much light as an HID .
Vibe proof , lite weight , no ballast .
Thin profile less than 4 " thick .
h mmmmm
Originally Posted by Yellow Pig
Here is what you need to put in it:
Truck Light's 12V LED Headlight w/ High and Low beam. This new and exciting LED Headlamp innovation provides a new level of performance for 7” round forward lighting 12 volt applications, offering the extended life and energy efficiency of light emitting diode technology.
Product Specs:
-Hard Coated Polycarbonate Lens
-Anodized Aluminum Housing
-Metalized Reflector
-Encapsulated circuitry
-Each light contains 10 High Output Light Emitting Diodes (LEDs)
-Designed at 12.8v
-4.5a (High Beam)
-2.5a (Low Beam)
-Operational temperature range of -50C to 70C
-Overvoltage spike protection to 600v
-Constant output
The translation of forward lighting to a 12 volt LED headlamp application means brighter, crisper and whiter light output than incandescent alternatives, while offering longer life and greater dependability that has since become standard for LED signaling and marking products. The 7” round LED Headlamps feature solid-state circuit board assemblies for unrivaled shock and vibration resistance and hard-coated polycarbonate lenses that offers 30 times more impact strength than glass. All of these key features work toward a desired goal among end user’s, achieving a maintenance free system.
The 7” round white LED Headlamps meet or exceed all applicable Department of Transportation (DOT) requirements pertaining to headlights, one of the most difficult standards to achieve. Truck-Lite has been able to successfully develop a perfect blend of thermal management and light output to produce an aesthetically pleasing beam pattern through innovative precision optics. The new LED headlamps are designed to replace any standard 7-inch round headlight within 12 volt applications. They can be aimed using standard mechanical aiming equipment.
Made in the U.S.A., each headlamp uses ten high output LEDs as its light source, with a light output brighter than traditional glass beam headlights, which results in better visibility. While a typical headlamp may be rated to last as little as 1,200 hours, Truck-Lite LED Headlamps are expected to exceed that by as much as 50 times. The LED technology used in Truck-Lite’s Headlamps will offer improved visibility over conventional incandescent, as the color temperature of the assembly is around 5000K, far closer to sun light than incandescent or halogen lamps.
"The more you drive the less intelligent you are !"
Repo Man - 1984
950TRANSALP is offline   Reply With Quote
Old 02-23-2010, 04:35 AM   #52
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,207
Another Order In
and will want the lens pro when you get that sorted.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 02-23-2010, 05:41 AM   #53
Boatman OP
Upward and onward!!
Boatman's Avatar
Oddometer: 10,410
Thanks for the order.
I'll get back to working on the protector this week. I need to rethink my vacuum forming rig to get a consistant product. Right now I have about 4 failures for each success.... gets costly pretty quick.
Old 03-24-2010, 10:51 PM   #54
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
Looks great. Did I miss the price on a non powder coated version?
cj
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 03-25-2010, 05:21 AM   #55
Boatman OP
Upward and onward!!
Boatman's Avatar
Oddometer: 10,410
cj
Hi cj,
No you didn't miss the price. For a raw finish setup the price will be $95 shipped.
Old 03-25-2010, 08:58 AM   #56
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
Great, Thanks.
So I take it you just order the Frame from TT, not the entire light kit.
Last question for now.
Do you have a parts # list for the TT items needed?
Old 03-25-2010, 12:45 PM   #57
Boatman OP
Upward and onward!!
Boatman's Avatar
Oddometer: 10,410
Great, Thanks.
Trail Tech will not sell you just the frame/mount,,,,, been through this with them.
Check your PM's.
Old 04-02-2010, 11:55 AM   #58
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,460
I get the next one!!!
PM sent
Barron is offline   Reply With Quote
Old 04-02-2010, 06:53 PM   #59
Boatman OP
Upward and onward!!
Boatman's Avatar
Oddometer: 10,410
Originally Posted by Barron
PM sent
PM replied to.... sorry for the delay,, I've been on the road.
Scott
Old 04-06-2010, 03:23 PM   #60
motolocopat
When in doubt gas it!
motolocopat's Avatar
Oddometer: 519
I Don't Understand
Excuse my ignorance but I don't understand how 7" = 8" or how a size 7 will fit in a size 8 without bulging out... Does the 8" Race Light by virtue of being a "Race Light" and racing stuff being lighter somehow fit in a 7" space? Inquiring minds want to know..
Funny thing is I do not have an 8" race light!
I like the product so much I was afraid it would sell out and I would not be able to get it in the future when I do convert to the 8" race light.
I plan on trying out one of these crazy expensive Truck Lite 7" LED headlamps in a Trail Tech 8" Race Light w/ your adapter ring.
How has the Truck-Lite LED worked out?
Steaks Medium Rare, Red Wine, V-Twin Road-Bikes, 4-Stroke Dirbikes, V8 RWD Cars, American 4X4 Trucks...Endless Roads with Motoing Amigos
Un Moto Abrazo
Keep the Shiny Side Up
www.moto-loco.com
motolocopat is offline   Reply With Quote
Times are GMT -7.   It's 07:41 PM.
