Old 12-12-2009, 01:44 AM   #1
Nailhead OP
Painting by numbers
Nailhead's Avatar
Oddometer: 5,387
This Jeep Blows...
A friend of mine made this. Harry lives in the foothills of southeastern Wyoming where the snow and the wind conspire frequently to make roads impassable.
[IMG][/IMG]
Harry bought the snowblower at a government auction somewhere, and the Jeep somewhere else. The Jeep has a 350, and I don't remember what year it is. He devised hydraulic actuation for lifting the snowblower, and for rotating the discharge chute. To power this, Harry mounted an additional power steering pump modified for extra fluid capacity. The horizontal radiator hose seen on the far side of the engine is this modification:
[IMG][/IMG]
The snowblower is shaft-driven off the PTO to the pillow blocks visible next to the discharge chute, with the shaft having an ample slip joint to enable lifting the unit. The pillow blocks allow chain drive to the snowblower input shaft:
[IMG][/IMG]
At the time I took these pix, this was a work-in-progress so several of the above components were missing. Another view of the drive & lift mechanism:
[IMG][/IMG]
The actuator cables leading to the valve assembly where the bumper should be are connected to these levers:
[IMG][/IMG]
I've seen those levers do their thing, and this machine has amazing potential. The unit is designed to remove in 1/2 to 1 hour, so it doesn't render the Jeep useless in the summer. This includes removing the Vermeer counterweights in the back.
This man is a good friend and a talented fabricator with an amazing head for solving problems mechanically. He should be proud of this creation.
[IMG][/IMG]
-Chris
'04 GS Adv- A fond memory
'07 990 Adventure- still bonding...
How hard can it be? - Jeremy Clarkson
Nailhead is offline   Reply With Quote
Old 12-12-2009, 05:59 AM   #2
dentedvw
Where did I put that
dentedvw's Avatar
Oddometer: 2,014
Wow, fantastic creation.
"Even though my trip turned out badly, I don't regret the kind of life I chose to live. Adventure!" RIP-Clay Schwartz 9/14/07
The bike never has been, never is, and never will be the limiting factor in my, your, or anyone else's ability to have an adventure. -jake28-
dentedvw is online now   Reply With Quote
Old 12-12-2009, 06:09 AM   #3
mmitchell57
Vulcan Halfbreed
mmitchell57's Avatar
Oddometer: 2,193
Send a message via AIM to mmitchell57
That's pretty cool!
Projects - www.Goomra.com
1969 CB350 - Restoration Project
1962 Ford Fairlane 500 - Restoration / DD project
mmitchell57 is offline   Reply With Quote
Old 12-12-2009, 06:46 AM   #4
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 4,733
I guess he knows it won't rock crawl worth a damn now.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is online now   Reply With Quote
Old 12-12-2009, 06:52 AM   #5
Jungle Jim
buckle up buttercup
Jungle Jim's Avatar
Location: New Jersey - That's OK, we don't like you either
Oddometer: 9,720
very cool
thanks for sharing
post some pics of it in action if you can
and give your pal a pat on the back from me
Jungle Jim is offline   Reply With Quote
Old 12-12-2009, 12:57 PM   #6
comes naturally
renewed hope
comes naturally's Avatar
Oddometer: 1,891
Very cool!
comes naturally is offline   Reply With Quote
Old 12-12-2009, 02:49 PM   #7
Nailhead OP
Painting by numbers
Nailhead's Avatar
Oddometer: 5,387
It actually does OK even with the snowblower on: he took it to town to finish it, and in order to do so he had to drive it out of the canyon over a rather gnarly road because his neighbors are mental patients who keep fucking with his easement. I watched through my rearview on the way out, and that Jeep had no trouble at all.
Bear in mind that whole snowblower comes off quite easily for rock work.
-Chris
Old 12-12-2009, 02:53 PM   #8
Nailhead OP
Painting by numbers
Nailhead's Avatar
Oddometer: 5,387
Originally Posted by Jungle Jim
very cool
thanks for sharing
I will gladly do both.
Check out another of his creations in the Cool Trucks thread-- it's an M715 with a dump bed and some other trick mods.
-Chris
Old 12-12-2009, 03:30 PM   #9
AkBrian
Oddometer: 7,669
Nice work!
AkBrian is online now   Reply With Quote
Old 12-12-2009, 04:24 PM   #10
TALLGUY
TALLGUY's Avatar
Oddometer: 341
Pto
Maybe i just cant see but was this jeep already equiped with a PTO in front or what exactly powers it? Is the PTO also hydrallically driven from the extra power steering pump, or is there a PTO off the transfer case??
Oh yea, very nice and practical idea. I have seen the same only with a small motor mounted right on the blower and snowplow brackets for lift.
Who are you, Ernest Hemingway?- Campari
Nobody pretends to be from Iowa.- WaterWheel
TALLGUY is offline   Reply With Quote
Old 12-12-2009, 05:09 PM   #11
Carlo Muro
Supercàzzola
Carlo Muro's Avatar
Oddometer: 1,798
That was my question exactly. This model CJ (76+) would not have had a PTO from the factory. Nothing a good fabricator couldn't work around though.
Carlo Muro is offline   Reply With Quote
Old 12-12-2009, 05:27 PM   #12
Nailhead OP
Painting by numbers
Nailhead's Avatar
Oddometer: 5,387
It is PTO driven from the transfer case, and Harry went through several PTO's before he found one with the right height.
-Chris
Old 12-12-2009, 05:57 PM   #13
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 4,733
Nice job, sure beats freezing your ass off on a tractor.
N. Texas
Old 12-12-2009, 05:59 PM   #14
Nailhead OP
Painting by numbers
Nailhead's Avatar
Oddometer: 5,387
He put an additional heater in it, also.
-Chris
Old 12-12-2009, 06:11 PM   #15
A-Bone
Indubitably
A-Bone's Avatar
Oddometer: 11,627
Bitchin.... That thing needs a write up in Shed Magazine....
A-Bone is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 03:38 PM.
