Old 09-20-2004, 09:00 AM   #1
TEXASYETI OP
Call me "thread killer!"
TEXASYETI's Avatar
Oddometer: 1,898
R100GS output shaft bearing, fact or fiction?
I've owned three GS's in the past with 2 having problems with the output shaft bearing in the tranny. One exploded in Miami, leaving me stranded for a week while another was replaced - along with a retrofitted output shaft w/ c - clip - during a two month trip last summer. Any one else have this experience(s)?
TEXASYETI is offline   Reply With Quote
Old 09-20-2004, 04:36 PM   #2
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,270
Most likely caused by the lack of the circlip on the output shaft, allowing too much end play, thus tearing up the bearing. For more details, check out:
http://home.jps.net/~snowbum/transmission.htm
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 09-20-2004, 08:55 PM   #3
twowheels
Leaving Children behind
Oddometer: 200
fact
OUtput bearing failure is not uncommon. Though the mileage tends to be high. I'd consider it preventative maintenance to replace the bearing or put in a circlip.
twowheels is offline   Reply With Quote
Old 09-21-2004, 08:43 AM   #4
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,270
I concur. If you're tearing into the tranny at all, replace all seals and bearings, and make sure the output shaft gets the groove for circlip (and install the circlip!). The time and effort required to remove and disassemble the tranny, as well as re-shimming the rear cover, more than makes up for the cost of bearings and seals....
Cpt. Ron
Old 09-21-2004, 03:20 PM   #5
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,336
Been there, done that...Circlips and their grooves are a must if you ever crack the tranny case open. I had mine rebuilt with the groove and a taller 5th gear at the same time by an independent wrench in San Jose Ca. for about $250 plus parts.
I heard a well placed source mention that there were some of the later model R100GSPD Classics that had the circlip re-installed from the factory.
Cheers,
JOrge
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"."
HST-RIP
"Woof, woof woof woof ...woof woof!!!!!!!!!"
Cricket the Dog-RIP
Rubber Cow is offline   Reply With Quote
Times are GMT -7.   It's 04:22 PM.
