Old 10-08-2011, 08:59 AM   #541
randyo
randyo's Avatar
Oddometer: 1,725
Originally Posted by Dysco View Post
I don't think the hole size matters too much if the rubber is pliable enough.
when I studded my Karoo Ts a couple years ago, I hooked up with someone on another forum that had a stud gun, it was his 3rd season on studs, first year he was on Aerostitch studs
when I went to his house, at the end of the day, he said the Karoo Ts were the hardest rubber that he had studded, I know we didn't use a bit larger than 1/8"
I think larger holes accept studs easier, it took a good 100 miles of riding to get the studs seated in all the way, the first 50 miles or so was real sketchy riding, but as they got seated, you can hardly tell the difference
in my front tire, I have about 9000 miles on it and its at about 50% wear, haven't lost any studs on the front tire, I did loose a few in the rear and it's at about 30% tread after one winter season (5000miles) and threw 3 or 4 studs,
still debating if I'm gonna use the front another season @ 50% or get a new front, I'm thinking trying the Aerostitch studs, expensive, I won't be going back to a motorcycle tire in the rear ever for winter, the car tire is just too good in winter conditions. but I may go from the unstudded General Altimax Artic to a studded Nokian Hakappelliitta
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
A man with a gun is a citizen
A man without a gun is a subject
randyo is offline   Reply With Quote
Old 10-08-2011, 10:18 PM   #542
FloorPoor
Oddometer: 712
Has anyone tried a Shinko 244? They have a similar tread pattern as a K270, but are quite a bit cheaper. They also have very good reviews for traction and longevity on bikebandit. I like the 270, but just ordered a 244 front to try(non studded for now) because it was cheaper shipped, than the 270 before shipping. They have gone up in price $10 since the last one I ordered.
As far as the T-63 is concerned, I have one that was ridden about 800 miles and taken off of my friends DR 650 (he is a little odd and won't continue running a tire that has had a puncture) What is the minimum tread depth to studd this tire? 10mm? I have never run a T-63 on my bike, but rode friends with them and they seemed to work quite well, and the price is good. The only problem I have seen with them is the stiff carcass. The same friend who gave me the tire had a flat on a ride and it was a BITCH to get the bead to break, and a PITA to get it to seat again.
"You can have anything you want, but not everything you want."
"There's nothing like that fresh tire feeling "
FloorPoor is offline   Reply With Quote
Old 10-09-2011, 05:22 AM   #543
luke-gr
Oddometer: 9
Randyo, thanks for your input. Maybe I'll take a look at the Karoos again due to your mileage. Id be using the Karoo2 on the KLR. Assuming those would work OK. Sounds like Im being a little too paranoid about putting mileage on the studs and wearing them out.
I think FloorPoor and I are having the same question about how to determine if a stud will work and determining the correct length? Do I simply measure the height of the knob and get studs that are that length or less or can the stud sit into the carcass of the tire a bit?
Money is certainly a consideration for me but I dont want to get into a situation where I have a tire that wont work and I'll pretty much be buying on others recommendations. I dont think my local dealer carries Shinkos.
Thanks for all your input.
luke-gr is offline   Reply With Quote
Old 10-09-2011, 11:38 AM   #544
randyo
randyo's Avatar
Oddometer: 1,725
almost every report I've seen and my own experience is that studs increase the tires tread life
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
Old 10-09-2011, 07:28 PM   #545
Dysco OP
Whackaducker
Dysco's Avatar
Oddometer: 16,266
Yes... sorta. I managed to stud a 10" trials tire to put on my scooter a few years back. Those were maybe 8mm, but very pliable.
The rear T-63 has a deeper tread than the front now that I've looked at it. The rear might even hold a 12, but the front is pretty shallow. Still haven't measured it.
Dysco is offline   Reply With Quote
Old 10-11-2011, 04:12 AM   #546
luke-gr
Oddometer: 9
Understood. Ive seen that for sure in my truck tires in the past. Not sure why I have been previously determined to install them on another set of wheels. :shrug: Other than mounting/ dismounting at for the season.....I may end up only with an extra front. I suppose it is safer to just put them on at the first sign of snow/ice that way there are no surprises. I suppose I was thinking of trying to keep the studs fresh so they were there when I needed them but probably being neurotic over nothing. I do put 1500 miles a month on the bike right now.
But you still feel like it'll accept a stud? My local tire store doesnt carry anything smaller than a #12 which is 11mm long. But, Im sure they would order for me. I really like the idea of something more along the T63 or a Karoo which hopefully will give me some better mileage and ride better particularly if I install the tires and leave them on. Do I measure the tread depth and that is the longest stud that will fit? Or is there some margin there? Say the front tread groove is 10mm, is that the max length stud that will work? I think that is my final question (cheers from the gallery :))
Old 10-11-2011, 07:26 AM   #547
randyo
randyo's Avatar
Oddometer: 1,725
my office is out in the barn, so I don't have a regular commute, I usually put my studded tires on right after thanksgiving, sometimes we have snow/ice earlier, I do have a Jeep if necessary, but a little snow won't stop me without studs, specially with the car ire on back, I've been runnin an unstudded Karoo 2 all summer, almost time to turn it around and run it backward
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
Old 10-31-2011, 11:42 AM   #548
pjm204
Oddometer: 2,003
I took a little snow ride Saturday on the Strom. I was impressed how well it handled. I do think I'd like to look into some studs for this winter. I didn't use any last winter and the KLR and I probably should have. Though I try not to ride when there is snow on the road.
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 11-01-2011, 11:14 AM   #549
ride4321
ride4321's Avatar
Oddometer: 1,966
Is anyone using ACF-50 to protect their bike from salt and corrosion? The few places I can find it online want almost as much to ship it as it costs ($11.00). I'd like to coat both of my bikes before winter.
http://www.skygeek.com/acf-50.html
Don't you know there ain't no devil, it's just God when he's drunk.
Tom Waits
ride4321 is online now   Reply With Quote
Old 11-01-2011, 05:45 PM   #550
luke-gr
Oddometer: 9
I saw that ACF50 mentioned somewhere in my recent searching....probably on this site. Dont remember seeing much commentary about it. :shrug:
About my tire studding...
I bought a Kenda Trakmaster and had three test studs inserted. Seemed to work fine. Ive now drilled the 90% of the rest that I am going to do (had to stop to fix the switch on my drill). I'll get it back to the shop to finish the other studs on Saturday. I drilled more knobs Dysco did on his tutorial page. I feel OK about that since I have two front wheels so will switch during dry spells.
I did notice some cracking in the rubber around the studs now that the tire has set for a couple days. Does that mean my holes should be a little larger? The guy who installed them did dip the tip of the gun in lube.
Old 11-01-2011, 07:07 PM   #551
randyo
randyo's Avatar
Oddometer: 1,725
some crack is ok as long as the studs are still tight
at least it was with my Karoo Ts, in front, 2 full winter seasons, 10,000 miles. haven't thrown a stud on the front tire down to about 40% treadlife
rear was toast after 1 season, it threw a couple studs as well
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
Old 11-01-2011, 07:42 PM   #552
MoBill
Smiles when says dat
MoBill's Avatar
Oddometer: 13,725
Yes, I was the guy talking about ACF 50...
I use it...one of our air crew guys swore by it too...I sprayed it on in Oct/Nov and cleaned the bike again in March. Just don't get it on the rotors. too slick.
www.skygeek.com
Also, here: http://www.advrider.com/forums/showt...488842&page=19
MoBill is offline   Reply With Quote
Old 11-02-2011, 05:32 AM   #553
Ceri JC
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
ACF-50 is great. It is very common amongst all weather bikers in the UK where our governments cover the roads in grit and salt that can corrode bikes very quickly. It is expensive compared to, say WD-40 or vaseline, but it works well and saves you a lot of time cleaning/reapplying as it stays on far longer than the alternatives, even when ridden regularly in driving rain/snow.
Process is: Clean your bike properly just before winter and then absolutely douse the bike (brakes aside) in the stuff. It should feel a bit slimy to the touch, even once dry if you've put enough on. End of season, give it a thorough washing off and cleaning. The dirt and crap from winter will come off with what is left of the film of ACF-50. If you experience especially long winters (or are particularly fussy about how your bike looks) repeat this process mid winter.
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is offline   Reply With Quote
Old 11-06-2011, 06:22 AM   #554
luke-gr
Oddometer: 9
Advice for switch on electric vest
I have a Saingear vest which Ive had since 1993 or so. It did not come with a switch. The SAE plugs are not easy to unplug on the fly. Wondering if anyone has a suggestion about adding a switch to it? For sake of simplicity and (especially) economics I'd just like an on/off switch.
I looked around the auto parts stores where there are a multitude of switches but all are designed to be panel mounted not mounted inline in a wire. Lowes Hardware has a rocker switch designed for lamps but I know it is not water proof. Not sure how big of an issue that really is??
Any advice would be appreciated.
Old 11-10-2011, 07:00 PM   #555
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Originally Posted by Alcan Rider View Post
If not, out comes the rubbing alcohol for some uses, cheap waterless hand cleaner for others. The latter is one of the best lubricants for seating the bead on a tire. Learned that from one of the tire shops in Anchorage many years ago.
That's a great tip on the hand cleaner. Widely available in small bottles, and serves double duty in a tool bag, too.
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Times are GMT -7.   It's 10:22 AM.
