01-12-2012, 07:20 PM
#571 | |
Con Brio!
Oddometer: 605
cheap heated vest switch
01-12-2012, 07:32 PM
#572 | |
Con Brio!
Oddometer: 605
non-electric hand warmers
![]() If that's not enough, then just tweak your existing gear: (heated grips, Hippo hands) with gerbing electric glove liners inside army surplus winter arctic mitts. That will let you ride in any temperature you'd ever think of wanting to do. Might need to duct tape the seam between the mitts and your jacket to avoid cold air leaks, but you'd be totally set for anything not completely insane.
01-15-2012, 02:52 AM
#573 |
Oddometer: 353
I am about to go out in -10c .i just bought W&S heated gear- hopefully it will do the trick
01-16-2012, 04:44 AM
#574 |
Von Hochstaden's son
Oddometer: 45,093
That is cold .
mikuni vm32-33 both sides :\ 5000 feet altitude/ 140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide 35 mpg around town riding like a asno |
01-16-2012, 08:39 AM
#575 | |
Oddometer: 810
with choppers mitts, they work great, no where to fit them in a pair of tight fitting gloves or boots I keep a few on hand as an emergency measure if my heated gear should fail
RandyO IBA # 9560 07 VeeStrom 99 SV650 82 XV920R A man with a gun is a citizen A man without a gun is a subject |
04-23-2012, 05:10 PM
#576 |
Oddometer: 9
Thanks for the replies
I wandered off after I didnt get a quick reply, sorry. :)
I made it throught the winter fine. Ive put just over 16K on my KLR over the past year. Studded tires were barely needed with this warm winter but Im sold on them. Awesome traction. I was concerned about traction on dry pavement but see it is no big issue (for me on my bike anyway). I have seperate rims and will swap them out next year as the knobbies with studs just dont last long. Never did put a switch on my vest but did end up buying a cheap lamp type switch on Ebay. I rarely used the vest anyway and when I do, it's cold enough to leave it on. I bought a Firstgear Thermo suit which worked quite well for me. Ive certainly done my share of layering. I work on Grandfather Mountains part time as security and left one morning at 4.8F for the 25 mile trip home. Not too big of a deal except for my hands. Ouch! My KLR has aluminum bars (installed by previous owner). I did wrap left bar with a couple wraps of duct tape before installing Kimpes heated stick-ons. Ive come to realize that aluminum is much more of heat sink than steel. Noticed Hot Grips site doesnt even recommend putting their products on aluminum bars. Wondering if it would be worthwhile to change out the bars back to a steel one? Any thoughts on that (Grasping at straws?)? Wondering if the Oxford grips would be better than what I have? Really dont want to throw money at this as I'd say that heated gloves or liners would solve the problem but really hate to deal with the wires every day as this is my daily driver. I was thinking about the Firstgear liners from my local dealer. Here's to warmer weather.......
11-25-2012, 06:54 PM
#577 |
caddis muncher
Oddometer: 14,879
Bump for the warmest winter weather I've seen!
11-27-2012, 06:54 PM
#578 |
Oddometer: 94
Just ordered 200 4706 studs and a new set of Dunlop 606s...............bring on the crappy weather.
Canadian FJR |
11-28-2012, 09:12 AM
#579 |
Oddometer: 0
Dysco - Apologies if you already covered this, but I've got a question for you. In your original post you said you preferred heavier dual sports to lighter ones for use in the snow. Since then it looks like you've also tried your hand with lighter, smaller displacement bikes too. Having tried both, what are your thoughts on heavy vs. light bikes in the winter?
12-18-2012, 10:11 PM
#580 |
CUSTOM USER TIT-LE
Mid december bump
going to use all my "mental energy" (as the orientals call it ki) to keep it from snowing. It's going well in the northeast poconos here. I live in the mountains. No snow, although they are calling for a winter event this weekend.. I'm sure alot of you guys in different parts of the country will get alot. bike has been down for a month, it shall be operational again tomorrow. Can't wait to ride. |
12-18-2012, 10:59 PM
#581 |
Oddometer: 825
Racing to get some fresh rubber on the rear before the blizzard hits Thursday...
'06 F650GS Dakar "I never saw no miracle of science That didn't go from a blessing to a curse I never saw no military solution That didn't always end up as something worse" |
12-21-2012, 02:32 PM
#582 | |
caddis muncher
Oddometer: 14,879
![]() Lower would be better for the WR250R, but it's more fun to get squirrely with. I think a lot of it depends on the tire profile- some tires are pointy and sketchy, others are a little flatter and comfy. I did not love the Trakmasters I put on the WRr, but the two rear Trakmaster's worked fine on the F650gs. I'd be interested in trying it with a T43 on the WRr. That might be worth a try down the road. |
12-29-2012, 04:02 PM
#583 |
Oddometer: 1,138
I'm a bit late, but have a new set of 606's in the mail, should be here on thursday. I'm just going to get a local shop to stud them for me, I figure on just getting normal automotive studs. 13mm seems to be what most here are using, I'll run to the shop on monday and see what they have.
I saw here somewhere that I should drill the length of the stud? Shouldn't I stop a bit short, maybe 1/8" or so, to leave some stick out? Next is another oil question- What do you guys do for chain lube? They use salt here on the roads, I imagine the chain is going to need lubed daily. ATF? Used motor oil? I typically just use regular chain lube, but I can see that getting expensive quick. Bike is a KLR650. Thanks. |
12-29-2012, 10:09 PM
#584 | |
caddis muncher
Oddometer: 14,879
Lube the chain frequently, then spray it off with warm water and re-lube when it's above freezing. |
12-29-2012, 10:40 PM
#585 |
Oddometer: 825
Pondering helmets again...
I did a couple 90 mile trips this week in the teens and 20s F. Electric boot insoles and electric grips with bar muffs kept me in a decent comfort zone, but the freezing airflow across my eyes seems like the most fatiguing element. I looked real hard at the Ski-Doo BV2S last year, but just can't afford $400 for a 3 month a year helmet. So i'm thinking about an electric face shields as it would only be $60 to add to the IS-Max I'm using. Beyond keeping snow and fog off the shield (my pinlock/breathmask combo are doing fine at that), does a heated shield do much to keep the air around your face any warmer? I would assume so but since these helmets are designed to have slight airflow even with the vents closed i'm wondering if air circulates too quick for the heat from the shield to affect it...?
