Old 01-01-2013, 07:58 PM   #586
Moparmanpete
Support all riders
Moparmanpete's Avatar
Oddometer: 294
I bought a set of Tusk handle bar muffs (like hippo hands) but haven't used them because I think they would drag the front brake with the wind pushing against (I can hear the brake light switch activate) them since I have yet to get brush gaurds.
Do they and is there a fix before I get the gaurds?
Pete
"The reward is in the doing of it" "If you don't go when you to want to go, when you do go you'll find you've gone" BM
08 Wildfire 150 Scoot "The Virus"
The Virus's RR http://advrider.com/forums/showthread.php?t=826703
87 XL600R "The Cracken" deceased till further notice
Moparmanpete is offline   Reply With Quote
Old 01-02-2013, 07:03 AM   #587
jules083
jules083's Avatar
Oddometer: 3,799
Pete
Sounds like you would need some sort of support then. If they are that close I would think it would be difficult to grab the front brake also, considering that you'll probably have heavy gloves on.
Maybe build a barkbuster type support? It wouldn't have to be real heavy, just enough to hold the mitt away from the bars a bit. I'm picturing a piece of flat stock or tube that bolts to the master cylinder area and extends out in front of the lever.
All typos and misspellings blamed on my phone.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Old 01-02-2013, 09:46 AM   #588
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
If you're going with some cheapo muffs, you just have to kludge up something that will stick out further than the levers.
If you pay extra to go with someone who makes them for motorcycles like Hippo Hands, they should be able to give you an easy and reliable solution...
'06 F650GS Dakar
Those who believe you should always error on the side of caution usually become comfortable making errors and before too long know of little else.
Don Coyote is offline   Reply With Quote
Old 01-06-2013, 08:55 PM   #589
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Pete
You can try adjusting your lever downward to some degree, that way the wind pressure will not be applying force in the identical direction as the lever actuation. Of course, make sure it still does the job you need it to do in that position... (the lawyers made me say that).
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 01-06-2013, 09:25 PM   #590
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
Seems to me you'd still have to fight wind pressure just to get your fingers between the muffs and the levers, likely to bring some butt puckering moments if not worse...
'06 F650GS Dakar
Old 01-06-2013, 09:33 PM   #591
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
How fast are you going?
I'm sure every configuration varies, but I've never had any problem with the skidoo muff mitts on my 800gs. They rest against the brake lever at speed, but don't actuate the switch due to the angle. Hands get to the levers no problem.
Go out at night for a quick spin, you'll be able to see whether the brake lamp is lit while you're riding.
Nate in N.E.
Old 01-06-2013, 09:34 PM   #592
Moparmanpete
Support all riders
Oddometer: 294
I tried them for about 50miles yesterday of an 80mile ride varying speeds, hands were warm but they definetly were pushing the levers and didn't want to stay in one place. I might try them again when I get some brush guards.
Old 01-06-2013, 09:38 PM   #593
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
Originally Posted by MitchG View Post
The answer is no, it will not contribute any measurable warmth inside the helmet. That being said, to keep your face warm you must minimize air flow inside the helmet as much as possible(read good sealing in the neck area). Unfortunately, now that you've stopped the air flow and your face is warm, your shield will start to fog. This is why you need a heated shield.
Just noticed you are using a breath mask. These things are a must, and work unbelievebly well. Thought I needed some new ones so I went to nofogusa.com and low and behold, they have a heated version now: www.nofogusa.com/Optional%20Heat.htm Cool!
Well, the HJC IS-Max with pinlock, breath mask, and chin curtain all in place actually do take care of all of this. Problem is the chin curtain folds up on the breath mask, which is how i've been using it. I thought there were other vents letting in air, but after your comment tried unfolding the curtain to fully cover the bottom and it seemed to stop the airflow entirely. Unfortuantely it takes a while to futz with the curtain every time the chin bar is lowered and it frequently pops out requiring the entire helmet to be removed for replacement.
With everything in place though, the only thing that fogs is the internal sun-shield occasionally...
'06 F650GS Dakar
Old 01-06-2013, 09:41 PM   #594
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
Just thinking of Pete going fast enough to actuate the levers...
'06 F650GS Dakar
Old 01-06-2013, 09:48 PM   #595
Moparmanpete
Support all riders
Oddometer: 294
At 55mph it was turning on the brake light, at 80mph the brake drag was noticable. The wind keep pushing the muffs down and I had to keep readjusting the left one which was a PITA and the reason for taking them off. Was nice to wear summer gloves though. but in the end my winter gloves did just fine.
Old 01-06-2013, 09:50 PM   #596
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Sounds like comprehensive testing.
Nate in N.E.
Old 01-06-2013, 09:54 PM   #597
Moparmanpete
Support all riders
Oddometer: 294
I liked them enough to keep them and I would like to try them again with some hot hands in them, for the really really cold stuff
Old 02-07-2013, 09:34 PM   #598
Keithert
Oddometer: 871
I went for my first ride in the snow tonight on my XT225. I had my feet scraping the ground like outriggers in case I started to slide. I was on a road with 2-4 inches of snow. I did put my feet on the pegs some but was worried about getting them down if I started to slide. I was only going about 10 mph in first gear. I'll have to read the thread but am also looking for current tips.
Keithert is offline   Reply With Quote
Old 02-08-2013, 08:17 AM   #599
randyo
randyo's Avatar
Oddometer: 1,689
ya, keep yer feet on the pegs, be one with the bike
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
A man with a gun is a citizen
A man without a gun is a subject
randyo is offline   Reply With Quote
Old 02-08-2013, 08:44 AM   #600
Moparmanpete
Support all riders
Oddometer: 294
And don't crash!
Find a big empty parking lot and just ride around, Less worry about getting run over from behind, just like if you were learning to ride for the first time, practice accelerating, braking and turning and feel for the tires slipping
Times are GMT -7.   It's 06:33 PM.
