Old 10-20-2010, 07:55 AM   #181
SaferMoto
SaferMoto's Avatar
Oddometer: 269
Originally Posted by Vertical C
Hey safermoto
Does the vest go under you normal jacket, how thick is it deflated? Just wondering how much room it takes up.
Also do you have pics of it inflated? How does it protect the neck from under the jacket?
The vest should always be wore over your normal jacket. If you follow the link I posted in the previous post there are 3 videos which show you fitment, deployment and re-packing
There are also a host of videos on YouTube if you search using safermoto
let me know if you have any more questions
www.SaferMoto.com
Authorized Dealer of Hit-Air brand Airbag-equipped jackets and vests.
Special Discounted Pricing for ADVrider members use the code ADVRider1 at checkout
SaferMoto is offline   Reply With Quote
Old 10-20-2010, 10:21 AM   #182
TallRob
TallRob's Avatar
Oddometer: 1,395
the japanese hit-air videos are awsome! Just saw one where a guy is demobstrating a vest inside a department store while another guy is making motocycle sounds. classic! but its actually a good vid because it shows the guy jumping off the bike and the vest clearly inflating very quickly.
TallRob is offline   Reply With Quote
Old 10-20-2010, 10:25 AM   #183
SaferMoto
SaferMoto's Avatar
Oddometer: 269
Here is a link to a "Scottish" hit-air video
NV New Model
www.SaferMoto.com
Old 10-27-2010, 08:56 PM   #184
SaferMoto
SaferMoto's Avatar
Oddometer: 269
Website changes, new look and new shopping cart
http://www.safermoto.com
Your opinions are, as always, appreciated
www.SaferMoto.com
Old 12-20-2010, 04:20 PM   #185
testrider
Oddometer: 118
What exactly is the difference between the MLV-Y and YS?
Thanks.
testrider is offline   Reply With Quote
Old 12-20-2010, 04:45 PM   #186
SaferMoto
SaferMoto's Avatar
Oddometer: 269
Cool2
Thanks.
The YS is a "full" vest with mesh panels and 2 pockets. The MLV-Y is a high vis version of our lightweight vest. If you wear a jacket with a lot of pockets, like a Belstaff or Kilimanjaro then the MLV-Y allows easier access to your jacket pockets.
If you wear a jacket that just has a few pockets then the YS is a good bet as it gives you "external" pockets to use.
The MLV-Y is lighter but mainly it comes down to style.
Both vest have the same air protection system installed.
MLY-Y
YS
let me know if you have any other questions
www.SaferMoto.com
Old 12-20-2010, 04:56 PM   #187
testrider
Oddometer: 118
Thanks for the reply. Why does the YS full vest use 50cc while the MLV-Y uses 60cc? Does it imply that the YS have small air bags so it doesn't need as much air to inflate? Then how do the 2 protection systems compare?
Thanks again!
-mike-
MLY-Y
YS
Old 12-21-2010, 07:11 AM   #188
SaferMoto
SaferMoto's Avatar
Oddometer: 269
Thanks again!
-mike-
mike,
Sorry for the delayed reply I am trying to get a definitive answer from the inventor/factory for the difference. The first reply really did not address the question so I have re-asked and as soon as I get an answer I will post it up
www.SaferMoto.com
Old 12-21-2010, 09:36 AM   #189
testrider
Oddometer: 118
mike,
Thanks. I'm just trying to get the right one, for me. Your help is greatly appreciated.
It does sound like the 60cc MLV must be more 'protective'. The air got to go somewhere (more air bag volume). Are you sure it's not the other way around: MLV is a full vest while the YS is a light version?
Thanks again.
-mike-
Old 12-21-2010, 09:41 AM   #190
SaferMoto
SaferMoto's Avatar
Oddometer: 269
Thanks again.
-mike-
Mike,
No problem ask as many questions as you need to.
The main difference between the 2 vests is style. If you ride with a jacket that has lots of pockets you want access to then I would go with the MLV-Y. If you mainly ride with a jacket with few pockets then the YS would be the choice
The impact protection is the same for both vests.
When I hear back from the factory I will post up their answer, it is still early for them
www.SaferMoto.com
Old 12-21-2010, 10:14 AM   #191
testrider
Oddometer: 118
Thanks. I appreciate it. I really like to hear what they will say.
The structure of the air bags in the 2 vests are definitely not the same. Otherwise, they wouldn't use 50cc in one and 60cc in another. I wouldn't design 2 different gas cylinders if I don't have to. Common sense
Mike,
Old 12-21-2010, 12:35 PM   #192
SaferMoto
SaferMoto's Avatar
Oddometer: 269
Not being the guy that designed them I cant vouch for any differences there might be The email I got back stated "I must prohibit use" of 60cc in the YS so there must be a reason for it.
I am interested to find out the reason as well
www.SaferMoto.com
Old 12-21-2010, 03:12 PM   #193
TallRob
TallRob's Avatar
Oddometer: 1,395
Doesnt the MLV have a larger bag? I remember reading that of all the vests its got the largest CO2 bag area and the YS maybe a bit smaller bag area. Or the valves may be of a different (older?) design? Maybe thats why they dont want you using the bigger 60cc tube on the YS vest because it could over inflate it and pop it. Im just thinking outloud here. But that could be a good reason for it.
Old 12-21-2010, 04:38 PM   #194
testrider
Oddometer: 118
That's what I was wondering: why a 'light weight vest' (MLV) has more air bag area? While the full vest (YS) has less?
Old 12-21-2010, 07:03 PM   #195
TallRob
TallRob's Avatar
Oddometer: 1,395
When they say light wieght (which it is) There is no extra material like the standard vest. All you have is the bladder. All I can think of is that they are always improving the design.
Times are GMT -7.   It's 06:54 AM.
