10-23-2012, 11:50 AM
#1936 | |
Procrastinators
Oddometer: 5,779
I don't use tracking; I prefer to send messages when I feel like it.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
10-23-2012, 11:56 AM
#1937 |
Procrastinators
Oddometer: 5,779
It's too bad more usb cables aren't as rugged as the remote cable... the end where it goes into the remote is very solid.
10-23-2012, 05:11 PM
#1938 |
Procrastinators
Oddometer: 5,779
Speaking of remotes, I went out for a couple of hours today and my GoPro didn't lock up once. I had the remote tied down fairly tightly to the mounting Spot (pun intended) with a couple of broccoli elastics, and I wonder now if the lockups I had the other day could have been caused by the remote bouncing around. (And I sent a few Spot messages while out and they were all received normally so the remote can't be blocking the Spot signal enough to cause problems)
Anyway, it's solid, and worked well.
10-24-2012, 07:37 PM
#1939 | |
Torque Junkie
Oddometer: 3,538
Link |
10-24-2012, 07:43 PM
#1940 | |
Procrastinators
Oddometer: 5,779
10-25-2012, 07:01 AM
#1941 | |
Oddometer: 925
GoPro Hero3 Caps and Doors Covers I don't remember seeing those on GoPro's site but I could have missed them. Jon...
2007 FZ6 Past Bikes.....Check with my Wife.....I've lost count :-) |
10-25-2012, 10:59 AM
#1942 | |
Procrastinators
Oddometer: 5,779
10-26-2012, 09:56 AM
#1944 |
╭∩╮( º.º )╭∩╮
Colorado Trail - Continental Divide Trail Dual Sport Ride on WR250R
Here's my attempt to use the gopro in the rain, sleet, and Hail. ;)
If there's no video...it didn't happen
2007 ST1300, 2008 KLR650, 2008 WR250R, 1995 Ninja 250R Only a dog knows why a motorcyclist hangs his head out the window! Be real, be whole, be innovative. |
10-26-2012, 05:20 PM
#1945 | |
Procrastinators
Oddometer: 5,779
I do like my current solution - today I forgot to bring the lanyard but with those two elastics holding it, the remote didn't budge an inch. And the Spot works normally even though the remote is on it.
10-28-2012, 11:08 AM
#1946 |
╭∩╮( º.º )╭∩╮
Trail up to Hurricane Basin and old mining buildings
Another video from my Colorado trip...
Hurricane Basin Hinsdale County, Colorado Trail Type: Out and Back Nearby Towns: Silverton, Ouray, Lake City Nearby Trails: Mineral Creek, Cinnamon Pass, Engineer Pass Trail Length: 3 miles Elevation: 11,159 to 12,668 feet This trail packs a lot of scenery and rocky fun into three short miles. Even though it's in the middle of all of the popular San Juan Mountain trails, it sees little traffic. This trail is highly recommended if you enjoy old mining buildings and high mountain views. It starts off of the Engineer Pass trail near the ghost town of Animas Forks. There is camping near the trailhead, and the trailhead is not marked. You can find it by following two different trails continuing down into the valley next to the Engineer Pass trail, crossing through Henson Creek, follow the trail up and into Schafer Gulch. The trail immediately begins climbing over loose rocks along a shelf road. Continue up into the gulch with Gravel Mountain on your left and Seigal Mountain on your right marking the Continental Divide. The trail is fairly easy once you pass the rocky section, and it isn't long before you come to an intersection. If you make a sharp left turn here you can take a brief spur up to a restored lodge. The lodge is huge and in good shape, but keep in mind that the situation could change at any minute. Enter the building at your own risk. Next to the lodge is an old mill that has not been restored. If you carefully find a way into the building you can spot much of the old equipment that was used. Exploration is difficult and dangerous in this building. Continue back to the main trail and keep heading up Hurricane Basin. You can spot many old mines here, though all shafts have been closed or caved in. Follow the trail over more loose rocks to the very top in order to fully enjoy the view of the basin below you. It provides a good view of the buildings and mines.
10-29-2012, 05:53 AM
#1947 |
Procrastinators
Oddometer: 5,779
A couple of GoPro mount ideas:
This is a combination of the seat post mount and a RAM suction mount. I actually own the GoPro suction mount but it's cumbersome and limited in the range of angles you can set the camera to. The RAM ball/GP clamp is really easy to fiddle with. It's really solid; strong enough to pick up a marble tile. And the mount/tile would make a solid base, if you were to, say, leave your GoPro out to record the "Tail End of Hurricane Sandy" Also, I was finding it hard to pull the battery out of the camera so I added a little bit of electrical tape to make a kind of "pull tab".
10-29-2012, 02:32 PM
#1948 |
Oddometer: 925
That Ram mount looks good and like you said there is a lot more freedom to position the camera. It appears that you twist the upper half to get it to stick. Is that correct?
Thanks, Jon...
10-29-2012, 03:34 PM
#1949 |
Procrastinators
Oddometer: 5,779
That is correct. The newest version of this suction mount doesn't have a ball attached, though. It lets you decide what to put on top of it.
10-29-2012, 04:02 PM
#1950 |
Oddometer: 925
Found the one with the rubber ball attached....
RAM 3" DIAMETER SUCTION CUP W 1" PLAS BALL Product Number: RAP-B-224-2U Your Price: $12.80 http://www.rammount.com/CatalogResul...5/Default.aspx ![]() They also have one with a plastic ball in some of their kits. I found the rubber ball one by checking the components of the different kits. Jon...
