Old 03-22-2013, 02:04 PM   #2266
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,660
Here's another alternative for GoPro mounts:
This camera adaptor takes the standard GoPro screw knob and acorn nut but be careful about those nuts - they're looser than they are in the GoPro part, so you'll likely lose a few unless you glue them in.
The arm costs $3.77 and is plastic, but looks to be strong enough for something like the GoPro.
This is what I bought:
RAM Mount Plastic GoPro Camera Adapter 1 inch B-Ball RAP-B-202U-GOP1 $6.95ea
RAM Mount Plastic Lite Arm B-Socket RAP-B-201-1U $3.77ea
Click the part images above to go to the GPSCity site, for more detail or to order.
Old 03-31-2013, 04:59 PM   #2267
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,684
Helmet
I put mine on the left side of the chinbar. Easy to control with your non throttle hand. you can dip down to see it in the mirror to check it is running. you also don't look like a Teletubbie.
QUOTE=FredRydr;21078103]This thread is long, and a search of it for "helmet" hasn't led me to an answer. is there an advantage to mounting my new camera on the side versus the top of my helmet? I've seen both. I ride dual sport, and figure mounting it on the bike would be a vibration nightmare.
Fred[/QUOTE]
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 03-31-2013, 06:32 PM   #2268
Jon_PDX
Oddometer: 1,114
GoPro mount on street helmet
Fred,
Here are some images of the hardware I used and one of the camera mounted on my street helmet.
The adhesive pad was the one with a slight curve that matched the curve of the helmet.
Not as elegant as others but it it will give you an idea. I'll probably do basically the same thing on my dirt helmet.
Jon...
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 03-31-2013, 06:48 PM   #2269
FLICKIT
FLICKIT's Avatar
Oddometer: 881
Have to agree, chin bar is the way to go, being close to eye level it gives the best view... I'm not a fan of the high, on top of the helmet view...
Being Down-under and riding on the left hand side of the road, I run the cam on the right so it doesn't clip as many trees...
This is what I use...
(back a fair way so I can only just see it out of the corner of my eye)
It gives this sort of view:
FLICKIT screwed with this post 03-31-2013 at 06:59 PM
FLICKIT is offline   Reply With Quote
Old 04-01-2013, 03:31 AM   #2270
snorske
snorske's Avatar
Oddometer: 104
i prefer the right side because I can start and stop the camera without having to put the bike in neutral (ie taking hand off clutch)
i love the GoPro Hero3 black - just need to order a ram mount as the stock handlebar mounts are too shaky
snorske is offline   Reply With Quote
Old 04-01-2013, 05:29 AM   #2271
gots_a_sol
gots_a_sol's Avatar
Oddometer: 468
I've been running mine on the front of my helmet, but I think I may go back to the side mount as you can't really see the bike in the videos unless you tip the camera down some (which I always seem to forget to do)
06 Husky TE610
09 Husky WR165 - VCHSS #79L
gots_a_sol is offline   Reply With Quote
Old 04-01-2013, 11:44 AM   #2272
team ftb
Befuddled Adventurer
Oddometer: 1,726
Any chance of a closer pic and description of what you used to get the above mount put together? Is that flat mount? How is it attached to the helmet, etc.?
In that position can you rotate the camera down low enough to get the bars in the pic and you just keep forgetting or does the angle not allow the bars to be in the pic?
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 04-01-2013, 12:18 PM   #2273
gots_a_sol
gots_a_sol's Avatar
Oddometer: 468
This particular helmet has a nice flat spot above the chin vent that was just asking to have a flat sticky mount stuck to it.
I think part of the issue may be the camera is located further forward in relation to the bike which is why it gets cut off. Also every now and then I would bang it off of the bars and get a nice view of the sky.
On my old yamaha, it wasn't too noticeable
http://www.youtube.com/watch?v=mmAXsUYgO-4
But on my husky, most video looks like this.
http://www.youtube.com/watch?v=Uabv4FH9eO8
06 Husky TE610
Old 04-03-2013, 03:29 AM   #2274
team ftb
Oddometer: 1,726
Thank you. I'll be using some epoxy to create a flat spot on my helmets then. I've had some decent luck with the chest mount as an option that captures as much of the bars as you care to want.
Cheers,
Team FTB
Old 04-03-2013, 05:48 AM   #2275
gots_a_sol
gots_a_sol's Avatar
Oddometer: 468
I have a chesty mount also. The only thing I don't like about it is you can't look around with the camera unless you turn your body to do so. I've missed some entertaining moments because of that, such as my buddy sitting beside me and deciding to fall over for no reason at all.
06 Husky TE610
Old 04-03-2013, 06:43 AM   #2276
team ftb
Oddometer: 1,726
Yep, that's the reason I'm looking for a helmet mount. To catch your buddies muck ups.
Cheers,
Team FTB
Old 04-04-2013, 11:04 PM   #2277
Raiz
Oddometer: 16
Doesn't it come with a sticky mount thing for your helmet?
Raiz is offline   Reply With Quote
Old 04-05-2013, 11:45 AM   #2278
Wahoo
Persevering
Oddometer: 77
Hero Camera
Not sure if I'm in the right spot and if not I'm sure someone will let me know about it.
I have an older Hero Camera which I've used very little mainly because I have not been able to tell if it was on or not without getting in front of it to see if the light was on. So, last fall I bought the back pac with the remote and just now tried to set it up to start using it. Now I find out, after talking to Hero Customer Support, that I need to down load "Conform Studios" tool bar to update the camera and WiFi backpack before I can use it. Since I have Windows Internet Explorer I cannot download the updates. I need a different system.
I most certainly explained my frustrataions with a Customer Service Rep. using various and sundry explentives.
Am I the only one on this thread suffering because of this? I think my best alternative is to trash this Hero crap, go ride and forget about it.
Wahoo is offline   Reply With Quote
Old 04-05-2013, 12:26 PM   #2279
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
That's what I've done.
Internet Explorer downloads Cineform Studio no problem. No toolbar involved. Then the remote and back pac get updated by the Cineform program.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 04-05-2013, 12:45 PM   #2280
Wahoo
Persevering
Oddometer: 77
Hero Camera
I originally tried the updates using my Internet Explorer and it didn't work. When talking to the Service Rep. he said the Internet Explorer wouldn't work. Go Figure.
Times are GMT -7.   It's 10:26 AM.
