Old 12-25-2009, 05:00 PM   #16
RichardU
Let's Ride
Oddometer: 903
Originally Posted by afmracer
It looks very compressed amirite? The samples on their site and on Vimeo look much cleaner. Sweet ride btw
Not sure what amirite means. Vimeo compresses whatever you send them, as does Youtube. Looks great on my 60" plasma at 1080i.
Originally Posted by Z0RR0
Does it have the standard camera mount at the bottom? Like most any camera has? It seems it doesn't ...
It has a proprietary mount, but you can buy an adaptor for a standard tripod mount.
RichardU is offline   Reply With Quote
Old 12-25-2009, 05:10 PM   #17
greenthumb
b00b
Oddometer: 251
Ive been playing with one for a couple weeks now. Pretty good unit, but very basic. No adjustments for Exposure or White balance. The website sample videos are shot in bright daylight, which is why they look so good. The performance in artificial or low light is relatively poor, but no surprise given the tiny sensor it has (and is the same as the SD unit).
Where it excels is the wide field of view. Advertised at 170, matching this with a std cam would be difficult and expensive. The distortion is pretty reasonable too. This huge field allows you to get by pretty well without a screen or viewfinder. Usually you end up including too much rather than missing your target. There is no tripod mount, but you can buy one separately from gopro. The housing seems reasonably good quality, but Id be careful with maintenance if you were to use it underwater. 60 meters seems to me a pretty generous depth rating given the housing construction. One disappointment, is that the domed lens sticks out unprotected and will definitely get scratched, but they do sell replacements.
I use Final Cut for editing and the file structure the cam creates does not allow for the Log and Transfer action, you need to import the files. Also, as far as i can tell, final cut still does not support 60p, and will not allow you to import the sequences shot in 60p. I have had success exporting from these files from Quicktime as a .mov with the settings set manually to 60fps and then importing that file to FCP, but ive yet to determine if it retains the 60p.
greenthumb screwed with this post 12-25-2009 at 05:34 PM
greenthumb is offline   Reply With Quote
Old 12-25-2009, 05:31 PM   #18
greenthumb
b00b
Oddometer: 251
Originally Posted by Gadget Boy
Something else, what does one do with the HD content? I suppose you need a blu-ray burner which is currently big bucks. You're saying you can burn HD content on a regular DVD-R?
You can burn in a format known as HDDVD using Compressor (a component of Final Cut) and maybe others, and fit 30 minutes of HD on a std dvd. Ive yet to see a std dvd player support it and im unsure whether a Blu-ray would.
Old 12-25-2009, 08:00 PM   #19
Wesley J OP
Hoser
Wesley J's Avatar
Oddometer: 631
Nope, it's an option. $5 or $10 on the website
The video posted above has artifacts (horizontal tearing) due to what I assume to be a rigid mount (high frequency vibration). So far I've seen no tearing with a human mount.
Wes
Burren Rider: "It's the kind of power that leaves your hands shaking after a spirited run and makes you feel like wearing your undies on the outside, super hero style."
'07 KTM 990 Adventure
'10 KTM 300 XC-W
Wesley J is offline   Reply With Quote
Old 12-25-2009, 11:49 PM   #20
Night_Wolf
Leg Humper
Night_Wolf's Avatar
Oddometer: 8,098
What new mall would that be
Originally Posted by Wesley J
I was at the new mall in Calgary and there was a little KIOSK selling them. The parent company is fusionracing.com (http://fusionracing.com/index1.html). $369.
Wes
L 51.01.900 / L W 114.05.900
"That road less traveled is a toll road, and sometimes the charge is more expensive than we ever expected. Most of the time, it's a one way road. Make the decision, hope for the best, and start traveling. Carry lots of coins." PecosBill
Pick good friends and you'll never be lacking Family Me
Night_Wolf is offline   Reply With Quote
Old 12-26-2009, 05:14 AM   #21
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 5,016
I wanted to buy the original GOPRO , but found out a HD version was in the works, so I waited. Now I'm all set to pull the trigger but see they are going to offer a remote control & wireless mic option in the near future. Still waiting to find out if the current HD version is going to be compatible.
bemiiten is offline   Reply With Quote
Old 12-26-2009, 08:01 AM   #22
erda
erda's Avatar
Oddometer: 212
Guessing it would be Cross Iron @ Balzac.
Current ride: 2009 Bandit 1250SEA
Previous rides: 2009 V-Strom 650SEA; 2004 Kawasaki Ninja 500ex
erda is offline   Reply With Quote
Old 12-26-2009, 01:41 PM   #23
Wesley J OP
Hoser
Wesley J's Avatar
Oddometer: 631
It's actually spelled Ball-sack
Yup, thats the one.
'10 KTM 300 XC-W
Old 12-29-2009, 04:17 PM   #24
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,639
Originally Posted by RichardU
Here is a sample (2.5 min) shot in 720p. I'll be glad to answer questions.
http://vimeo.com/7878885
Nice, but I can see artifacts in the video. If you look closely at the vid in full screen mode, about halfway up the frame, you can see a band several hundred pixels high (or so) moving up and down slightly. I have seen two explanations for this; one is the memory card not being fast enough, another is the engine electronics interfering with the cam. I am betting from your mounting near the engine that it was the electronics - there is nothing like 60 to 120KV firing at 5K RPM to interfere with solid state electronics.
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee is offline   Reply With Quote
Old 12-30-2009, 09:35 AM   #25
TheMan
TheMan's Avatar
Oddometer: 160
In my first 24hrs I scratched my HD's lense when the RC car it was mounted on flipped on tarmac. For the 20th time .
I'm not well-experienced in video cams, but I will say I'm very pleased with my Hero HD's results. But I'm just pointing and shooting w.little demand beyond attaching to things and recording.
TheMan is offline   Reply With Quote
Old 12-30-2009, 10:37 AM   #26
Gramp-Z
Gramp-Z's Avatar
Oddometer: 830
I have the non-hd version and used one of the flat mounts to screw to an arm i built that screws to the top of my clutch master cyclinder . Have it a little ways behind my windshield , but with wide angle of camera , the edge of windshield is on outside corner of picture . Camera is just above my mirror , slightly ahead , so it is easy to get to the top button . I use it on my street bike , and it has been pretty good . Bright sunlight is best , been looking for some software to edit the lighting to see if i can lighten pictures / video without losing to much . I actually use mine in 3 shot mode often , beats the heck out of trying to dig out regular camera . Even the lithium batterys lose the juice fairly quickly when riding in cooler temps . Tip , keep a second set of batterys in shirt pocket , ready for a quick change out . Don't know what the wind chill to batterys was on a little 156 mile ride on the 28th , temp was between 30 -36 , running around 60-80 mph . Lithium made it half way , rechargables did the rest . Have fun , highly recommend the 3 shot mode , standard camera will take about 1,600 pics on 2 gig card .
Gramp-Z is offline   Reply With Quote
Old 01-01-2010, 09:14 AM   #27
munchmeister
Grow'd Up Mini Trail
munchmeister's Avatar
Oddometer: 1,422
Yo. GrampZ. Every get pics like this? Late afternoon so light was not the best but the CMOS rolling shutter of my GoPro non HD, non wide 5mp gave me these when I had it in 'pic every 2 secs' mode. I'm posting this one as it has the greatest number of vertical and straight lines, showing the effects of the CMOS rolling shutter. Check that contrail in the sky ! and the telephone poles
Munchmeister
2002 R1150GS - It's not about the knockdown, it's about the recovery.
munchmeister is offline   Reply With Quote
Old 01-02-2010, 12:33 PM   #28
Wesley J OP
Hoser
Wesley J's Avatar
Oddometer: 631
Definitely due to vibration. I've been searching for an inexpensive anti-vibration mount. Anyone have any ideas? So far I've only found a RC chopper mount...
Wes
'10 KTM 300 XC-W
Old 01-02-2010, 01:12 PM   #29
munchmeister
Oddometer: 1,422
I'm thinking the only way to isolate the vibrations enough for the GoPro I've got is to use a RAM plate of some sort and lay some gel pad or the right kind of foam pad on the plate, then find a way to mount the camera so it kinda "floats" on top of the foam. Maybe just use some bailing wire and one of these. Just add a chunk of neoprene on top of the plate.
Munchmeister
Old 01-03-2010, 07:57 AM   #30
Gramp-Z
Gramp-Z's Avatar
Oddometer: 830
Wow , that looks wild ! No , I guess my 83' Sabre is a little too smooth . I made a little error when changing fork oil , and was taking some video on I-90 at Snowqualmie Pass (typical pass , rough ), when i looked at the video , it was somewhat shaky , but the audio was terrible ! Lets see if I can load a pic of my mount . I'm a noob at all of this , just signed up for Smugmug . Ran out of time , resizing , will try again later , if i have the time . Also , kind of like the effect , the wide angle distortion has , looks like your moving way faster than you are , "sucking trees into your vortex ! LOL
Times are GMT -7.   It's 05:19 PM.
