Old 01-03-2010, 08:06 AM   #31
RichardU
Let's Ride
Oddometer: 876
Vibration is the biggest challenge for these cameras. I have experimented with mounting the camera in various locations:
  • Handlebars had so much vibration it was unwatchable.
  • Helmet was better, but still not ideal, plus all the problems of the picture moving every time I check my rear view mirrors, etc.
  • Mounted to my skid plate / frame is mostly stable image, although the front wheel is always in the picture, and there are artifacts.
  • The chest mount is the most stable image, but the mirrors get in the picture. Wouldn't work on a bike with windscreen.
I have also tried various foams. The camera doesn't weigh enough to compress neoprene. Softer foams can actually increase vibration.
There is a difference between vibration and shock. My GPS is mounted on a Touratech mount with rubber boots to reduce shock. But it still vibrates a lot.
There is a reason why most mid to high-end videocameras have image stabilization. And there is also a reason why professional vehicle-based cameras are stabilized with gyroscopes.
The other solution for video is to fix it in post. A variety of editing programs will apply image stabilization after the fact.
RichardU screwed with this post 01-03-2010 at 08:40 AM
RichardU is offline   Reply With Quote
Old 01-03-2010, 08:09 AM   #32
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,163
Yes, it's easy to isolate cameras from vibration, pros have been doing it for years. All you need is one of these:
Might be a little difficult to mount on a helmet, but it's the only way. And attachment to a vibrating and rapidly moving object will result in a vibrating and rapidly moving image.
It's a limitation of the media.
2011 White 990 Adv R
2003 565exc
FakeName is online now   Reply With Quote
Old 01-03-2010, 10:02 AM   #33
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 4,601
IMO the best vids I have seen for cams are on Vimeo - they don't seem to sample down the resolution as bad as any other hosts - although YouTube recently went up to 1080p.
This is a demo I found on Vimeo:
http://vimeo.com/7996230
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee screwed with this post 01-03-2010 at 10:07 AM
CodeMonkee is offline   Reply With Quote
Old 01-03-2010, 10:05 AM   #34
greenthumb
b00b
Oddometer: 172
I would suggest trying to make whats known as a 'steady cam' in miniature. if you look at an f800 brake resevior, it is basically the same principal. it consists of a counterweight and the fixed point being between the cam and the weight.
heres a professional and homemade example. much bigger, but scale it down and it should work.
greenthumb is offline   Reply With Quote
Old 01-03-2010, 10:38 AM   #35
FakeName
FakeName's Avatar
Oddometer: 1,163
Sure, it will work great. As long as you hold it verrrry steady as you are riding.
2003 565exc
Old 01-03-2010, 11:36 AM   #36
Wesley J OP
Hoser
Wesley J's Avatar
Oddometer: 597
Ok bitches. Cropping a short 1080p clip in its native form for download.
Any suggestions on a location to upload?
Wes
People who won't walk down an escalator and cars that park themselves. De-evolution is officially on...
'07 KTM 990 Adventure
Wesley J is offline   Reply With Quote
Old 01-03-2010, 12:51 PM   #37
tokenboy
Gnirly Adventurer
tokenboy's Avatar
Oddometer: 336
Send a message via MSN to tokenboy
vimeo
Ask for Jenny.
tokenboy is offline   Reply With Quote
Old 01-03-2010, 01:24 PM   #38
Wesley J OP
Hoser
Wesley J's Avatar
Oddometer: 597
Just an FYI for you guys, there is actually a free tool to cut these video files down.
Here it is: http://www.videohelp.com/tools/AviDemux
And if you want to trancode it to something else, say something that a crappleTV will play, use this: http://www.videohelp.com/tools/SUPER
Video Shortly.
Wes
Old 01-03-2010, 01:25 PM   #39
Wesley J OP
Hoser
Wesley J's Avatar
Oddometer: 597
Originally Posted by tokenboy
vimeo
No transcoding allowed. Vimeo transcodes everything, i want to let people dl a file just how it looks. I'll put it up on my website I guess. I think I have unlimited bandwidth but it's relatively slow.
Wes
Old 01-03-2010, 01:54 PM   #40
Wesley J OP
Hoser
Wesley J's Avatar
Oddometer: 597
Here's a short video including a 3rd gear wheely at 80 kmh, a crash and a donut or 2..... Colors are a bit muted as the lens is dirty from spray from cars.
Please right click and save as
Video
If its brutally slow and someone wants to put it somewhere else for dl, feel free.
Wesley J
Wesley J screwed with this post 01-03-2010 at 02:04 PM
Old 01-03-2010, 04:58 PM   #41
Gramp-Z
Gramp-Z's Avatar
Oddometer: 637
[IMG]%5Burl=http://gramp-z.smugmug.com/Motorcycles/RTW-visit/1082443[/IMG] Lets see if my attempt to insert a picture of my GoPro mount works . If you end up with a "post" mount , you could try wrapping a nice bunch of modeling clay around shaft to see if it helps. In machine work , we use it to cut down vibration on thin material , works well . If it makes a difference , then move on to a dense foam collar . I may do a litttle work on this problem , as I think I'll be going to a Wee-Strom this spring . Going from the velvet smooth V-4 , to a twin , I may deal with this problem a little more . Good luck .
Gramp-Z is online now   Reply With Quote
Old 01-03-2010, 05:10 PM   #42
Wesley J OP
Hoser
Wesley J's Avatar
Oddometer: 597
Old 01-03-2010, 05:43 PM   #43
LarryB
Baja GPS Maps, LBMaps.com
LarryB's Avatar
Oddometer: 73
Send a message via Skype™ to LarryB
Orange thing?
Anyone know what the orange rubber thing that comes with the HD Hero is?
Baja maps for Garmin. www.LBMaps.com
LarryB is offline   Reply With Quote
Old 01-03-2010, 06:34 PM   #44
munchmeister
Grow'd Up Mini Trail
munchmeister's Avatar
Oddometer: 1,279
I'm not so sure a steadicam is the answer, even if you could fabricate one. A steadicam is designed to eliminate the ups and downs caused by walking with your camera. The vibrations from the bike are high frequency vibes, the ones you feel in your grip. Just about anything that is secured to the bike is going to have the bike's vibrations transferred. I've thought, perhaps, that if a camera could have a mount on the bottom of the camera that is isolated by rubber or something, it might remove some of the vibes. For example, think of two common screw eyes which are bound together by, say, a rubber band. Pull the two screw eyes apart a bit to flex the rubber band between them and let this absorb the vibes. Build a platform for the camera for it to rest on, keeping it secure with the jig described. Make sense? I may have to draw this up in SketchUp or something.
Ok, here is a quickie, crude SketchUp drawing.
Munchmeister
2002 R1150GS - It's not about the knockdown, it's about the recovery.
munchmeister is offline   Reply With Quote
Old 01-03-2010, 07:29 PM   #45
Rashnak
Lorem Ipsum
Rashnak's Avatar
Oddometer: 9,695
I have the non-hd version. The HD version definately has some upgrades, especially in the battery.
But regardless of version- this is a fun camera. I have several mounts on my bike, and also on top of the helmet. I interlace the GoPro footage with still shots and video from the other two cameras.
Here is the result...
"thanks for aptly demonstrating the problem "
Rashnak is offline   Reply With Quote
Times are GMT -7.   It's 08:31 AM.
