Old 01-27-2010, 01:12 AM   #16
Gladly
Gladly's Avatar
Oddometer: 157
Originally Posted by Cigar Mike
I am in contact with an the owner of the XR400 now and may be able to get an old frame to be able to fit a stand. If so, I don't see where it will be much of a problem. I will post here if that comes about. There will be some loss of ground clearance, but it will be able to take a good hit.
Thanks,
Cigar Mike
hopefully it will still be an under 5 minute install for the 400. For the harder core trail runs it could be removed, and reinstalled for the softcore and around town stuff
'03 XR400R
Gladly is offline   Reply With Quote
Old 01-27-2010, 08:42 AM   #17
Cigar Mike OP
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,464
On the 650L stand it is a snap to install without the skid plate. With the skid plate on it can be a bear to line up the bolt holes. I assume it will be a similar situation on the 400. I don't have one therefore I don't really know. I will have to wait to get feedback after the first one is installed. I will let you know.
Cigar Mike
When in doubt, give it Gas!
Cigar Mike is offline   Reply With Quote
Old 01-27-2010, 08:48 AM   #18
Cigar Mike OP
Cigar Mike's Avatar
Oddometer: 1,464
Progress on the TE610
Still have a ways to go to refine the design, but I know it will work now.
Thanks to Mountain Eagle for the use of his Husky.
Cigar Mike
Old 01-31-2010, 06:37 AM   #19
FatherX
eXiled
FatherX's Avatar
Oddometer: 4,844
i'm in
it should make it easier to work on until it is actually running.
I love these goofy bikes and their "let's go make coffee some place stupid, instead of, a stupid place to buy coffee" mentalities.
FatherX is offline   Reply With Quote
Old 01-31-2010, 10:00 PM   #20
Cigar Mike OP
Cigar Mike's Avatar
Oddometer: 1,464
TE610 Center Stand
This stand is made just like the one shown in the parts fiche. I think that I will still make a few adjustments. but it is very close.
Goes up on the stand easily. I think the legs need to get higher in the up position. I will be working on that.
Cigar Mike
Old 02-02-2010, 05:57 PM   #21
Cigar Mike OP
Cigar Mike's Avatar
Oddometer: 1,464
Revised Husky TE610 Center Stand
I think I see why Husky didn't make their stand available. It works but the stand was not designed very well. I made some changes and it works but it is not perfect. The problem is the side stand. There is just not enough room to fit the two together perfectly. There is some manipulation of the side stand and the center stand to get them up and down. But it is not too bad, IMO. Basically you will need to move both stands downward to get the side stand down. Once the side stand is down the center stand works fine. One of the easier bikes to get up on the stand. Stepping on the press down leg and lifting from the rear rack or rear section of the bike will get the bike up easily.
$80.00 plus shipping. Stands a primered and painted with rattle can paint. Will sell unfinished for $75.00 plus shipping. Unfinished stand shown in above pictures.
Cigar Mike
Old 02-03-2010, 04:56 PM   #22
Cigar Mike OP
Cigar Mike's Avatar
Oddometer: 1,464
XR400 Stand is complete
I am sending the XR400 center stand out tomorrow so that it can tested. If the test goes well they will be available soon. The stand that is going out is for a SM'ed bike. I will need a measurement for the standard dirt version to make the adjustment.
Cigar Mike
Old 02-03-2010, 11:38 PM   #23
Gladly
Gladly's Avatar
Oddometer: 157
Cigar Mike
let me know how you want it measured and I can do it
'03 XR400R
Old 02-04-2010, 08:16 AM   #24
Cigar Mike OP
Cigar Mike's Avatar
Oddometer: 1,464
PM sent
Old 02-04-2010, 09:05 AM   #25
Gladly
Gladly's Avatar
Oddometer: 157
PM sent
I'll try to get the measurements tonight
'03 XR400R
Old 02-04-2010, 09:23 AM   #26
Cigar Mike OP
Cigar Mike's Avatar
Oddometer: 1,464
In answer to an earlier question. Yes, it will be a 5 minute or less install.
Thanks,
Mike
Old 02-05-2010, 02:37 AM   #27
Gladly
Gladly's Avatar
Oddometer: 157
Thanks,
Mike
PM'd you back with the height as near as I could figure for my bike (trying to balance it on the floor jack while measuring)
how is the spring tension on the ones that you've built for other models, will it withstand some hooligan moves?
'03 XR400R
Old 02-05-2010, 09:09 AM   #28
Cigar Mike OP
Cigar Mike's Avatar
Oddometer: 1,464
The spring tension is good and the stand stays up nice and tight to the stop. There is no bounce of the stand that I am aware of. Getting a spring that would do that and also retain its spring tension with the amount of extension required is why the spring is so long. Because the upper spring connection point is so far from the pivot point this was necessary. Getting the spring right on these stands is the hardest part of putting it together.
I base this on the XR650L stand which is almost the same as the XR400 stand. The only difference being the mounting bracket and a bend in the legs similar to the Husky TE610 stand. I hope to have some pictures next week when I receive them.
Thanks for getting the measurement.
Cigar Mike
Old 02-05-2010, 03:04 PM   #29
hahmule
Balding Gloriously
hahmule's Avatar
Oddometer: 623
Like it!
My 06 610 is lowered two inches at the shock. Do you think the center stand would still work?
What a lovely bunch of coconuts.
Better to be a fast mule than a slow race horse.
hahmule is offline   Reply With Quote
Old 02-05-2010, 04:07 PM   #30
spezjag
spezjag's Avatar
Oddometer: 8,411
Thumb
Mike -
My XR650L center stand arrived in record time, and was very professionally packed to boot! I really appreciate the lightning-fast service.
I am looking to being reunited with my bike (we are on opposite coasts right now) and getting the stand mounted.
Thanks again for an awesome product!
Gary
Only a motorcyclist knows why a cheetah hangs its head out the window. - Peterman
http://m.youtube.com/watch?v=DZ6jy8o...ure%3Dyoutu.be
spezjag is offline   Reply With Quote
Times are GMT -7.   It's 10:30 PM.
