02-05-2010, 03:31 PM
#31 | |
Too Old and Too Slow
Oddometer: 1,126
Custom Heights at no extra charge.
If it is the model year that has the factory installed mount it will not be a problem. Send me a PM and I will tell you how to get the measurement I need. I will be able to make one the height you need.
I will do that modification on any stand I make. There is always some difference between the height of the bike due to the different choices of tires. I have picked a middle ground for the heights. My XRL650L has a higher profile front tire but a lowering link on it. It works out about the same as a stock bike in height as far as rear wheel ground clearance when on the stand. The standard stand will work on most bikes unless they have been significantly lowered or SM'ed. Cigar Mike Quote:
When in doubt, give it Gas! Center Stands, XR650L/XR600, NX650, TE/SM610, TE630, XR400, XR250 and XT225. http://www.advrider.com/forums/showthread.php?t=537336 http://www.cigarmikes.com/ |
02-13-2010, 06:01 PM
#32 |
Oddometer: 1,126
XR400 Center Stand
XR400 Center is now available. $160.00 plus shipping. ADVrider inmates will recieve a 10% discount.
![]() ![]() Cigar Mike
02-13-2010, 06:42 PM
#33 | |
Oddometer: 143
edit, found one here: http://www.advrider.com/forums/showp...postcount=2015
'03 XR400R |
02-13-2010, 07:35 PM
#34 |
ADV Rider
That 400 stand should also work on a 250 right ?
03 Honda XR250R |
02-13-2010, 08:03 PM
#35 | |
Oddometer: 25
02-13-2010, 10:57 PM
#36 | |
Oddometer: 143
'03 XR400R |
02-13-2010, 11:05 PM
#37 | |
Oddometer: 1,126
The XR400 was able to be made because kawamatt2 sent me a portion of a frame for the XR400. I usually need to get my hands on a bike to see if I can make one. I was pretty lucky it fit as good as it did. I will make a few minor changes after talking with kawamatt2. Cigar Mike
When in doubt, give it Gas! Center Stands, XR650L/XR600, NX650, TE/SM610, TE630, XR400, XR250 and XT225. http://www.advrider.com/forums/showthread.php?t=537336 http://www.cigarmikes.com/ Cigar Mike screwed with this post 02-13-2010 at 11:23 PM |
02-14-2010, 04:37 AM
#38 |
ADV Rider
XR400 and XR250 frames are almost identical.
A week or two and I will buy one off you and test the fit.
03 Honda XR250R r00t4rd3d screwed with this post 02-14-2010 at 05:24 AM |
02-14-2010, 08:09 AM
#39 | |
Oddometer: 1,126
The lower portion of the stand is almost the same for the XR650L and the XR400 except for the bends in the legs to get the bottom of the stand higher on the 400. The 650 side stand does not allow this. I am going to see what can be done to modify the side stand so that I can get the center stand for the 650 to have the same bend to get the feet higher like the 400. Bikes that do not have passenger pegs typically have the side stands up higher since there is no interference with passenger pegs. Send me a PM if you would like, so we can figure out what the difference may be. I will check the parts fiche and see what I can tell from that. The inmates here have made the suggestions that bring new stands about, and it is appreciated. Cigar Mike
02-14-2010, 09:50 AM
#40 |
Oddometer: 89
Hey guys can you please enlighten me on the advantages of a center-stand? I had a 150cc scooter that had a center-stand; now I've got a XR250 with the stock side-stand. The side-stand seems like it's more stable in windy conditions. My scooter (parked on a center stand) fell down a couple of times in strong wind. It was chinese shit, though, so maybe this is it :)
Anyway, what is the reason you put center stands on XRs? |
02-14-2010, 10:02 AM
#41 |
ADV Rider
Do you still have that chunk of the 400 frame to measure ? Can you give me some numbers in inches to compare ?
Here is my 250 :
03 Honda XR250R |
02-14-2010, 01:12 PM
#42 | |
Oddometer: 1,126
Others have told me that they like that their bike is stored without having weight on the suspension and the bike takes up less space in the garage. If you do not know of a reason to have one, I doubt if you need one. I do not think that everyone would want or need one. I have tried to make the stands as easy as possible to install and remove. Even those of us that would want one may not want it on for every ride. When on Adventure rides it may be something you would want. For single track you may not. For the riding I do anymore the stand is not a problem. I have no desire to try and convince anyone that they need a centerstand. People have contacted me telling me that they want it for maintenance. I tell them that they would be money ahead to buy a hydraulic motorcycle lift. They are much cheaper and will lift both wheels off the ground at the same time. You can buy mechanical lifts for under $30. Bottom line, the stands are not for everyone. I just happen to be somebody that wants one and apparently I am not alone. Cigar Mike
02-14-2010, 01:19 PM
#43 | |
Oddometer: 1,126
Maybe?
I could make one from a tracing of the bottom of the bike. But it would have to be a pretty accurate tracing. May be some one in the Rookies has one I could look at. It would only take a couple of minutes to find out. Cigar Mike
02-14-2010, 02:50 PM
#44 | |
Oddometer: 89
I've got a hydraulic lift (DRC HC-2) in the garage, but for long trips the centerstand could be a real help. I wonder how much does the stand weigh? --Gene |
02-14-2010, 05:32 PM
#45 | |
ADV Rider
I shoved this piece of cardboard up under there and traced what I think you need then I sized it to be the exact size as the real measurements , so if you print it out it will be the real size and measurable. Are these the numbers you wanted ?
03 Honda XR250R |
