Old 03-04-2010, 06:47 AM   #61
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
Send a message via MSN to r00t4rd3d
03 Honda XR250R
r00t4rd3d is offline   Reply With Quote
Old 03-04-2010, 08:08 AM   #62
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
Cigar Mike is the man !
Got my stand today , fits perfect. Mike never actually had a XR250R to measure for the stand. He did it all from the numbers I gave him and his own knowledge. For it to fit perfect with no adjustments needed on either the stand or my bike , is friggin pretty amazing.
Two weeks from the time I committed to the stand , the UPS man brought it to my door.
2003 Honda XR250R Center Stand :
Awesome Job Mke !
Matt.
03 Honda XR250R
r00t4rd3d screwed with this post 03-04-2010 at 09:25 AM
Old 03-04-2010, 09:35 AM   #63
Gladly
Gladly's Avatar
Oddometer: 143
Originally Posted by r00t4rd3d
mine was waiting for me at the office today!
'03 XR400R
Gladly is offline   Reply With Quote
Old 03-04-2010, 11:35 AM   #64
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
My new tire changing tool.
Two old tent spikes and a piece of rope :
03 Honda XR250R
Old 03-04-2010, 04:55 PM   #65
Cigar Mike OP
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,126
Not prefect.
r00t4rd3d,
The stand looks like it is a little far forward in the down position. I would like you to stick a thin piece of material between the stops and get the stand a little more vertical. If you let me know the size of the material you shim it with I will be able to make the adjustment. Ideally the stand should be at approximate 15 degrees in relation to the ground. That will lift the rear of the bike higher as well. In addition that should allow the bike to rock back on the rear tire with the addition of about 30 lbs of weight behind the rear seat.
How good a guess was that on the angle of the center stand in the up position? I was hoping it would match the angle of the side stand.
But it works better then I thought it would considering I didn't get to try on a bike. I will send you a PM and see what you would like to do.
Cigar Mike
When in doubt, give it Gas!
Center Stands, XR650L/XR600, NX650, TE/SM610, TE630, XR400, XR250 and XT225.
http://www.advrider.com/forums/showthread.php?t=537336
http://www.cigarmikes.com/
Cigar Mike is offline   Reply With Quote
Old 03-04-2010, 05:57 PM   #66
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
Mike , my driveway is all uneven and wavy. I think it made my pictures look deceiving. Here it is on a flatter surface. It couldn't be any closer to 15 degree's and my rear tire is off the ground 1 3/4.
03 Honda XR250R
Old 03-04-2010, 06:29 PM   #67
Cigar Mike OP
Cigar Mike's Avatar
Oddometer: 1,126
OK, I was wrong. It is perfect after all.
It sure didin't look it from the other pictures.
Cigar Mike
Old 03-05-2010, 02:41 PM   #68
JustJohn
Old Fart
JustJohn's Avatar
Oddometer: 11
XT225 with Turbocity skid plate
CigarMike,
Did you ever come up with a center stand that works on the XT225 with the TC skidplate installed instead of the factory one?? Thanks, JustJohn
JustJohn is offline   Reply With Quote
Old 03-05-2010, 03:26 PM   #69
redpillar
redpillar's Avatar
Oddometer: 794
Are you thinking of making one for the KLX250 at all?
redpillar is offline   Reply With Quote
Old 03-05-2010, 04:14 PM   #70
donny662
donny662's Avatar
Oddometer: 337
Or the DRZ400?
Calvin: I think people worry too much about the little things. All they do is make themselves unhappy that way. Why get an ulcer over things that don't really matter?
Hobbes: Like that book report you're supposed to be writing now on the book you haven't read?
Calvin: Exactly. Case in point.
donny662 is offline   Reply With Quote
Old 03-05-2010, 04:34 PM   #71
Solrider
Smiling Politely
Solrider's Avatar
Oddometer: 262
Originally Posted by diesel1959
Mike--good to see these great designs prosper. Would you be interested in creating a stand for the Super Sherpa? I'd happily buy one and I'd bet there'd be a few others too. Glad to have good folks like you here! Cheers
BTW, Norvegicus speaks very highly of you and that's good enough for me. ;)
x2 please! I'd be happy to send you measurements if you need them.
Heidi - KF7CKI
Sierra Expeditions
1-866-507-4254
1998 4Runner SR5*~*2009 Kawasaki Super Sherpa*~*2009 Voo Doo Dambala
Two Libras
Solrider is offline   Reply With Quote
Old 03-05-2010, 07:52 PM   #72
Cigar Mike OP
Cigar Mike's Avatar
Oddometer: 1,126
Originally Posted by JustJohn
CigarMike,
I have only seen pictures of the skidplate. One of the XT225.com members (was that you?) sent me pictures of his and I told him if he sent me his skidplate I was pretty sure I could make one fit. He decided to put the stock plate back on and install the center stand. I have not been asked about since until now.
Cigar Mike
Old 03-05-2010, 08:24 PM   #73
Cigar Mike OP
Cigar Mike's Avatar
Oddometer: 1,126
DRZ Stand
Originally Posted by donny662
Or the DRZ400?
I have done a little research on the DRZ400 and from looking at the frame diagrams it looks like a stand similar to the XR stands would be possible. You would lose about 1 1/4" of ground clearance. I would just need to get my hands on a bike and the time to do it. I believe it would be close enough to the XR stand that I could make a few modifications and the it would fit the DR.
I would like to build one for the DR and hopefully I will get to it this year. If some one requests a stand for a certain model I do try and make one. Problem is I am getting a lot of requests for different models and I try to get to them on a first come first serve basis. It is because of the help of the Rockies Regional Forum members that I am able to get my hands on different models to make those stands.
I update my blogspot (http://www.cigarmikes.com/) as I start on new projects. And post here when they are available.
If not for the help of fellow inmates, there would only be two models available. I recieved part of and old frame to make the XR400 stand. That was cool!
Cigar Mike
Old 03-05-2010, 08:32 PM   #74
Cigar Mike OP
Cigar Mike's Avatar
Oddometer: 1,126
I did look at the frame diagram for that bike and I think I will need the bike to make one. The Honda's are very close to one another so I was able to to do it with measurements on the XR250. I think I was more lucky then good on that one. Some don't work out that good and it takes a lot of effort to get it right. I am getting feed back now on the XR400 that indicates that there needs to be some adjustments. I would rather be lucky then good.
Cigar Mike
Old 03-05-2010, 08:34 PM   #75
donny662
donny662's Avatar
Oddometer: 337
I'll link to this thread from ThumperTalk. There might be a few others from the DRZ forum interested and, hopefully, that will include someone from Colorado.
Times are GMT -7.   It's 01:39 PM.
