Old 12-30-2009, 03:03 PM   #1
Steve G. OP
Steve G.'s Avatar
Oddometer: 7,076
Centech AP2 installation locations, GS/GSA
So I've just recieved my Centech AP-2 fuse panel and AP-130R relay, thanks to the boys at BestRest http://www.bestrestproducts.com/p-50...use-panel.aspx so I can wire in my Piaa light kit. The wiring looks very straight forward, but, for such a big bike, there doesn't seem to be very many locations to mount the AP-2 and still have fairly easy access to it.
Just wondering if any of you guys have found a good place to bolt this thing down?
Steve
Steve G. is offline   Reply With Quote
Old 12-30-2009, 03:32 PM   #2
dang
Oddometer: 461
There is a bracket just under the aft end of the fuel tank which holds the diagnostic plug. Somewhere on here a clever fellow has posted a pattern for a panel bracket which attaches there. It's close to the battery so there is little voltage drop in the primary cable and generally central to various aux loads.
Someone makes a commercial plate which fits there too. Cyclenutz perhaps?
Oh, here you go.
http://www.advrider.com/forums/showthread.php?t=110062
and here is the commercial version,
http://www.cyclenutz.com/products/el...50gs_more.html
dang is offline   Reply With Quote
Old 12-30-2009, 04:11 PM   #3
mikegc
mikegc's Avatar
Oddometer: 1,647
Centech AP2 Fuse Block
I put mine in the removable try that holds the stock toolkit. I also placed the Centech supplied relay in the tray and accessed power for it via the accessory plug just below the tray. I still use the original toolkit case as a cover for the Centech & relay.
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 12-30-2009, 07:32 PM   #4
PotatoHead
It's only potato...
PotatoHead's Avatar
Oddometer: 273
I put mine (on a 2007 GS) on a piece of clear plastic shaped to fit on top of the tool tray, so that I keep a bit of space underneath for tool and fuse storage.
You can see the container holding extra fuses and a red "bit holder" underneath the clear plastic. Bought the fuse and relay from http://www.easternbeaver.com/
PotatoHead is offline   Reply With Quote
Old 12-30-2009, 09:09 PM   #5
Steve G. OP
Steve G.'s Avatar
Oddometer: 7,076
Great picture! I've got free access to up to 1/2" thick lexan. I'm going to do the same thing.
Thanks guys!
Steve
Old 01-01-2010, 11:20 AM   #6
Steve G. OP
Steve G.'s Avatar
Oddometer: 7,076
So, just had a chance to start working on this. From looking at your picture, do you have to lift the clear plastic to gain access to your tool kit, or have you pulled it right out, and are using the catch tray underneath for your tools?
Steve
Old 01-01-2010, 11:24 AM   #7
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,014
Not so neat, but same location:
Jim
Old 01-01-2010, 12:11 PM   #8
PotatoHead
It's only potato...
PotatoHead's Avatar
Oddometer: 273
Steve
Yes, I need to lift the clear plastic to get access to the "tools" (but there is not a lot of space) underneath. I keep the real tools in a tool tube or panniers.
Keep in mind that wires are attached, so think about where to attach wire tie downs so you can get access.
I think I used 1/8" plastic from TAP plastics.... Started with a cardboard template to get the shape, cut the plastic, and then sanded to fit.
Old 01-01-2010, 12:57 PM   #9
billyt53
Phast Phossil
billyt53's Avatar
Oddometer: 596
This is where I fitted mine on my 1150GSA.
Oh, I see that you have a 1200 gs. My bad.
Billy
India - The Highs and Lows
A photography book by me
South America on Two Wheels
Another photography book by me
billyt53 is offline   Reply With Quote
Old 01-01-2010, 01:59 PM   #10
myblubeemer
JWAT
myblubeemer's Avatar
Oddometer: 489
jwat
"I'm not sure what I do all day, but it takes me all day to do it!"
myblubeemer is offline   Reply With Quote
Old 01-01-2010, 04:04 PM   #11
Mac
Mac's Avatar
Oddometer: 2,150
Mac
R1200GSA | 690E | 300XCW
RMAR President - Website FaceBook
Member: NRA, AMA, TPA, MSF RC
Mac is offline   Reply With Quote
Old 01-01-2010, 05:59 PM   #12
1200gsceej
1200gsceej's Avatar
Oddometer: 1,259
That is so pretty, so neat
-ceej
Originally Posted by Mac
My bike: Yellow '05 1200GS - on the Spotwalla ADV location page as CJ3.
My solo trips: 2014 Natl Park triangle, SF-Colorado-SF 2011 and 2013, SF-LA loop, Pinnacles and Carmel Valley loop
With Ol'Badger: http://www.2guysonbikes.com
And remember: Beauty is in the behind of the holder.
1200gsceej is offline   Reply With Quote
Old 01-01-2010, 06:05 PM   #13
GB
Mod Squad
GB's Avatar
Oddometer: 56,579
nice work, I wish I could find that wire sheathing around here.
Old 01-01-2010, 07:54 PM   #14
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,334
Wow, I wish I can do work like that, Mac do you have a "How to" or at least more pictures of diagrams so a Humble admirator can follow "Some" of your steps.
Aagain wonderful layout so elegant and easy to follow.
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 01-02-2010, 11:46 AM   #15
NBeener
Oddometer: 1,521
Mac, I thought you were gonna' set up shop :)
Mine ... same as the others ....
NBeener is offline   Reply With Quote
Times are GMT -7.   It's 06:23 AM.
