Old 09-18-2013, 07:21 PM   #436
hiawassee
Fair play t'ya!
hiawassee's Avatar
Oddometer: 199
Originally Posted by motoxer667 View Post
I am 5'11". I had the same seat on my '01 YZ426 too. Have you replaced the rear Spring? When I adjusted the rear sag on my "12 I am border line on needing a heavier spring which I did do on my YZ when I had it.
Have not replaced the spring, but I'm thinking one of the 2 P.O.s might have. Earlier this year after i bought the bike, I was trying to determine how to stiffen it up and whether I might need a new spring. I consulted the manual and it says there are color coded spots of paint on the spring that correspond to its relative stiffness. I found the paint on mine and it matches up to a factory code for a stiffer than stock spring. So I made some gradual adjustments to the damping and compression and that made a difference.
It has a soft SDG gripper seat on it now which isn't bad as far as comfort. For some reason though that seems to be unrelated to either the suspension or the seat, the bike just feels smaller. Could it be the more streamlined design of the aluminum frame compared to the older boxy steel frame configuration? Both of mine are in the garage side by side and the 450's seat height is lower where everything else for the most part is the same. Sitting on both, they feel roughly equal as far as sag is concerned.
Not a big deal I guess. I just don't care for the bulk of my weight while riding seated to be on my undercarriage. Seems like more weight needs to transfer thru my feet to the pegs making it easier to stand quicker. I've got lingering back problems as it is and long miles take their toll regardless. Not that I have any plans to quit of course . So maybe a tall seat is the way to go.
__________________________________
'81 KZ1000 (resting in pieces)
'01 WR426F
'07 WR450F
hiawassee is offline   Reply With Quote
Old 09-19-2013, 11:01 AM   #437
Parx400
Oddometer: 1,889
Originally Posted by hiawassee View Post
hey, how tall are you? I've been considering a tall seat on my '07. I'm 6'2" barefoot, and 6'3"-ish with riding boots on. my legs cramp as well when seated. feel like I dwarf the bike. riser under the bar helps a little, but still cramped when seated.
for some reason it doesn't seem as tall as my '01 426. wasn't sure if it's because I run a 19" rear tire on the 426 vs. 18" on the 450, or if there's a difference in suspension between the two (despite trying to even them up, the '07 still feels a little cushy-er).
Starting in 05 they made the bike about an inch lower from the seat to the ground. I had a 2000 wr400 with stock seat and lowered pegs. on my 06 wr450 with lowed pegs I still felt cramped so I went with a taller Guts seat. I'm 6,2 almost 6,3 barefoot.
Parx400 is offline   Reply With Quote
Old 09-19-2013, 11:52 AM   #438
T-cosmic
T-cosmic's Avatar
Oddometer: 276
I guess I'll have to do the seat mod too, on my '12. I'm 6'4'' and I find precise braking (rear brake) very difficult due to the angle of my ankles.
Share the best off road tracks you have ever ridden on www.adv-tracks.com
T-cosmic is offline   Reply With Quote
Old 09-24-2013, 03:33 PM   #439
andrewgore
Team MGH
andrewgore's Avatar
Oddometer: 3,536
Got some use outa my WR450 this past weekend.
Andrew
andrewgore is online now   Reply With Quote
Old 09-25-2013, 12:23 PM   #440
T-cosmic
T-cosmic's Avatar
Oddometer: 276
Nice Andrew...
I gave mine a wash...
Old 09-28-2013, 12:20 PM   #441
-TRED-
-TRED-'s Avatar
Oddometer: 181
Tps
I'm want to disconnect the TPS on my bike, but I'm not sure where it is located.Did some reseach, but still not sure. Can some tell me or shoot me a picture of what it looks like?
'07 WR450F
'04 DRZ400S (FOR SALE)
I was going really fast until I crashed.....BRAAAAP!
-TRED- is offline   Reply With Quote
Old 09-28-2013, 01:17 PM   #442
beernutt
This space for rent
beernutt's Avatar
Oddometer: 332
GYTR power tuner loan?
My 06 bit the dust.
http://www.advrider.com/forums/showthread.php?t=921730
Getting a 12 WR450. Does anyone have the GYTR power tuner they can loan out? I'd be happy to put a PayPal deposit down to use it, and even give you $20 to let me use it. I'll pay shipping both ways to CO.
Thanks for thinking about it.
Alan
beernutt is offline   Reply With Quote
Old 09-28-2013, 05:15 PM   #443
wilkinsonk
soup de grimace
Oddometer: 856
Originally Posted by beernutt View Post
My 06 bit the dust.
Alan
I think the dealer will reprogram for you if you can't get a hold of a tuner... So what are the plans for the '06? At the least you can get some use out of the wheels.
- Ken
wilkinsonk is offline   Reply With Quote
Old 09-28-2013, 06:32 PM   #444
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,152
It's on the left side of the carb, hidden behind the frame. The connection to unplug it is about 12" or so forward. You'll have to remove the gas tank to find it.
Unplugging it didn't make my 08' run any better on the road. It still stuttered while trying to maintain a steady speed. I ended up buying a Dynatek programmable CDI, that an inmate was selling & offered to let me try it before buying. It's not cheap, but it works. I was happy to pay for it rather than paying a mechanic hours to try to diagnose it, and maybe never figure it out.
GlennR is offline   Reply With Quote
Old 09-29-2013, 03:42 AM   #445
-TRED-
-TRED-'s Avatar
Oddometer: 181
Thanks Glenn. I'm going to give it a shot disconnecting first. I'm not sure thats the best option, since from what I have read, I will be giving up some low end torque when I'm on the trails. If it doesn't work, I will take your route and try the Dynatek CDI. Beside the stutter going away, any other differences you see with the new CDI?
'07 WR450F
Old 09-29-2013, 07:55 AM   #446
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,152
The Dynatek just fixed the stutter issue. I didn't notice anything else. It is "programmable" for custom applications, but the computer software & hardware to program it is an optional purchase. It comes with 4 different profiles programed in it, and one of those fixes the WR450.
Old 10-09-2013, 03:19 PM   #447
eRRmmm
Oddometer: 576
Seat Concepts rack
Hello all,
I recently picked up a 2005 WR450, and after giving it a thorough and much needed service I'm looking to set it up for longish dirt (desert) rides, with the occasional overnighter.
I'll order a Safari tank soon to increase range, but will occasionally need a bit more fuel. The easiest way I can see to do this is a 4L container strapped to a rear rack. (I have a Giant Loop Coyote for camping gear which would sit just forward of the rack, Camelback Mule for food and first aid etc).
I had a Seat Concepts seat on my DR650 which was great, so I'll probably be getting one for the WR. The Seat Concepts rack looks ok too, and I'd save some postage to Aus if I ordered them both. I'm aware of the Promoto billet racks which look great but are expensive landed here - hard to justify since it will spend probably 50 weeks a year hanging in the shed.
Has anyone got a Seat Concepts rack (also sold on ebay?) and if so can you give me your opinion on it?
cheers
Tim
eRRmmm is offline   Reply With Quote
Old 10-09-2013, 03:27 PM   #448
Farmer Roy
Farmer Roy's Avatar
Oddometer: 374
Originally Posted by eRRmmm View Post
Hello all,
cheers
Tim
yeah, i've been looking at these racks to, interested in what others think
was thinking about maybe modifying it, running a brace down to the footpegs for more strength and to act as pannier frames for soft panniers ect ?
Farmer Roy is online now   Reply With Quote
Old 10-09-2013, 04:33 PM   #449
-TRED-
-TRED-'s Avatar
Oddometer: 181
Did the Shen500 and the stutter actually was almost non-existant once I got to much higher elevation. It could be jetting too?
'07 WR450F
Old 10-09-2013, 04:35 PM   #450
Parx400
Oddometer: 1,889
Hello all,
cheers
Tim
I got a safari for my 06. I love the tank but ran into this problem. Since the tank was made for the 03/04 bike its sits so lower on the 05/06 that the kick starter wont fold in. I ordered a pro tec that is 28mm lower to see if it will tuck in.
Times are GMT -7.   It's 04:00 PM.
