01-02-2010, 05:35 AM
#1 |
Smiles when says dat
Oddometer: 12,779
WR250R Data, Specs and How-to's
All right folks, here's a reference thread for the WR250R. Links to good info both on the web and ADV's own original WR250R mega thread.
I'll set some placeholders first to segregate the data. And then as it's collected I'll go back and edit as we go. WR250R Forum: http://wr250rforum.forumotion.com/ WR Dual Sport Website: http://www.wrrdualsport.com/ ADV Rider's own WR250R Mega Thread: New WR250R - 1st impression, plus pics of her "naked"!! Rick Ramsey's site: http://rickramsey.net/WR250R.htm
WR250R Data Thread Pix: Sets for 2007 DL650 Build. , Custom Wolfman Tank Bag..Yamaha Super Tenere Build and now 2012 DL 650 Bulid MoBill screwed with this post 01-02-2010 at 06:17 PM |
01-02-2010, 05:36 AM
#2 |
Oddometer: 12,779
General Info, Specs, etc here
Oil Change: Drain Plug Torque: 14 ft/lbs (168 inch pounds) also recommendations out there to hand tight & add 1/4 turn (12mm) (1.48 qt w/filter) Oil Filter Housing Torque: 7.2 ft/lbs (86.4 inch lbs) Front Sprocket Torque: 69 ft/lb (95 Nm) Triple Clamp Bolts: Upper Bracket Pinch Bolts: 23Nm/17ft lb, Lower Bracket Pinch Bolts: 20Nm/14ft lb Rear Axle Torque: 90 ft-lbs Rear Sprocket Nuts = 25 ft. lbs Front/Rear Axle Nut Sizes: 22 Front/27 Rear. Lower fork pinch bolts- 14 ft lbs Upper fork pinch bolts- 17 ft lbs.
WR250R Data Thread Pix: Sets for 2007 DL650 Build. , Custom Wolfman Tank Bag..Yamaha Super Tenere Build and now 2012 DL 650 Bulid MoBill screwed with this post 04-02-2011 at 07:52 PM |
#3 | ||||||
Oddometer: 12,779
Maintenance:
Swing Arm: http://www.wrrdualsport.com/tech-gui...-swingarmmaint Spark plug removal: http://wr250rforum.forumotion.com/ma...lug-t1443.html Grease Wheel Bearings: http://www.wrrdualsport.com/tech-gui...wheel-bearings Chain Guide, Sprocket, Etc: http://www.advrider.com/forums/showp...ostcount=12525 (see next page for quoted post if desired) Alternative Air Filter: Quote:
Sprocket source: Quote:
WR250R Data Thread Pix: Sets for 2007 DL650 Build. , Custom Wolfman Tank Bag..Yamaha Super Tenere Build and now 2012 DL 650 Bulid MoBill screwed with this post 07-09-2012 at 07:32 AM |
01-02-2010, 05:37 AM
#4 | |||
Oddometer: 12,779
Troubleshooting
------------------------------------------------------------------------------- Enduro Mode: Quote:
WR250R Data Thread Pix: Sets for 2007 DL650 Build. , Custom Wolfman Tank Bag..Yamaha Super Tenere Build and now 2012 DL 650 Bulid MoBill screwed with this post 05-01-2010 at 04:53 AM |
#5 | |||||||
Oddometer: 12,779
Mods and parts supply
D606s: 120/90-18 and 90/90-21s. Mitas I would get (and it's available in the US) is 100/100-18 M/C 59M C-16 TT MI SKU: 2000026452101 REAR 110/100-18 C-16 TT MI $62.00 http://www.mitasmx.com/shop/index.ph...ct_detail&p=29 FRONT 90/90-21 C-17 TT MI $65.00 http://www.mitasmx.com/shop/index.ph...ct_detail&p=31 FRONT 80/100-21 C-17 TT MI $60.00 http://www.mitasmx.com/shop/index.ph...ct_detail&p=32 Mitas Rear Tire: C-16 Front Tire: C-17 Excella Tire Option: http://www.amstires.com/excella/ Front: OF213, 80/100-21 M/C 51R Rear: OF213, 120/90-18 M/C 65M Quote:
I ordered the 110 link smart chain...10,000 pound strength and 13/46 gearing from Krause Subsequently just went with Primary Drive brand from Rocky Mountain ATV, same longevity, 1/2 the price...AND I'm 112 link, 13/47 now. -------------------------------------------------------------- Link to Lowering the R2 info: http://www.wrrdualsport.com/tech-gui...15-lowering-r2 ----------------------------------------------------------------------------- UK Ventura rack--hangs off the back: http://www.ventura-bike.co.uk/fitmen...250x_2008.aspx Wolfman racks review: http://www.wrrdualsport.com/reviews-...s/116-brmrack2 ---------------------------------------- Programmers: Attitude fuel programmer http://www.tunewithattitude.com/products.php?pr=37 FMF Programming talk Quote:
Brtittania Composites Dual Sport Fairing, with link to how-to: http://www.advrider.com/forums/showt...9#post13624419 Fat Bar Comments (Pro Taper or GYTR Top Clamps: For the WR250R, the right lower clamp, you need a shorter bolt. The lowers normally come with I believe 100mm bolts, but the key/steering lock gets in the way. For the Pro Taper Tusk Big Bar Clamp, r/s lower clamp needs either 75mm or 80mm. VW Sandman Case Saver Kit: https://sites.google.com/site/sandma...case-saver-kit AIS Removal: http://www.wrrdualsport.com/tech-gui...take/72-aisrem (requires AIS Cover) AIS cover: WRRDualSport PayPal Link: https://www.paypal.com/us/cgi-bin/we...4b2728ea935a7c Flapper: http://www.wrrdualsport.com/tech-gui.../68-flapperrem Exup Removal: http://www.wrrdualsport.com/tech-gui...84-exupremoval See Rick Ramsey site if you keep the stock exhaust and need to keep the valve open: http://www.rickramsey.net/WR250Rmods.htm#exup (not needed if you replace the exhaust) Parts needed if you eliminate the Exup--to keep the check engine light from coming on: Bought the Exup eliminator from Graves Motorsports: http://www.2wheelpros.com/graves-mot...r-2353517.html Rockymountainatv.com Primary Drive Sprockets (Primary Drive is their in house brand of steel): (14/52 is another option, reduce countersprocket/chain wear?) http://www.rockymountainatvmc.com/pr...dFamilyId=2192 Need bolts too: http://www.rockymountainatvmc.com/pr...dFamilyId=9503 Alternative Site for sprockets: 14/50? Looks like similar ratio to 13/46: http://www.jtsprockets.com/52.0.html...sel_uid=6043&p Bash3r's install videos!! Quote:
Go Race: 540-392-0696, Blackburg, VA and Facebook: https://www.facebook.com/#!/gorace.suspension Quote:
Racetech: http://www.racetech.com/page/id/80 Rosamond, CA 951.279.6655 WER Suspension: http://www.werproducts.net/Suspension-Service.html Great Meadows, NJ (908) 637-6385 Quote:
WR250R Data Thread Pix: Sets for 2007 DL650 Build. , Custom Wolfman Tank Bag..Yamaha Super Tenere Build and now 2012 DL 650 Bulid MoBill screwed with this post 07-15-2012 at 12:13 PM |
01-07-2010, 05:26 PM
#7 |
Oddometer: 256
Here is a piece of information I need and it might be nice to have on this thread. I'm wanting to order the motion pro combo tire spoon axle wrenchs, but I can't find the front and rear axle size in the owners manual. Anyone have the front & rear axle nut sizes handy? It's for the R if that makes a difference.
01-07-2010, 05:28 PM
#8 | |
Oddometer: 372
22 Front/27 Rear.
01-07-2010, 06:12 PM
#9 | ||
Oddometer: 12,779
Engine removal comment from Bake:
WR250R Data Thread Pix: Sets for 2007 DL650 Build. , Custom Wolfman Tank Bag..Yamaha Super Tenere Build and now 2012 DL 650 Bulid MoBill screwed with this post 07-10-2010 at 08:36 PM |
01-07-2010, 08:06 PM
#10 |
Wannabe Far-Rider
I know its easy, but I wrote up a spark plug removal on the WR forum.
http://wr250rforum.forumotion.com/ma...plug-t1443.htm
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time. 2008 Yamaha WR250X - 1998 Honda Nighthawk CB750 Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012 |
03-13-2010, 05:57 AM
#11 | |
Oddometer: 12,779
Plastics part numbers from Krabill:
WR250R Data Thread Pix: Sets for 2007 DL650 Build. , Custom Wolfman Tank Bag..Yamaha Super Tenere Build and now 2012 DL 650 Bulid |
03-13-2010, 07:28 PM
#12 | |
Oddometer: 12,779
03-13-2010, 07:30 PM
#13 |
Butler Maps
Oddometer: 14,580
good idea.
the wrr thread is a growing beast like the dr thread.
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
03-13-2010, 07:33 PM
#14 |
Oddometer: 12,779
Thanks, I wasn't gonna do this at first, but there are some references in there I'd like to have at hand on ADV. If you see something, post it here and I'll take some of the deals and move 'em into the first posts.
03-17-2010, 12:48 PM
#15 |
Oddometer: 308
Thanks for taking time to make the Table of Contents!
