12-01-2012, 04:56 AM
#556 |
Oddometer: 1,664
Uh oh....the Trail Stand guy's personal anti-flat karma ran out, at least I made it home before it went flat, so I got that goin for me
![]() I'll be using the Trail Stand to fix this today and I'll document the process, maybe even add a few flat fixing tips.....stay tuned ![]()
TRAIL STAND (advrider thread)- Dual Sport Portable Jack Stand www.endurostar.com Husqvarna TE630 Husqvarna TE610E (for sale) Cagiva Gran Canyon sTE610vE screwed with this post 12-01-2012 at 05:02 AM |
12-07-2012, 10:45 PM
#557 |
Oddometer: 182
Mine arrived a few weeks ago. I immediately drove out to ocotillo, hit the throttle up a wash, and found a large jagged rock on which to pop my front tube. All so I could put this thing to use (it was burning a hole in my gear bag).
It worked well despite my inability to use it properly (as should be made evident by the harsh lean angle). Still very pleased and glad i didn't have to throw the bike on its side to get the job done. Thanks guys! Awesome product.
Current Rides:1998 KTM 620 Adventure Past Rides: 1994 KTM 400 EXC WP/D LC4 - Plated; 2001 BMW F650GS Thumper; 1970 CB175; 2003 KLR250 |
12-28-2012, 06:15 AM
#558 | |
Oddometer: 1,664
To help stability on almost any bike the more vertical the bike is when on the Trail Stand the more down force on it and the stability increases greatly, especially when lifting the front wheel. I posted the pic below to show how something under the kickstand to get the bike as vertical as practical before placing the Trail Stand increases the down force on the Trail Stand. Obviously you wont be carrying a piece of wood like this but a flat rock or something should do the trick.
TRAIL STAND (advrider thread)- Dual Sport Portable Jack Stand www.endurostar.com Husqvarna TE630 Husqvarna TE610E (for sale) Cagiva Gran Canyon |
01-04-2013, 06:22 PM
#559 |
Oddometer: 1,664
Got a Flat on the trail, you need an Enduro Star Trail Stand, it packs small and is ready when you need it!
Questions, post them up here ![]() ![]()
01-05-2013, 04:49 PM
#560 |
Oddometer: 10
I Got Mine!!
Steve received my order yesterday and it arrived in my mailbox TODAY!! Wow. Unbelievable. And that's not the best part ... this stand is STRONG. Pictures don't do it justice. If it weren't for everyone on this thread saying how wonderful it is, I probably wouldn't have bought it for fear that it wasn't stout enough. Well, that initial impression was absolutely unfounded. Great buy. Steve was great to deal with too. I sent him a couple emails asking some questions and he was super quick in getting back to me. Great partnership between buyer and seller. I can't recommend this highly enough.
Keith |
01-07-2013, 04:53 AM
#561 | |
Oddometer: 1,664
Yep the Trail Stand is made from steel, so it can be strong but still take up as little space as possible and it only weighs 10 ounces!. I've had several people say the couldn't believe how small I box it comes in but still it can extend high enough to do the job on any bike I have found. I've seen some aluminum types but guess what, they are 3 times the volume of material and take up much more room to pack and weigh the same as the Trail Stand made from steel. Everyone likes Aluminum but sometimes the right choice for performance to weight ratio and size is good old steel.
TRAIL STAND (advrider thread)- Dual Sport Portable Jack Stand www.endurostar.com Husqvarna TE630 Husqvarna TE610E (for sale) Cagiva Gran Canyon sTE610vE screwed with this post 01-07-2013 at 05:00 AM |
01-11-2013, 08:20 PM
#562 |
Oddometer: 182
Proved itself yet again, this time propping up a prize-winning pig.
![]() Thank you for this wonderful tool. I never leave without it.
02-03-2013, 04:32 AM
#563 | |
Oddometer: 1,664
It looks like you have a good stable position there. For others who might not know, if you lift the font wheel you can increase the stability by decreasing the lean angle on the kickstand by getting the bike close to vertical by placing something under the kickstand as shown above in post 558
TRAIL STAND (advrider thread)- Dual Sport Portable Jack Stand www.endurostar.com Husqvarna TE630 Husqvarna TE610E (for sale) Cagiva Gran Canyon sTE610vE screwed with this post 02-03-2013 at 04:38 AM |
02-10-2013, 04:38 PM
#564 | |
ya mo be there
Oddometer: 398
Any advice on how one person can get the rear wheel in the air? Front?
I have a 690 too. Quote:
ktm 450xcw, ktm 690 enduro r, kawasaki versys 650 "In Europe we ride about eight-tenths. If we really have to, we might ride nine-tenths. The crazy ones ride ten-tenths—but not for very long. In America, they seem to ride eleven-tenths all the time."-- Phil Read |
02-11-2013, 05:11 AM
#565 | |
Oddometer: 1,664
Basically you set the Trail Stand to a level that will get the rear or front wheel about and inch off the ground, each bike is different and once you find that lever you can mark the extension rod with a sharpie for something like that to give you a good starting point, it still may vary a bit on different surfaces. To lift the rear, after using the front brake strap to lock the front brake with the front wheel turned all the way to the left, I usually stand by the rear wheel looking forward and use my hip to knudge the bike over on the kickstand while I grab a hand hold on the left rear subframe area and slip the Trails Stand (with the height already set) under the foot peg area. The 690 looks like a bit of a challenge to find a good spot where it cant slip since there isn't a regular frame. Maybe even a spot on the front of the swingarm might be better, remember you want to make sure it cannot slip out, unless the bike is lifted off of it. Again the front brake strap locks the front wheel and helps stability significantly, ALWAYS use it. To lift the front turn the wheel to the left with the bike in gear and kneel on one leg, your right leg, under the handlebar, push STRAIGHT UP on the right side handle bar and slip the Trail Stand into a good spot in a skidplate like the pic above. When lifting the front especially, the more vertical the bike the more stable it will be with the front wheel in the air. Like I have shown above a "spacer" like board or a flat rock can help this stability dramatically, depending on the bike. The user always needs to decide the best method of use for safety, sometimes it may take help by a friends foot, or big rock, on the right side of the rear wheel to stop the bike from wanting to rotate around the kickstand. These are both easier than they sound, it takes a lot of words to describe pretty simple movements. And if you are riding with a friend it is alway easier for them to stand on the left and grab the area near the back of the seat and tip the bike to the left while you place the stand under the footpeg area, or another good spot to hold up the rear wheel. I am down to only a few Trail Stands left, the next run is due back from the plater later next week, just to let people know. Steve ESP llc
03-01-2013, 11:24 AM
#566 |
Oddometer: 1,664
Trail Stands are back in stock and shipping, if you have not recieved your shipping email yet you will sometime today!
Thanks very much for your orders and patience while I got restocked!
03-04-2013, 01:25 PM
#567 |
Formerly Flying Cow
Oddometer: 38
It's not very often you find the perfect log in the middle of nowhere.....
![]() Ordered a stand today!!!!
82' GPZ 750 R1 93' ZX6E 93' XR650L "...listen mister, you better not forget what you don't know!" ex-girlfriend
03-05-2013, 05:25 AM
#568 |
Oddometer: 1,664
It's on the way Flying Cow....and it's a lot easier to pack than a stump!
Thanks for the order you should see it in 2-3 days.
TRAIL STAND (advrider thread)- Dual Sport Portable Jack Stand www.endurostar.com Husqvarna TE630 Husqvarna TE610E (for sale) Cagiva Gran Canyon sTE610vE screwed with this post 03-05-2013 at 08:26 AM |
03-05-2013, 07:36 AM
#569 |
This is Liv'n!!!
Location: Northeast PA, Some... On HIGH ADVENTURE Most!
Oddometer: 1,222
03-06-2013, 07:00 PM
#570 |
Oddometer: 1,664
Hey Jim, I see the Trail Stand works for the front of the beast too! I check in on the HighAdventureTour thread from time to time, great adventure, and thanks for the pics and the good words!
