Old 09-24-2004, 12:45 PM   #1
losercharles OP
it's just a rash
losercharles's Avatar
Oddometer: 387
Brake Failure light likes to flicker on
Today, I notice that my brake failure light started to flicker. COuld this be due to low fluid level? What causes the light to actually come on? I hate that brake fluid is hidden underneath the tank ('76 r/90) Any suggestions on what I should break first to fix the brake?
-Losersteve!
losercharles is offline   Reply With Quote
Old 09-24-2004, 01:39 PM   #2
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,715
my guess...
Pull the tank and check the brake fluid level...then promptly throw away the under-the-tank master cylinder and replace with the later kind that mounts on your bars!
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 09-24-2004, 02:23 PM   #3
Eurobiker
Vintage Cat Herder
Eurobiker's Avatar
Oddometer: 5,964
Not Guessing.....
The terminals on the cap are prolly shorting to the tank creating your flicker. Pull the tank and insulate the connectors with silicone, electrical or duct tape. Total repair cost, $.10 plus the you now owe me. As long as your in there though, I'd change the brake fluid and bleed the system if this hasn't been done in the past 2 years. Make that 2
Mark
If I agreed with you, we'd both be wrong.
Eurobiker is offline   Reply With Quote
Old 09-24-2004, 02:56 PM   #4
racer
racer's Avatar
Oddometer: 1,548
grounding
Sounds like a grounding problem.
racer is offline   Reply With Quote
Old 09-24-2004, 04:10 PM   #5
Flash
Sand Boxer
Flash's Avatar
Oddometer: 3,163
There's a float underneath the brake reservoir cap. Fluid level goes down, float sinks, closes circuit, light comes on.
Flickering light? As stated before, check the fluid level. If OK, then disconnect the two wires and tape them out of the way. Reinstall tank and go for a ride. If flickering stops, you've got a bad cap. Most likely problem.
If the flickering ontinues, you've got a short elsewhere.
My 78 R100S does it too. And the culprit is the rear master cylinder cap. To get a new cap, I have to buy the whole reservoir.
I should have enough saved by New Year's.
04 K1200GT
IBA # 12323
Flash is offline   Reply With Quote
Old 09-27-2004, 01:06 PM   #6
losercharles OP
it's just a rash
Oddometer: 387
Ouch, dude.... So with that said it's probably just best to convert to a later handle bar mount. Some old fella who works on BMWs says that I could just slap a Suzuki Master Cylinder on it, but then I fear I may have to start pulling 60 mph wheelies and perform stoppies on my new squidmobile... only time will tell!
-LoserSteve!
Times are GMT -7.   It's 09:09 PM.
