Old 01-04-2010, 09:45 PM   #16
Benjava
Benjava's Avatar
Oddometer: 1,920
It's probably fuel like every one says. But I had similar symptoms. Cuttng out under load but would idle ok. Only happened when it was very hot. I replaced the coil and it has not happened since.
"Limbautomy" what's the Rush?
Benjava is offline   Reply With Quote
Old 01-05-2010, 01:06 AM   #17
rivercreep
Oddometer: 3,243
Things I'd check.
1. A fuel delivery problem could be caused by several common things and I'll ABC the things I've thought of that can cause intermittant problems.
a. sticky float/valve
b. a small hole in your diaphram
c. something residual in the bottom of your fuel bowl that keeps getting sucked up and then released once the bike shuts down. (although you've cleaned it already so I doubt this one).
D. vacuum operated petcock is going bad and keeping fuel from the carb intermittantly.
e. debri in fuel tank.
2. One thing that steers me away from some of my suggestions however, is the sooty plug. (incorrect ratio of fuel = check needle wear and slide wear too!)
I've had previous bikes act the same way and show a sooty plug by not burning off the gas (which will cause those deposits).
a. your coil is going bad and not delivering enough charge at higher rpms, fouling out the plug to the point where it wont start untill the plug dries out.
b. bad plug wire can do the same thing if it grounds out.
c. bad plug
d. any number of wiring/ground problems.
3. hows your doohickey? timeing can always screw things up.
4. how many miles since your last valve adj?
rivercreep is offline   Reply With Quote
Old 01-05-2010, 05:50 PM   #18
roadtripp OP
roadtripp's Avatar
Oddometer: 113
Good news! I brought it to a mechanic today, and together we disassembled the carburetor and cleaned it out again. He blew through one of the jets (I'm not sure which one it was) and cleaned out the float bowl, and presto - a working motorcycle! I'll keep a close eye on it for the next couple hundred miles, but I'm hopeful that this problem has been solved. I'm excited to continue my trip southward! Thanks to all your help, and thanks especially for helping me get over my fear of the carburetor - that thing always seemed very "spooky", but now that I've taken mine apart and put it back together, I feel like I have a better understanding of what exactly makes my bike tick. Onwards and upwards!
-Joe
Seattle -> Ushuaia on an '05 KLR 650: November of '09!
Blogging my ride at http://tdf.joepemberton.com and on advrider at http://www.advrider.com/forums/showt...php?p=11295681
roadtripp is offline   Reply With Quote
Old 01-05-2010, 08:04 PM   #19
BC Brian
BC Brian's Avatar
Oddometer: 598
Glad you are back on the road
Looking forward to reading more of you RR
Brian
BC Brian is offline   Reply With Quote
Old 01-06-2010, 04:24 AM   #20
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,484
Does the KLR have a vacuum activated petcock? If there is a leak there, it may be intermitent too! Drain the carb and check for water in there! If so, drain the tank! Good luck Joe!
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 01-06-2010, 05:42 AM   #21
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,403
WooHoo!
Glad you're up and running again! KLR's have their own personality...maybe yours just didn't feel like moving for a few days!
Looking forward to the rest of your RR!
Be safe
2005 KTM 950 Adventure
Roaming Rally 2011RR2012 RR2013 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 01-06-2010, 08:37 PM   #22
dukedinner
Oddometer: 323
A good tip I learned is to run some SeaFoam through the bike once a year..does wonders for engine performance and keeps everything clean. The first time I did it I thought I had a new bike...
dukedinner is offline   Reply With Quote
Old 01-07-2010, 01:31 PM   #23
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,665
Fantastic! Glad to hear your problem is resolved. As most of us listed the carb or electrics are about the only thing that can put a KLR down. Now you have a little more KLR education and have gained confidence along the way. Fantastic.
Keep the RR coming and up to date on your trip. Be Safe
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is online now   Reply With Quote
Old 01-07-2010, 07:03 PM   #24
rawdog
rawdog's Avatar
Oddometer: 808
Great support system to have here.
rawdog is offline   Reply With Quote
Old 01-08-2010, 03:51 AM   #25
XDragRacer
Oddometer: 3,042
+ 1 on the advice on the thread so far. Diaphragm air-tight fit is critical, and the "choke" (enricher) plunger must seat fully for proper carb operation.
A desperate measure sometimes effective is STARTING FLUID. A whiff of this ether-based sure-thing combustible mixture into the carb will sometimes kick off a balky engine, later picking up on its own and running on its gasoline fuel supply.
Have a fire extinguisher standing by if you try this, and--oh, yes, "Do not try this at home!"
With compression/spark/combustible mixture; oughta start! A long tow or push at a pretty good clip, and easing the clutch out in 3d or 4th gear might kick it off, if the electric starter won't.
XDragRacer is offline   Reply With Quote
Old 01-11-2010, 07:17 PM   #26
piratehood
discoverin' dual sportin
piratehood's Avatar
Oddometer: 90
What is "Seafoam"
piratehood is offline   Reply With Quote
Old 01-11-2010, 07:28 PM   #27
subybaja
subybaja's Avatar
Oddometer: 2,889
Snake-oil-in-a-can that actually works.
Found at most NAPA/Schucks/PepBoys.
subybaja is offline   Reply With Quote
Old 02-24-2013, 06:30 PM   #28
RandyLove
Oddometer: 23
2007 KLR650 Starts But Stutters/Dies Under Load
I thought I'd add my experience with a very similar sounding issue while I was riding through Argentina. I pulled off at a fuel station to get off the bike and grab a drink. 15 minutes later, after not fueling or making any changes to the bike, it began to stutter above 3.5 - 4K RPM.
Issue: I could start the engine and rev it up as high as 4K RPM while in neutral and it would run fine. Then throw a leg over her and try to ride and it would stutter at about 3.5K - 4K RPM then pop back up and give me power for a second, then drop off again. I was traveling at about 55MPH, which was all she could muster.
I pulled off at a safe shaded area and started to review what I had worked on recently. I had removed the fuel tank to repair some chaffed wires (another post altogether) and recalled the vacuum hoses from the carburetor could cause a similar issue. I inspected the connections and found that one in fact had backed off, presumably when I pulled off the highway into the fuel station's bumpy potholed parking area. Once all snugged up, I was back on the road w/o issue.
Hope this helps someone.
Randy
"Take calculated risks." General George S. Patton, Jr
Tour de Farnes, A round trip Adventure from San Francisco, CA to Ushuaia, Argentina and back http://pretirement2012.blogspot.com
RandyLove is offline   Reply With Quote
Times are GMT -7.   It's 04:00 PM.
