Old 01-26-2011, 05:24 AM   #61
Gumbeaux
The Chameleon
Gumbeaux's Avatar
Oddometer: 745
Just noticed that I never updated here that I received my Woody's wheels some time back in the late summer/fall and I am very happy with the results. I opted for OEM hubs, but if I had to do it again, I may choose the billet option.
Either way, they give me great confidence and work well.
Ideally, I want some discs and rotors too so I can quickly swap my street and dirt setups. Those parts are expensive...still looking for a deal.
Buy with confidence.
Gumbeaux
Gumbeaux is offline   Reply With Quote
Old 04-11-2011, 11:32 AM   #62
inmate-n00b
Ciao, Marco
inmate-n00b's Avatar
Oddometer: 1,006
Hey Woody!
I sent you a pm a while ago.....I'd like to get some info.....
The scenario is that I spend the weekdays with my stock wheels and Annakees (or any other ds tire), then on the weekend, I swap the OEM wheels out and put in the new wheels with some knobbies. Just a simple swap out.
I understand that you give two options:
50/50 (dirt/street)
and
100% (dirt)
I like the 50/50 option.
I guess I need new front and rear rotors. Will I have to get any ABS-related hardware? Will the ABS still work?
I'd like to keep the tire sizes the same. Also, I want both wheels to be tubeless. I understand that you use the nuetech tubliss system for the front 21" wheel. I have heard conflicting things on how good the tubliss system is. In that case, I will go tubes up front and tubeless in rear.
I don't know if it's worth going with a 19" up front. I happen to like the 21" wheel.
Does the 50/50 keep the stock width for the wheels?
Also, what are the color options?
I'm confused over all the choices and info....as you can see..
Thanks.
inmate-n00b screwed with this post 04-11-2011 at 01:35 PM
inmate-n00b is offline   Reply With Quote
Old 04-18-2011, 08:34 AM   #63
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,088
ahhh finally got near a working computer,,,
Originally Posted by OMG_WTF View Post
Hey Woody!
I sent you a pm a while ago.....I'd like to get some info.....sorry,,have been on the road since beginning of april,,,dealing with family weddings in New Orleans ,,and now in Orlando with my grand-kids,,will be back in Denver to celebrate Easter with my troopies
50/50 (dirt/street)we convert to 1.85x21 front rim and 3.5x17 rear can use stock/oem tire sizes
and
100% (dirt)we use 1.6x21 and 2.5x18 for hard core riding and a bit wider for easier stuff
then we also convert to 2.5x19 front with oem resr 4.25x17 for outrageousely fine mainly street touring application[can be sealed for tubeles too]
I guess I need new front and rear rotors. we recommend galfer wavy/floating rotors sporting galfer green pads...work better for less $$$ Will I have to get any ABS-related hardware? if ya want ABS you'll need the ABS rings too!!!Will the ABS still work? only if the ABS rings are installed
I'd like to keep the tire sizes the same. Also, I want both wheels to be tubeless. I understand that you use the nuetech tubliss system for the front 21" wheel. I have heard conflicting things on how good the tubliss system is.tubliss ads state for off road use only In that case, I will go tubes up front and tubeless in rear.10-4,,,no problem
I don't know if it's worth going with a 19" up front. I happen to like the 21" wheel.like i said earlier ,,,if ya spend alotof time on the slab and keep the bike on fire roads and smoother trails you'll be fine
Does the 50/50 keep the stock width for the wheels?no,,,i gave specs above
Also, what are the color options?if ya go with billet hubs ,,we can get a variety of colors NC,,rims too,,but that adds another $75-100 per rim depending on satin or glossy finish
Thanks.
hope that helps abit
woody
ps ,,ya can always call the toll free # below and ask my specialist Zach for solid info and advice,,,
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 04-18-2011, 10:35 AM   #64
inmate-n00b
Ciao, Marco
Oddometer: 1,006
No need to apologize. Thanks for answering my questions. I may give Zach a call.
Old 04-25-2012, 05:21 PM   #65
Mongo357
Mongo357's Avatar
Oddometer: 65
Wicked Monster Front Wheel
Woody,
What would it take to get this front wheel set-up?
http://www.advrider.com/forums/showp...4&postcount=13
Any chance that is just a fat tire spooned onto a normal sized rim? (I know that isn't a GS, I'm not even sure if it is a 21" rim.) Could a slightly wider rim be used with the stock hub, brake rotors, etc? I know the fender would have to go, and brake lines extended or re-rerouted.
Mongo357 is offline   Reply With Quote
Old 08-08-2012, 04:59 AM   #66
Built to Last
Oddometer: 3,088
Monster wheel set up for f800,,,,
Originally Posted by Mongo357 View Post
Woody,
sorry,,,i just got back in town from round th eworld trip and RMAR Rallye
just send us your old wheel and we'll build ya one or we have everything here,,
looks like a 2.5x19 rim with a big 140/80 tire on it
woody
Times are GMT -7.   It's 03:02 PM.
