Old 11-29-2011, 02:27 PM   #46
tallrider
tallrider's Avatar
Oddometer: 50
Big Dom,
Nice idea on modifying the light. I never thought of that.
I have been running the HID in my setup mostly. So far have not aggravated any motorist so will continue with that for awhile. If it becomes a problem I will use your approach. Thanks for posting.
JP
tallrider is offline   Reply With Quote
Old 01-12-2012, 06:48 AM   #47
Lnspltrs
Oddometer: 1
Very interested
Are these still available?
Lnspltrs is offline   Reply With Quote
Old 01-12-2012, 07:15 AM   #48
Boatman OP
Ride more, BS less!
Boatman's Avatar
Oddometer: 8,407
Yes,, available and ready to ship.
I also replied to your PM.
08 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 05-04-2012, 08:10 AM   #49
Boatman OP
Ride more, BS less!
Boatman's Avatar
Oddometer: 8,407
Bump,,,, been getting PM's lately asking if these are still available.
Yes, they are.
Old 05-14-2012, 07:08 AM   #50
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 3,850
Send a message via AIM to BlueLghtning Send a message via MSN to BlueLghtning Send a message via Yahoo to BlueLghtning
Just found this thread after seeing it mentioned in the Husky TE-610 thread.
I recently bought a TE-610 that came with the 8" BD headlight only and although I like the light output when I need it, I really hate not having a low beam. I keep the light pointed low as to not blind on coming drivers, but on a back road when I need the light, that just gets annoying. I have really been on the fence about replacing this light with something else as I just wasn't happy with this setup, but this conversion might be exactly what I need.
So I assume with the H4 conversion, you get a proper low beam cutoff? With the high beam, do you get a bit more wider beam and is the light output still pretty good? It appears the stock BD beam although shines very far is pretty narrow also and doesn't really illuminate the side of the road very well to watch for animals.
BlueLghtning - Follow me on my SPOT Messenger
Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650
Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225
Smugmug Pics - Save $5: Y2l43o9LVBERU
BlueLghtning is online now   Reply With Quote
Old 05-14-2012, 06:25 PM   #51
Boatman OP
Ride more, BS less!
Boatman's Avatar
Oddometer: 8,407
Take a look at the first post for pics of the illumination. The pic of the low clearly shows the the cutoff and the hi shows the spread.
Old 05-14-2012, 09:18 PM   #52
BlueLghtning
Oddometer: 3,850
Thanks, I took a closer look and I like what I see.
BlueLghtning screwed with this post 05-15-2012 at 09:11 AM
Old 05-15-2012, 06:02 AM   #53
Boatman OP
Ride more, BS less!
Boatman's Avatar
Oddometer: 8,407
Originally Posted by BiG DoM View Post
Hey BL - I also have a TE610 and love it! My conversion above to the BD 8" is though on my HP2 and I can say it gives a very good spread and throw and cut off with the H4. If you want to retain the full 8" refelction (as opposed to 7") you would need to find a used H4 headlight for removing the globe fitting.
While the retrofit of an H4 bulb in an 8" reflector will allow you to use a hi/low bulb you do not get the true hi beam and low beam. The lens of an H4 reflector is cut to give you the cut off for low beam. On low beam all that will happen is the light output will be cut by 5-20watts (depending on the bulb) but will have full dispersement just like the stock 8" desert style reflector with no low beam cut-off. Hi beam will be pretty much the same as the stocker. The pattern of the beam will also depend on how you arrange the bulb in relation to the reflector.
I know you mean well by posting your discovery in my Vendors thread but I produce these conversions for people that need an approved light to be street legal. This is the Vendors Section, if you feel so passionate about your modification please start a thread of your own in The Garage.
Thank you, Scott
Boatman screwed with this post 05-15-2012 at 06:14 AM
Old 05-15-2012, 07:38 AM   #54
GB
Mod Squad
GB's Avatar
Oddometer: 53,454
Inmates: please read the posted rules in Vendors.. no thread shitting and no poaching by posting links to alternate vendors or "PM me for a better deal".. Start your own vendor thread.
Old 07-13-2012, 07:15 PM   #55
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 228
Conversion kit is dead on! Went 1 step further with a 35 watt HID conversion high/low solenoid bulb and electronics off Ebay for $35.00. It fit perfect, great pattern and lumen output (basically, will melt steel at 30 paces), an unbridled success! Thanks for the kit!
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 08-17-2012, 07:39 PM   #56
Rivera926
Oddometer: 1
Dual 8" Kit
Is this kit also compatible with the Baja Designs dual 8" assembly?
I have always wanted this kit:
http://bajadesigns.com/ProductDetail...8-Inch-Halogen
but I would like the ability to have hi/lo beam.
Thank you, I am new to this message board
Rivera926 is offline   Reply With Quote
Old 08-18-2012, 06:24 AM   #57
Boatman OP
Ride more, BS less!
Boatman's Avatar
Oddometer: 8,407
As far as I know BD uses the same buckets for the dual as the single in which case they will be compatible.
Old 08-18-2012, 10:50 PM   #58
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 228
Moved my BD 8" c/w conversion and HID installed, from my TC450 to my newest "adventure bike", a converted HD XR 1200. Light is fantastic on the road as well! Thanks Boatman!
Old 01-03-2013, 11:32 PM   #59
Taranis
Oddometer: 330
Nice installation article of this combination here:
http://www.motoiq.com/magazine_artic...onversion.aspx
Check out the pics on page 5 for results!
DIRT BIKES ARE FUN AND INTERESTING
Taranis is offline   Reply With Quote
Old 01-04-2013, 12:48 PM   #60
hahmule
Balding Gloriously
hahmule's Avatar
Oddometer: 566
Want One..
for my Baja designs light. PM payment info, thanks
What a lovely bunch of coconuts.
Better to be a fast mule than a slow race horse.
hahmule is offline   Reply With Quote
Times are GMT -7.   It's 04:19 PM.
