Old 10-28-2010, 09:36 AM   #211
sailer
trained Cirus Bear
sailer's Avatar
Oddometer: 834
ok so the hockey stick came stock. ok
other questtion for the group
what was stock spring rate that came stock with the 2003 exc 300???
sailer is offline   Reply With Quote
Old 10-28-2010, 01:50 PM   #212
danketchpel
Oddometer: 2,632
Originally Posted by DirtJack
..... but I still added the button which is great when the fire goes out and you are poised on a precipice.
I will agree there are times when being able to push a button to light the fire while keeping your feet down can be extremely useful if not life saving. I'm trying more and more to keep myself out of those situations, LOL. I hate taking chances with gravity.
13 MG Stelvio NTX, 09 Duc Sport Classic, 02 Speed Triple
13 Husky Terra 650, 00 Suzi DRZ400-S
danketchpel is offline   Reply With Quote
Old 10-28-2010, 01:51 PM   #213
ErricZ
ErricZ's Avatar
Oddometer: 750
my book sez 71-90/260 in the back, 4.0N/mm up front
ErricZ is offline   Reply With Quote
Old 10-28-2010, 01:51 PM   #214
danketchpel
Oddometer: 2,632
Have any of you 300 owners found a good setup for a radiator overflow tank? That's the next mod I'd like to add.
Old 10-28-2010, 08:20 PM   #215
Stu
Buffo Maximus
Oddometer: 955
Overflow Tank
I made one for my 525 EXC. It worked so well I put one on my 300 as well. My cost was about $8. You can see it here:
http://www.advrider.com/forums/showt...201026&page=11
It is under the heading "Coolant Collector".
Stu
Stu is offline   Reply With Quote
Old 10-28-2010, 09:04 PM   #216
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,579
I run Evan's coolant in my 300 so it never overheats. But some does slosh out if I fill it to the cap. When I bought it, Roger from Elite told me to only cover the top of the fins and thus none will come out.
My KDX had the same problem (no overflow tank). I routed the overflow hose up to the top of the triple tree-right under the number plate and problem solved.
I despise Ethelyn glycol in so many ways...but most folks like it I guess.
You looked down here...didn't you.
MeterPig is offline   Reply With Quote
Old 10-28-2010, 10:31 PM   #217
Stu
Buffo Maximus
Oddometer: 955
Evans
I run Evans as well. The bike most likely runs 10+ degrees hotter that stock but it doesn't boil over. What does escape gets caught in my overflow bottle to be sucked back in when the bike cools down.
Stu
Old 10-29-2010, 05:24 AM   #218
ErricZ
ErricZ's Avatar
Oddometer: 750
Yup, another Evans convert here ever since I've owned modern triumph motorcycles! :) I didn't fill the radiator, I added 1.3L at a 30-degree angle, as per the manual states. I haven't run it in the summer yet, so I'll see next year.
Old 10-29-2010, 08:08 PM   #219
sailer
trained Cirus Bear
sailer's Avatar
Oddometer: 834
vibration damper for hadle bar
so who's (brand) Vibration Damper work the best with the ktm trees?
Old 10-30-2010, 12:08 AM   #220
996DL
Buell me
Oddometer: 2,356
Check into BRP top triple trees with rubber mounted bar mounts, they utilize CRF elastomers, the product is top notch and suprisingly affordable...
996DL
996DL is offline   Reply With Quote
Old 11-01-2010, 04:13 PM   #221
sailer
trained Cirus Bear
sailer's Avatar
Oddometer: 834
996DL
does anyone make a handle bar damper that works with the stock KTM trees??
Old 11-01-2010, 05:35 PM   #222
big adv
I need supervision
big adv's Avatar
Oddometer: 1,072
KTM Hardparts has a set, they are for the newer tree's('08-), but can be made to work on yours. Spendy though.
BA
My dad's a TV repair man, he has an awsome set of tools. We can fix that!
big adv is offline   Reply With Quote
Old 11-03-2010, 07:41 PM   #223
sailer
trained Cirus Bear
sailer's Avatar
Oddometer: 834
best DOT tire for this bike
doing more and more payment on this bike these days and need a good trail type tire that is DOT approved. a, 20 on /80 off, type tire.
trail stuff with rocks and mud, stuff you find around New England
Old 11-03-2010, 08:33 PM   #224
big adv
I need supervision
big adv's Avatar
Oddometer: 1,072
Perrelli MT-21 is a good Dot tire
BA
Old 11-03-2010, 09:49 PM   #225
Bucho
Oddometer: 2,081
aftermarket seats
How interchangeable are the seats on the KTM models?
I have a 99 300EXC. The bike came a SDG and a stock KTM seat. Both are very low. I know its a dirtbike and not a touring bike, but I would like a taller seat.
Bucho is offline   Reply With Quote
Times are GMT -7.   It's 04:32 PM.
