11-14-2012, 10:21 AM
#736 | |
Purveyor of Light
Oddometer: 3,646
Not sure on the main jet. No overflow, when leaning it over. Starts first kick without choke, when hot or cold, thinking the low end/pilot is stinky rich.
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
11-14-2012, 11:00 AM
#737 | |
Torque Junkie
Oddometer: 3,531
With the SXS head I find I can run the back a tooth smaller (13/49) the extra grunt works nicely with a little more gear. Sometimes you'll hear "pipe knock" on decel with a higher com head caused by too lean cond (not enough fuel when the throttle is suddenly shut down), if you run in the a/s 1/2 turn that will usally solve it. |
11-17-2012, 08:30 AM
#738 |
Oddometer: 23
Jeting
I am planning on getting a 2012 300.... I live at 9600ft and I am not a mechanic.
1) For weekends in Moab will it run fine without rejetting 9600ft to 4600ft I assume I would richen the fuel oil mix a bit 2) of course rejetting is better....... how long would it take your not expert mechanic brother to rejet the bike? |
11-17-2012, 10:50 AM
#739 |
Lacks Freetime
Oddometer: 4,913
The KTM..back in its natural habitat...sadly, not for that long.
![]() I just got back from a short test ride. Good news..I made it back. Bad news..I broke the bike. It died coming back on road, two streets away from house. While rolling at speed ...I jumped it going to start it again. It wanted to stall on low end...I did not let it. Got it in driveway and thought it was just lack of fuel. Put in on reserves and tried kicking it. Kicked waaay to easy. Hummm compression issue. Praying it was a loose spark plug..I pulled the seat and tank to check. Plug was fine. I suspect with the difficulty I had putting top end back together..something was wrong with rings...and they probably broke on ride home. With kid coming ..this shall sit till spring. Ugh. KTM's
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011 WRR/X rear shock adjustment , DZ Moto Photo Bloggin' , Learning photography thread - Ryder Joseph Z. , Born 11/26/12-- the next Adventure begins. |
11-17-2012, 02:26 PM
#740 | |
Scone Rider
Oddometer: 6,699
I don't mean to be harsh. I've made my share of expensive mistakes. Sometimes the purpose in our life is to serve as a warning to others. Sometimes I'll tell the story of the CB750F build and the "Llama Incident"
We don't stop riding because we get old, we get old because we stop riding. |
11-17-2012, 03:32 PM
#741 | |
Lacks Freetime
Oddometer: 4,913
This is the third two stroke top end I have done, and never used one. Not sure how you would get it out?? Usual method is to hold rings with hand, and then lower cylinder down onto piston, while squeezing the rings. Its not like a four stroke, where the piston and connecting rod goes in from top of head, and gets bolted around crank journal. In two stroke, connecting rod does not come out unless you take whole motor apart. Maybe I am missing something.
11-17-2012, 05:54 PM
#742 | |
Oddometer: 4,804
RIDE SAFE |
11-19-2012, 08:09 AM
#743 | |
Scone Rider
Oddometer: 6,699
With that said, I've never used a ring compressor. I've always well oiled things and jiggered the rings thru the taper at the bottom of the cylinder. Because of the requirement to align the rings with the pins on the piston, a 2 stroke is usually more difficult. I'll probably be visiting Harbor Freight to get a ring compressor for my upcoming 300 top end job. The most difficult top end I ever did was a V4 honda. The cylinder banks were cast into the upper case. You had to align all the pistons as you brought the upper case & cylinder down. After that project, I vowed never to own a bike with more than 2 cylinders. Currently shopping for a KTM 950/990.....
11-19-2012, 09:00 AM
#744 | |
Lacks Freetime
Oddometer: 4,913
The only way I could see you using a ring compressor, on of these motors, is to use it, to insert the piston, down into the cylinder, from the topside, push it down enough to expose just the wrist pin hole, and then try to put the combo down over the connecting rod, and insert the wrist pin and clip(s), that way, through the connecting rod. Even if that is even possible with motor in bike, I am not sure. Somehow, I doubt it. I know I barely had room to get cylinder on from top, while trying to compress the rings with my hand, and slide down from above, the normal way I know it and have done twice already.
11-19-2012, 09:25 AM
#745 | |
Scone Rider
Oddometer: 6,699
I think I see the issue with the ring compressor. There's not enough space below the cylinder to get it in and out of there. What's really needed is a half-height ring compressor. I'm wondering if just a hose clamp couldn't be used on the 2S?
11-19-2012, 09:40 AM
#746 | |
Lacks Freetime
Oddometer: 4,913
At the end of the day, it probably was my fault...as I had to take the cylinder off three times to change the gaskets and get the proper Z setting. What a PIA. Once I got the proper gasket on there, the rings/piston gave me a hell of a time going back into the cylinder. Although it did seem OK, once I finally got it. This time, I'll be pulling the motor for sure. The nice thing about these two strokes..they make it pretty simple to pull motor.
11-22-2012, 07:02 AM
#747 | |
Oddometer: 147
I don't see anything gained by pulling the motor out. |
11-22-2012, 07:29 AM
#748 | |
Lacks Freetime
Oddometer: 4,913
Pulling the motor will make it easier to get cylinder on correctly, for me anyway. When I did the top end on a YZ125, I did it on bike and had no issues. This motor, I have done out of frame, and had no issue. This last time, motor was in frame, and I had room issues. Not sure why...but I did. Also, if I have to send cylinder out to get redone, I'd rather have motor in house, and not out in weather*temp) changes in shed.
11-22-2012, 10:32 AM
#749 |
Lacks Freetime
Oddometer: 4,913
On a side note, I did watch a bunch of vids this morning with the KTM 300 EXC in them, and my bike does sound normal.....you know, when running.
11-22-2012, 03:26 PM
#750 | |
Torque Junkie
Oddometer: 3,531
Yeah I know, the old ones are still available. My hardest cyl install was a VW waterboxer, seperate cyl liners that fit down into a non removable waterjacket that pretty much blocks all access for a mortal like me.
