Old 02-07-2014, 01:07 PM   #1441
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
Originally Posted by DougZ73 View Post
I'd be leary to take it out of the freezer and put a lot of heat on it right away....would probably crack the aluminum case....which is not wanted.
I didn't mean throw the blue flame to it right away.
Fuck,everything in moderation.
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
Theres a name for people without beards,"Women".
AWM is offline   Reply With Quote
Old 02-07-2014, 01:25 PM   #1442
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,022
I do F in moderation.....just stick a little in at a time till she is used to it.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 02-07-2014, 01:56 PM   #1443
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
Same with aluminum.
Old 02-07-2014, 03:16 PM   #1444
dentvet
Oddometer: 1,354
Stick the the case in the oven or bbq and slowly heat it up, bearing side down and gravity will plop the bearings out onto the cookie sheet. the aluminum expands more than the steel. 250-300 degrees
theres a cool video of husaberg assembly line where the cases are sitting on simple hot plates and the ladies just drop the cold bearings in, kerplunk. no press or tool, just gravity
dentvet is offline   Reply With Quote
Old 02-07-2014, 05:13 PM   #1445
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,022
I have heard of heating the whole case upside down too....even says to do it that way in the pdf manual I have. The issue is there are about 4-5 other bearings and seals in there that I do not want to drop out or be melted(seals).
Old 02-07-2014, 05:38 PM   #1446
toadnumber55
toadnumber55's Avatar
Oddometer: 15
Just got my katoom in the house, it is an 99 exc. Sadly it might sit for awhile because I have to put money into my truck now.
toadnumber55 screwed with this post 02-07-2014 at 06:56 PM
toadnumber55 is offline   Reply With Quote
Old 02-08-2014, 11:19 AM   #1447
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,022
10 minutes at dealer and $20 later( lunch money) and , stuck old bearing case is out, and new bearing is installed. As usual, my dealer does right by me.
Old 02-08-2014, 08:11 PM   #1448
Toadady
Toadady's Avatar
Oddometer: 3,938
here ya go son
Toadady is offline   Reply With Quote
Old 02-09-2014, 09:05 PM   #1449
Toadady
Toadady's Avatar
Oddometer: 3,938
so far we've found....
cylinder was already off, but base of jug had silicone on it
powervalve cover had no gasket and plenty of silicone
powervalve lift arm stopper was MIA, and has been run without it, pv had been up against piston for long time
water pump impeller bolt is MIA, flat washer was there, and the impeller is stripped
kick starter is gone, and retainer bolt is broken off in shaft
rear wheel spoke missing and spokes are very loose
front and rear wheel bearings are shot
swing arm bushing at shock is wornout
lower chain roller is shot along with chain
Old 02-10-2014, 04:08 AM   #1450
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,022
PV cover does not get a gasket..silicone per manual. there should be 4 little orings in there though.
no wonder why you got such a deal.
Old 02-10-2014, 05:28 PM   #1451
Pmason
Pmason's Avatar
Oddometer: 143
sounds like a nice project
2008 KTM 300 XC-W
Pmason is offline   Reply With Quote
Old 02-10-2014, 07:38 PM   #1452
Toadady
Toadady's Avatar
Oddometer: 3,938
anyone know how to put these things back together?
Old 02-10-2014, 09:44 PM   #1453
Capt. Egregious
Capt. Egregious's Avatar
Oddometer: 368
I like Three Bond instead of silicone.
Capt. Egregious is offline   Reply With Quote
Old 02-11-2014, 04:54 AM   #1454
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,022
ha.....I am in same boat....but mine does not look nearly that neat...parts here, parts there, etc. LOL
Old 02-11-2014, 06:22 AM   #1455
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
You boys better get to it!!!!![Dougy]Winters gona be all over before your done.
Times are GMT -7.   It's 03:12 PM.
